TheQM – Tapping Reaming & Drilling Lube.
Results 1 to 3 of 3
    Sep 2018
    JHB
    Thanked: 37
    Default TheQM – Tapping Reaming & Drilling Lube.
    From R1426.00
    In light of the latest address by the President, it seems prudent to promote a Reaming & Drill Fluid as many will be returning to work during Level 3.
    A heavy duty, general purpose, active cutting oil.
    The cutting fluid assists the cutting operation by forming a chemical reaction at the tool tip, producing a compound with a high shear strength, thereby decreasing the friction at the cutting edge.
    It helps disperse the heat and chill the tool tip preventing softening of the tool and reduction of its cutting power by loss of temper.
    This eliminates and minimises distortion or warping of the work. Correct lubrication of the tool and work piece gives better surface finish, helps to give the chips proper form and prolongs tool life.
    To order online, and product specs, follow the link below:
    https://www.thequartermaster.co.za/i...Drill+Fluid+5L
    Price includes Vat.
    Full costs displayed BEFORE you have to pay.
    Online Credit Card and EFT Payment options available.
    www.thequartermaster.co.za we are still very much ONLINE, continue to deliver Nation-Wide and Internationally, Door2Door OR you can pop in and Click’nCollect
    Please contact us at [email protected] if you need assistance or have a query.
    MAG
    #TheQM
    E&OE
    Thanked: 247
    Default Re: TheQM – Tapping Reaming & Drilling Lube.
    To be used by us mere mortals every day in ZA
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sep 2018
    JHB
    Thanked: 37
