500w inverter question
Results 1 to 20 of 21
    Aug 2018
    Paarl
    Thanked: 63
    Default 500w inverter question
    Hi
    I bought a 500w inverter to put in my trailer.
    My question is:
    1.When connected to the battery the green light on inverter burns the whole time alltough switch is in off position. Is this good or bad.
    2.When switch is in on position the fan runs continuously without or with a load. Is this good or bad.
    The inverter does the job altough it is a cheapie I just don't like things like the light burning when my trailer is parked and the fan is annoying.
    Jacques
    Thanked: 96
    Default Re: 500w inverter question
    Any inverter when connected to power has a "no load consumption". So it is going to drain your battery without any load. Best is to disconnect when not in use.
    Ps 16:5
    Thanked: 152
    Just wire up a 2 pole isolator switch between the battery and the inverter and switch off when not in use.
    2009 Suzuki GV 3.2
    ex : 2010 Suzuki GV 2.4 M/T
    ex : 2007 Audi A4 2.0T - RS4 rear suspension 8
    Thanked: 518
    All the inverters that have a green and red LED and power switch that I have seen only light up the green when the switch is on. The red is on when there is a fault. This convention does NOT draw any power when switched off even if it is connected to a battery. The on/off switch is there to prevent a drain from the battery when off.
    The fan running as soon as you switch on could also be due to the saving on cost to monitor the temp.
    Aug 2018
    Paarl
    Thanked: 63
    I have 2 inverters one is the changi one and not one of them has the green light on the whole time and fan running whole time when switched on.
    Tried to return inverter to supplier cause for me that is not what I thought it should be.
    Supplier just say inverter works no money back. Name:  LN-500_Inverter_grande.jpeg
    Aug 2008
    Rangeview Krugersdorp
    Thanked: 1242
    I bought a Doxin many years ago. Has never missed a beat !
    Ford Figo 2016
    Aug 2018
    Paarl
    Thanked: 63
    Does the fan also run the whole time.
    Aug 2008
    Thanked: 1242
    Quote Originally Posted by fatbike View Post
    No, does not run with just the router, if I add the charger it flicks on and off, only when I add the laptop does it stay on but very quiet.
    Ford Figo 2016
  9. The Following User Says Thank You to duncang For This Useful Post:
    Aug 2018
    Paarl
    Thanked: 63
    Thanks I will see it as a learning curve school fees paid.
    Will get something that suits my needs
    Thanked: 295
    Relocate the inverter so you dont hear it.
  12. #11
    joburg
    Thanked: 444
    Do you know what it's power consumption is with no load? I'm quite interested in a small cheapie inverter to test on my system, my 1500w (Meanwell home solar 400a batteries) inverter's own power consumption is by far the biggest load on my whole system.
  13. #12
    Thanked: 518
    Quote Originally Posted by sparewheel View Post
    For starting to compare the China Changi draws 10W when switched on and no load. With the weak Rand the 3000W peak is no longer cheap. The fan only comes on at over about 300W which is great.
  14. #13
    Feb 2013
    Thanked: 289
    Fan running all the time even with no load will annoy me as well.
    What does the manual say about that green light, does that green light mean it is sort of in stand by and still drawing a little power?
    "The darkest places in hell are reserved for those who maintain neutrality in times of moral crisis." - Dante Alighieri
  15. #14
    Aug 2018
    Paarl
    Thanked: 63
    You know the chinese manuals they always say as litttle as possible but the supplier say it is stand by.
    But I do not understand it cause switch is in off position. Like I said school fees paid I just think something like fan running should be included in description I was never told that it will run continuously when switched on��
  16. #15
    Feb 2013
    Thanked: 289
    If you decide to keep it, I'd put in a extra switch between the inverter and battery to totally switch it off, just be sure to get one rated for the correct current.
    If I may ask, what did this inverter set you back?
  17. #16
    Aug 2018
    Paarl
    Thanked: 63
    I paid R500 for it but not going to use it already looking for one that will work for me.
  18. #17
    Feb 2013
    Thanked: 289
    Not sure what your needs are and whether you need true sine wave or modified sine wave, but quick Google tells me you should come right for around double that if you look at this for example. https://www.outdoorwarehouse.co.za/p...h-usb-new/6424
  19. #18
    Aug 2018
    Paarl
    Thanked: 63
    Jip that is the one I am getting.
  20. #19
    Feb 2013
    Thanked: 289
    Just keep in mind it also still draws a little current even with no load, so if it can't be completely switched off, I'd still add a extra switch.
  21. #20
    Thanked: 518
    It should not draw any current when switched off as all the guys who bought the Changi will know. One should not have to add switches between bat and inverter if things work as they should.
