Interesting new engine ignition design
Results 1 to 15 of 15
    Feb 2016
    Thanked: 778
    Default Interesting new engine ignition design
    Source/More Info: Cheeseman, P., "A New Efficient Combustion Method for ICEs," SAE Technical Paper 2020-01-1314, 2020: https://www.sae.org/publications/tec.../2020-01-1314/
    Abstract
    The best known methods for combustion in Internal Combustion Engines (ICEs) are: Spark Ignition (SI), Compression Ignition (CI) and Homogeneous Charge Compression Ignition (HCCI). Each of these combustion methods has well known limitations for efficiency and clean exhaust.
    This paper presents a new method of combustion, called Entry Ignition (EI) that overcomes some of these limitations. EI burns a homogeneous fuel air mixture at constant pressure with combustion occurring at the inlet where the unburned mixture flows into the combustion chamber. Combustion results from the unburned mixture mixing with the much hotter burned gases already in the combustion chamber. EI can operate in a conventional piston-type engine, with the only major change being in the valving.
    EI’s efficiency gain results from the following. Firstly, EI is not subject to “knocking” and so can operate at CI-level compression ratios or higher. Secondly, EI allows lean burn, which improves efficiency for basic thermodynamic reasons. Thirdly, an engine using EI can fully expand the combustion gases (Brayton cycle), and finally, EI has reduced heat loss relative to the other combustion methods.
    These efficiency boosting effects combine independently to give a thermal efficiency of 63%, based on thermodynamic textbook-derived computer simulations. Because both EI and SI burn a homogeneous mixture, they do not produce significant particulate emissions. Also, EI can burn sufficiently lean that NOx production is kinetically suppressed, so that exhaust cleanup may be unnecessary.
    Nov 2011
    Langebaanweg
    Thanked: 1135
    Default Re: Interesting new engine ignition design
    As someone with a little experience, I think it will be overly complicated and expensive to maintain.
    I think that the electrical vehicle will be it's downfall before it will be a proven concept.
    But an interesting idea.
    Jun 2012
    Thanked: 1064
    For a stationary engine running at a fixed speed this may work. Cannot see how it can ever be put into a production vehicle with that level of complexity.
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
  4. The Following User Says Thank You to mullerza For This Useful Post:
    Thanked: 13635
    don't underestimate microprocessor speed and capacity
    Not so long ago, variable valve timing and multi-point sequential injection was impossible: now just about every single new vehicle has it.
    Apr 2018
    Fraserburg
    Thanked: 809
    This is a double expansion engine. Triple and quadruple expansion steam engines were in use over a century ago on ships. The Titanic had twin quad expansion engines. The rotary valve can be replaced by another steam age valve - The one used to send steam to the twin double sided pistons used on steam trains. It's principle is the same and proven unlike the rotary valve suggested.
    But this is going to a an expensive engine. A three times requirement for cylinders of different sizes. It falls foul of the law of diminishing returns. It's like getting 10 km/h more out of a car. It's possible but costs more than the car itself.
    Nov 2011
    Langebaanweg
    Thanked: 1135
    I agree and unfortunately there is potential for carbon buildup that can make the rotary valve less effective.
    Jun 2012
    Thanked: 1064
    Not worried about the electronics, even modern variable valve timing is mechanically relatively simple systems.
    I'm worried about the new hardware on this engine, specifically the fancy rotary valve sitting in the combustion chamber
    2012 Q7 4.2 TDI
    Thanked: 684
    What about a No-Camshaft Engine? ('Freevalve')
    Nov 2011
    Langebaanweg
    Thanked: 1135
    Wankel is also non-valve.
    I think it's an amazing engine, if they can just spend some more money on improving it more.
    Apr 2018
    Fraserburg
    Thanked: 809
    The British Napier Deltic Diesel. Extremely compact with three crankshafts and opposing pistons. No valves and supercharged. 18 cylinders and 36 pistons driving three crankshafts. Used on trains and ships. The only examples I know of in SA were fitted to SA Navy minesweepers bought from the UK. For the working principle see:
    https://www.youtube.com/watch?v=D3bj47TAYiU
    Jun 2012
    Thanked: 1064
    wankel unfortunately has fundamental design issues that cannot be engineered out such as the shape of the combustion chamber, plus the fact that the chamber effectively moves as combustion takes place so the flame front is always trying to catch up.
    wonderful engine, but there is a reason every manufacturer has abandoned it.
    2012 Q7 4.2 TDI
    Thanked: 903
    This looks similar to an article I read, and can't find again. The subject was individually controlled/actuated valves. Tremendous theoretical increase in performance and efficiency but reliability never got anything past a prototype...
    These kinds of ideas are dependant on someone actually finding a way to implement the design...
    "The problem with internet quotes is that they are very often unverified."
    -Abraham Lincoln
    Thanked: 2159
    I have seen enough systems that folks said "it will never...." that turned out to be every day in the modern world.
    My late uncle was a motor mechanic and I remember him warning against a too high compression ratio to avoid detonation, fast forward 30 years and my son's Audi rs4 v8 had direct injection like a diesel that allowed us to supercharge that engine to silly compression on an already high compression engine......safely. Impossible dreams is becoming common and everyday technology.
    The first diesel I did in matri was an old 404 peugeot bakkie that got washed down river in the floods in Lydenburg. I remember the engine was sent to Sartor Bros as they were the "best" motor engineers and they could set the diesel pump to a t.
    Turbos were used on the more upmarket trucks and tuning a diesel was a combination of science and witchcraft. Today turbos are the norm and common rail ijection is the standard with electronics doing all of the engine control and of course diesel engines making torque that easily puts an equivalent petrol to shame.
    I doubt that I will see this new technology come in to commercial production but who knows? they say the first person to reach the 200 year old mark has already been born maybe its me but I doubt that even more
    Henk
    Follow us on Facebook
  15. #14
    Thanked: 988
    Quote Originally Posted by MarcR View Post
    Read something a while ago that makes me pretty sure they are using something like this in F1...
  16. The Following User Says Thank You to Peter Connan For This Useful Post:
  17. #15
    Jun 2012
    Thanked: 1064
    F1 uses normal cam, but the valve springs are replaced with pneumatic systems as wire springs just cannot cope with the high RPM
    2012 Q7 4.2 TDI
  18. The Following 2 Users Say Thank You to mullerza For This Useful Post:
