Results 1 to 20 of 27
Thread: Jockey Wheels
    Aug 2010
    Thanked: 31
    Default Jockey Wheels
    Hi all.
    Generally the nose weight of an off road caravan/ bush trailer is pretty heavy. These rigs are normally fitted with a heavy duty jockey wheel on a 60 mm shaft and a 190 mm rubber wheel.
    However, I have experience that it still remains difficult to move the rig around on thick soft sand or soft grass surfaces. So I was wondering if there are any benefits in fitting a double or even a triple jockey wheel, or for that matter, even another single jockey wheel unit on the opposite side of the a frame.
    Any experience or any thoughts ?
    Love to hear from you,
    Alit
    Wees altyd bedagsaam teenoor ander.
  2. The Following User Says Thank You to Alit For This Useful Post:
  3. #2
    Thanked: 1380
    Default Re: Jockey Wheels
    Just a thought. A pneumatic wheelbarrow wheel and then you reduce tyre pressure for the circumstances.
    Aug 2018
    Paarl
    Thanked: 230
ID:	573146Click image for larger version.
    What about this
  5. The Following 3 Users Say Thank You to fatbike For This Useful Post:
  6. #4
    King Williams Town
    Thanked: 1902
    Fit two wide jockey wheels in place of the one jockey wheel.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Nov 2006
    Thanked: 481
    "A pneumatic wheelbarrow wheel and then you reduce tyre pressure for the circumstances."
    This is the answer.
    Im having the jockey wheels of my boat and caravan replaced asa i can move around freely again.
    The wheelbarrow wheel is too big, Burquip used to have the small wheels I think it was used for generator frames/luggage trolleys.
    Wilderness
    Thanked: 1448
    Your caravan has too much weight in the front.
    Pieter Kemp.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  9. The Following User Says Thank You to Pieterk For This Useful Post:
  10. #7
    Thanked: 1293
    Double wheel helps, I put one on my Jetstream.
    FJC - Just Cruising
  11. The Following User Says Thank You to dirtshark For This Useful Post:
  12. #8
    Thanked: 499
    Double wheel is the answer. My Xplorer has that and I also fitted to my Off Road Trailer.
    Just be careful with pneumatic. Could catch you out with a flattie.
    Platkar 1: BMW 118 (SWAMBO)
  13. #9
    Thanked: 253
    The weight on my BL-Kewer is 120 kg and it still bites into soft sand.
    Got a solid wheel with bearings that is slightly round on the surface and 16 mm wider - no sharp square edges - and it seems to run better that the old wheel.
    Just used it twice before lockdown hit us in the Kgalagadi, will see when we camp again what it does.
    Fitting two wheels of the square type did not go down well, to bulky and in the way plus it still dug into the sand.
  14. The Following 2 Users Say Thank You to Danie S For This Useful Post:
  15. #10
    Aug 2010
    Thanked: 31
    Thanks to all of you. Looks like heavy nose weights on trailers and caravans are the rather the rule than the exception.
    I will experiment with a second single jockey wheel.
    Mooi loop.
    Alit
  16. #11
    Mar 2016
    Kloof
    Quote Originally Posted by Alit View Post
    Hi all.
    You need to have made/engineered for you a double pneumatic 250φ jockey. Use the standard wind up (top half) 60φ jockey.
    For towing, I turn the whole thing upside down, to get the wheels higher up, away from a high middle-mannetjie. See my foto. This JW really works in soft sand.
  17. The Following 3 Users Say Thank You to schully For This Useful Post:
  18. #12
    Apr 2017
    Quote Originally Posted by schully View Post
    Can you perhaps share the details of where to have this jockey made and where to find the wheels? Looks like this will work for me. I was interested in a product from Australia, but the transport cost was more than the actual product. https://www.youtube.com/watch?v=W7F1VHaMqhE&t=4s
  19. #13
    Polokwane
    Thanked: 822
    Conqueror Courage 2016
  20. The Following User Says Thank You to DC Polokwane For This Useful Post:
    FCS
  21. #14
    Thanked: 954
    Quote Originally Posted by FCS View Post
    This caddy where the normal wheel fits between these 2 to create 3 wheels next to each other. It is made of 2 old wheel forks.
  22. The Following User Says Thank You to ekkekan For This Useful Post:
    FCS
  23. #15
    Jan 2009
    Private Concession in the Linyanti
    Thanked: 79
    Quote Originally Posted by DC Polokwane View Post
    I fitted one of these to my trailer and it helps a lot.
    https://alko.co.za/product/200-doubl...-wheel-580202/
    Hope it helps
    I have the same on my Companion and moving it around in sand or soft soil is still a mission. Solid surfaces are a breeze.
    Land Cruiser 76 4.5D V8
    Conqueror Companion
    I don't trust anyone who's nice to me but rude to the Janitor. They lack integrity...
  24. The Following User Says Thank You to Bush Boy For This Useful Post:
  25. #16
    May 2014
    B-gowrie Randburg
    Thanked: 387
    ... if you have a spare wheel swingarm at the back , swing it out ... fully extended it will counter the nose weight a bit ...
    2002 Defender 130 DC HCPU. :
    Own the road... Any road ...
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8 :
    The Greatest Rover.
    ‘1975 Series3 88 PUP :
    Simply ... Classic ...
    ‘2017 Metalian Mini ...
    A Home from Home
  26. #17
    Polokwane
    Thanked: 822
    Quote Originally Posted by Bush Boy View Post
    The double wheel is a huge improvement on the single but I still struggled in thick sand.
    But that's just the way it is, it will have to do, luckily the Conqueror Courage's tow ball weight isn't too heavy.
  27. The Following User Says Thank You to DC Polokwane For This Useful Post:
  28. #18
    Thanked: 1301
    I did this mod to the jockey wheel on my Xplorer. It was a dual wheel unit and I added a third wheel between the other two. I upgraded the axle bolt from normal 8.8 to a stronger high tensile steel one. So far it has worked well and was relatively cheap to do. Click image for larger version.
ID:	614873Click image for larger version.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  29. The Following 2 Users Say Thank You to Paul#25 For This Useful Post:
  30. #19
    Thanked: 4901
    Additional wheel Paul#25 used are readily available at caravan shops. Not expensive. That higher tensile bolt could be 10.9. Bolt shop should have those. The grades are 8.8, 9.8, 10.9 and 12.9. I think that 9.8 is rare. Alternative solution is to get high tensile rod and have the bolt supplier to put threads on at the ends or buy threaded rod. Easy solution is to have 8.8 and spare.
    Jouko
    2003 Grand Cherokee 4.7l
    2012 Smart
    Never drive a normal car 8)
  31. #20
    Polokwane
    Thanked: 822
    I think that for soft sand (and maybe mud) the setup in post #11 will work the best.
