Engine type confusion
Results 1 to 7 of 7
    May 2016
    Douglas
    Default Engine type confusion
    Okay, so I bought a '73 F250. The previous owner told me it was a 351 Cleveland engine. I have, however, noticed that the engine number is FE1049X. Apparently an FE engine is not a Cleveland? Does the engine number indicate the engine type?
    Is this a Cleveland or an FE engine? What are the differences between the two? Anything I should know about?
    Thanked: 13548
    Default Re: Engine type confusion
    FE is a Ford medium block used in Ford trucks and the Cleveland replaced it in 1976.
    352
    Introduced in 1958 as part of the Interceptor line of Ford V8 engines, the Ford 352 of 351.86 cu in (5.77 L) actual displacement was the replacement for the Lincoln Y-block. It is a stroked 332 with 3.5 inches (88.90 mm) stroke and a 4 inches (101.60 mm) bore, and was rated from 208 bhp (155.1 kW) with a 2-barrel carburetor to over 300 bhp (223.7 kW) on the 4-barrel models. When these engines were introduced, they were called Interceptor V-8 on the base models and Interceptor Special V-8 on the 4-barrel models.[20] The 1958 H vin coded 352 was designated as Interceptor V-8 Thunderbird Special according to the 1958 Ford V8 Cars & Thunderbird Service Manual pg 483. The Interceptor was the base-performance engine in 1958. For the 1959 model year, the FE engine series was renamed the Thunderbird V-8 and the Thunderbird Special V-8.[21] When installed in Mercury vehicles, these engines were named "Marauder". This series of engines usually weighed over 650 lb (295 kg).[23] In 1960 Ford created a high-performance version of the 352 rated at 360 horsepower (270 kW) it featured an aluminum intake manifold, Holley 4160 4-barrel (4-choke) carburetor, cast iron header-style exhaust manifolds, 10.5:1 compression ratio, and solid lifters.
    2V heads
    8.4:1 208 horsepower (155 kW) at 4000 rpm and 310 lb⋅ft (420 N⋅m) at 2800 rpm 19651967 Ford F-Series
    https://en.wikipedia.org/wiki/Ford_FE_engine#352
    Thanked: 13548
    Nice buy. Post some pics.
    May 2016
    Douglas
    Dunno how. I click on "Manage attachments" but nothing happens.
    Kathu
    Thanked: 2837
    Engine number does not tell much. You need the casting number on the block. You can find above the starter.
    Easiest would be to post a picture of the engine. I might be able to identify it.
    Feb 2020
    Las Vegas and Minneapolis
    Thanked: 328
    Yup, get the block casting numbers...
    http://www.mre-books.com/interchange/interchange11.html
    David -
    20 Toyota Tacoma TRD Off Road Decal Edition 3.5L
    If your only tools are a cutting torch and hammer, all of your problems are locomotives...
  7. The Following User Says Thank You to AardvarkNV For This Useful Post:
    May 2016
    Douglas
    I'll try and get it, then. Thanks.
