Aftermarket TPMS ?
Results 1 to 8 of 8
    Rangeview Krugersdorp
    Thanked: 1291
    Default Aftermarket TPMS ?
    What and which type to look at for a small hatchback ?
    Ford Figo 2016
    Thanked: 1291
    Default Re: Aftermarket TPMS ?
    Bump..
    Ford Figo 2016
    Melkbosstrand
    Thanked: 174
    I've got Steel Mate TPMS on my bakkie
    decent enough quality
    https://www.steel-mate.co.za/
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  4. The Following User Says Thank You to BobMabena For This Useful Post:
    Jul 2019
    Houtbay
    Thanked: 28
    Steelemate and TyreMoni will do the job.
    There are quite a few other makes on the internet for under R1000. Don't know how good these are.
    On tar, you quickly feel when something is wrong with the tyres. I would not use a TPMS.
    On poor gravel or off road, by the time you notice something is wrong, you've damaged the tyre beyond repair. Always use a TPMS in these conditions.
  6. The Following User Says Thank You to WillMartin For This Useful Post:
    Thanked: 537
    I have the below R400 units sold on www.banggood.com
    Impressed with it. Has usb charging socket as well as small solar panel. Sensitive enough to even show a temp increase if you brake hard for 2 or 3 robots. It does beep when pressure is below the set point or temp above. A great plus for these units are they don't give a constant beep if the unit is in the car and the trailer/Caravan is at home. They are available with inside or outside sensors. The batteries are the same as the expensive branded units. Pick up range is over 20m between Tyre sensors and the display unit.
    So happy with and want to get some for spare car and just keep it in the garage and glance on the display from time to time. No need to check Tyre pressures on a regular basis.
  8. The Following User Says Thank You to ekkekan For This Useful Post:
  9. #6
    Plett/Paulshof
    Thanked: 1001
    Steelmate
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa ?, Fusion 17 boat-Yamaha FT100hp 4st.
  10. #7
    Aug 2018
    Paarl
    Thanked: 72
    Please post a link to specific unit or supply name.
    Your link is just opening banggood
  11. #8
    Thanked: 537
    Quote Originally Posted by fatbike View Post
    https://m.banggood.com/IMars-T240-TP...l?rmmds=search
  12. The Following User Says Thank You to ekkekan For This Useful Post:
