Looking for a motor and gearbox for a winding machine
Results 1 to 12 of 12
    Thanked: 1031
    Default Looking for a motor and gearbox for a winding machine
    I am looking for a supplier of an electric motor and gearbox combination with the following requirements:
    Output RPM: 80-500RPM
    Max output torque: 55Nm (co-insides with lower RPM)
    Output torque at minimum RPM: 10Nm
    Must be reversible and operated from a foot-pedal.
    Infinitely variable speed between the stated limits would be an advantage.
    I must be able to mount a 3-jaw chuck on the output with a capacity of 40-100mm.
    Power supply can be single or three phase.
    By voorbaat dankie
    Feb 2014
    Komga
    Default Re: Looking for a motor and gearbox for a winding machine
    Bearing Man Group
  3. The Following User Says Thank You to Kennedy For This Useful Post:
    durban
    Thanked: 1120
    Could a stepper motor attached to a cheap rotary table work?
    Thanked: 448
    Stepper motor controller is too expensive
    Thanked: 1003
    Misread the specs.
    Thanked: 1031
    Plunger, I have no experience with electric stepper motors. Only pneumatic ones, and that wo'nt work.
    It needs to move reasonably smoothly. Will a stepper motor do that?
    Dec 2014
    Thanked: 1918
    A retired lathe with a VFD?
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 1031
    That is an option I have been considering, but the guys are crazy with their prices.
    Thanked: 448
    What are you trying to wind?
    A single phase VFD will give you a 3 phase output.
    Motor & gearbox from Bonfiglioli .....
    Sorted
    Thanked: 1031
    Thanks @GaryFrank
    durban
    Thanked: 1120
    Try Zest. Bearing man but they are big bucks.We all want to know what you are winding. ?Yes we are nosey
    Thanked: 1031
    Thanks Plunger
    Sorry, can't say. NDA...
