Results 1 to 8 of 8
    Nov 2006
    Lonehill
    Thanked: 634
    Default Dust proofing a defender 130 tailgate
    What is the best way to dust proof the defender 130 tailgate?
    thank you
    BruceT
    ZS6EBT
    Defender 130 Puma
    Hermanus
    Thanked: 557
    Default Re: Dust proofing a defender 130 tailgate
    thank you
    I don't know. I travel with my sliding window behind cab open and it is dust free in the back. I am talking about Namibia dust.
  3. The Following User Says Thank You to Hylton For This Useful Post:
    Thanked: 180
    On my 110 I used foam strip with adhesive on one side. You can buy it at Builders. The broad thick one. Iv done extensive overlandig in thick dust and my canopy is 95% Dust free
    Edwin
    Defender '99 TD5 Pick Up
    Rock sliders, Spare wheel carrier, Roof Rack, Aluminium canopy, Tentco RTT, Tentco Awning, 280Ah Dual batteries, 3 x Sliding Drawers, Water tank, Hot Shower, Kitchen
  5. The Following User Says Thank You to Defender TAZ For This Useful Post:
    Thanked: 17104
    Combination of foam strips and door rubber.
    If I recall, the 130 tail gate isn't a one-piece like the 110? It's the HiCap tail gate? It has removeable sub-frames?
    Jakes Louw
    Nov 2006
    Lonehill
    Thanked: 634
    Thanks Jelo.
    Im not sure.
    Biggest gap I can see is where the catch "linkage" goes through the sheet metal to the pin.
    BruceT
    ZS6EBT
    Defender 130 Puma
    Swakopmund
    Thanked: 210
    "95% Dust free" is an oxymoron and does belong in the same sentence, Defender does not belong in the same paragraph.....
    2014 Land Cruiser 76 V8 SW
    1994 Defender TDi 200
    Drive it like you stole it!!
    North of Rooiberg.
    On my 130 the only dust proof part was the loadbin. The original tailgate rubber it came with did a really good job. Way better than the doors. With the rubberized bin i had to open the drainage hole in the front corner to drain water from time to time.
    The original rubber got damaged and was later replaced with a universal sort of door rubber i bought per meter, but it's not the same. It helps, but it's far from dust proof.
    Werner Smit
    2001 Defender 130 TD5
    2005 Discovery 3 TDV6
    2003 Discovery 2 TD5
    1999 Discovery 1 300tdi with lots of mods
    19 something Forward Control 2B
  10. The Following User Says Thank You to Ystervark For This Useful Post:
  11. #8
    Dec 2010
    Thanked: 456
    The only dust free part of my Defender is the dry-bag I keep my paddling emergency kit in. Oh, and the extra can or two of engine oil I carry.
  12. The Following User Says Thank You to DJR For This Useful Post:
