Coastal Living & Rust - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 55 of 55
    Mossel Bay
    Thanked: 77
    Default Re: Coastal Living & Rust
    Our offices are 100 metres from the sea and I use https://www.jetskifishingsa.co.za/in...sassin-1-litre all over my vehicles,the also use it in Canada on the salt roads for protection on the vehicles,I use it every time I flush my boat motor and on my fishing reels..you only use a small amount on a 5 litre spraycan with water,I also use the Tectyl 506 because I get it at around R80 a can
  2. #42
    Thanked: 977
    Quote Originally Posted by WillMartin View Post
    700 m from the waves.... my experience:
    Outside door handles, etc.: grade 316 stainless steel. 304 tarnishes and pits. 3CR12 tarnishes but does not pit.
    Steel fence, etc. Galvanize AND paint. Hammerite is good.
    Epoxy-coat aluminium (windows, camper on back of LC, etc.)
    Wooden fences, etc.: stainless steel screws and bolts
    Wash line, etc.: replace every two years.
    Cars: in garage or carport closed on 3 sides - open side is away from the coast.
    Store stuff in an enclosed area - undercover is not good enough (steel paint tins, wheelbarrows, etc.)
    WD40 everywhere
    Air conditioners - have not found a solution that works. Has anyone solved this?
    Had this treatment specified by an AC specialist for coastal ( +-20-40m from HWM) AC units for a client - been 2 years now, no problems as yet ......time will tell
    https://bluchem.co.za/products/
    "The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence."
    - Charles Bukowski
  3. The Following User Says Thank You to Patrick L For This Useful Post:
  4. #43
    Cape Town Southern Suburbs
    Thanked: 1124
    Quote Originally Posted by Lofty View Post
    Wurth also sells an aerosol spray wax that is cheaper than the equivalent Tectyl spray and works as well in my experience.
  5. The Following User Says Thank You to Skylark For This Useful Post:
  6. #44
    Thanked: 438
    I bought a tin of the ACF-50 and am not very impressed yet. It might be great for corrosion prevention but from an application point of view, I still prefer Tectyl 506.
    It is very thin, oil like. It does not have the clinging on ability of Tectyl. It does not do the immediate capillary effect like Tectyl but forms a droplet and drips of. Very messy.
    Early days but I think I might stick to Tectyl in the future for automotive use.
    It seems to work well when cleaning firearms though. It is probably more suitable for these types of applications.
    I was given a sample of the Corrosion Block which appears to be the same thing but just ever so slightly thicker.Name:  1590844618549.jpg
    2004 Defender 110 Td5
  7. #45
    Plett/Paulshof
    Thanked: 996
    Quote Originally Posted by Patrick L View Post
    This also works for specific applications.
    (full data sheet attached)
    Q30
    SUPER PROTECTIVE FILM
    Q30 is a Super Protective film that gives long-lasting protection against corrosion and water ingress. Q30 is completely transparent and can be sprayed onto any exposed metal surface.
    Q30 has an extremely high electrical tolerance (up to 1000V) and can be sprayed onto electrical circuit boards. Q30 can be peeled off, and can stretch by up to 1000%. Q30 is 500 hour salt spray test certified and withstands temperatures of 100˚C for extended periods of time. Q30 prevents tarnishing, seals electrical circuit boards, prevents corrosion, seals small leaks in skylights and insulates and protects PCBs.
    Available in 400ml.
    i have tried this...not as good as valvoline Tectyl glashelder
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa ?, Fusion 17 boat-Yamaha FT100hp 4st.
  8. The Following User Says Thank You to BruceHun For This Useful Post:
  9. #46
    Plett/Paulshof
    Thanked: 996
    it comes off too easily. The Tectyl forms a solid barrier.
  10. #47
    Langebaanweg
    Thanked: 1146
    Quote Originally Posted by Sawdust View Post
    Tectyl and ACF50 are totally different tools.
    Tectyl is a more long-term corrosion protection.
    While ACF50 is a shorter term corrosion protection.
    It's very nice for places that needs regular attention/inspection as well as stuff like actuators, electric plugs and hinges.
    It's used on aircraft carriers to coat parts exposed to salt spray.
    It's a penetrating oil. Apply it on a cloth and wipe on area. Wipe off excess after 10 -25 minutes.
    I use it on my rear cross member after every wash.
    The rest, like chassis innards and under vehicle is treated with an Ardrox product similar to Tectyl.
    I reapply that every 5 years as gravel eats it away after a while.
  11. The Following 3 Users Say Thank You to jfh For This Useful Post:
  12. #48
    Apr 2008
    Boksburg
    Thanked: 29
    Subscribed. I am new to the coast (Knysna) and already learned a lot from this thread
    Chris
    Pajero GLX
    Imagine Comfortvan
  13. #49
    Thanked: 1124
    The Wurth I'm referring to works the same as Tectyl, it's a heavy wax coating and I've used both and can't say I've noticed much difference, it definitely doesn't come off easy.
    Wurth does have an enormous product catalogue so perhaps you are referring to a different product.
  14. The Following User Says Thank You to Skylark For This Useful Post:
  15. #50
    Postmasburg
    Thanked: 256
    Wurth do indeed offer a wide and good array of products.
    Could you perhaps give us the product name from Wurth that you are referring to Skylark?
  16. #51
    Wilderness
    Thanked: 1194
    I also live 300m from the sea and everything is rusting. Kitchen and bathroom utensils, replaced with proper stainless. Curtain tracks facing the sea now need to be replaced. Aluminium window handles, some have been replaced as they had corroded to bits. Cupboard hinges, garage door sliders and everything in the garage also rusting. Door handle screws don't last long.
    I have found, that everything that i had previously sprayed with normal penetrating spray rusts( Q20, spark, plofit etc) and i have the following theory:
    The normal rust penetrating spray contains brakefluid. Once it dries, the steel has been cleaned of any protective layer and the oxygen then gets to the clean steel.
    I have lately started using WD40 and tectyl glashelder.
    Be careful of using silicone on any steel products as it contains acetic acid and promotes rust. Look at vehicle window rust that have been repaired with silicon
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  17. The Following User Says Thank You to Pieterk For This Useful Post:
  18. #52
    Mossel Bay
    Thanked: 77
    The Tectyl differs in price from R145 to R210 a can, I know the price is below R80 a can because my friend sells it... Cant think the profit margin is so huge
  19. #53
    Mossel Bay
    Thanked: 77
  20. #54
    Dec 2013
    Ramsgate Kzn
    Thanked: 93
    im on the South coast Ramsgate l..lived in Pmb and wife said if i convince her to move to the coast ..its gota be a house on the beach...literally.
    We are sea facing and right on the beach with beach access 100 m ffom waters edge.
    i have grown to accept that everything rusts in the house and constant maintenance.
    i however am still battling after 3 years to accept my cars and tools starting to corrode.
    what bothers me is that i can not seems to get rid of the moisture in the garage.
    people suggested installing a dehumidifier to suck out the moisture ..costly but that will eventually burn out.
    washing the cars with paraffin does help
    finally deceided to rent out a workshop space closer inland near port edward to store my vehicles and projects just to protect them from the harsh weather .
    sorry to ramble ..but i wish i had a solution
  21. #55
    Thanked: 1124
    Quote Originally Posted by Mapog View Post
    This should be it: https://www.wurth.co.za/chemicals/su.../00893-082-400
