Nissan sani kb280td project...
Results 1 to 2 of 2
    May 2020
    Parys
    Default Nissan sani kb280td project...
    Hey guys
    Im new here, awesome forum 💪💪💪
    Please help, ive got a nissan sani vg30 v6 4x4 off from an elderly couple, vehicle is mint and the price was amazingly low as it was a non runner and stood in his gerage for a year or so...
    Vehicle had no clutch and didn't start. The clutch was only the master cylinder R210... sorted.
    Furthermore with the starting issue we discovered it had and old anti hijack system together with the dictator ecu somehow didn't correspond 😆
    Got her fired up but she runs uneven and on 2800rpm there's a funny knocking noise.
    I have a super clean isuzu kb280 tdi motor and would love to put it in this sani because the rest of the vehicle is still unbelievably solid. 210k on the clock, one owner.
    What do i do with "bellhousing/adaptor" in order to run on the sani's gearbox and 4x4 system?
    Thanked: 13635
    Default Re: Nissan sani kb280td project...
    Rather just get the Isuzu KB 4x4 gearbox and transfer case, the front and rear propshaft on all Jap IFS vehicles should all be the same: front prop out on LHS, rear prop out in the middle.
    Otherwise go read here:
    https://www.4x4community.co.za/forum...atibility-Info
    Reenen is the best guy for advice on this type of conversion from and to Nissan engines.
