Looking for offcut stainless/ aluminium plate
Results 1 to 6 of 6
    May 2016
    Thanked: 8
    Default Looking for offcut stainless/ aluminium plate
    Hi guys - I'm in need of 1 or 2 stainless steel or aluminium plate/s 820 x 400mm but don't want to buy a full sheet. Does anyone have any left over or know where I can buy cut to size?
    JHB
    Thanked: 138
    Default Re: Looking for offcut stainless/ aluminium plate
    Thickness?
    May 2016
    Thanked: 8
    Quote Originally Posted by Woolf View Post
    Thickness?
Size:  205.3 KB About 1.5mm or so - it's to do a kitchen top like in the pic. If aluminium it may need to be 2 mm?
    Aug 2018
    Paarl
    Thanked: 67
    Quote Originally Posted by Enduroguy View Post
    Contact Heinz from metalian he sold alu to me last time not sure if he has 2mm
  5. The Following User Says Thank You to fatbike For This Useful Post:
    JHB
    Thanked: 138
    Can probably help you. Will measure when I get home from work
  7. The Following User Says Thank You to Woolf For This Useful Post:
    JHB
    Thanked: 138
    The sheets I have were taken off some lift doors. The one side is a bit scratched and the other side is covered with contact adhesive. The adhesive comes off easily with lacquer thinners and reveals a shiny unmarked surface. The sheet sizes are 2120x625mm. Thickness is 0.80mm which I think will be adequate for your purpose. Working with 1.5mm will be difficult without access to proper guillotines and benders. Working with this thickness is difficult enough.
    I am in Orange Grove. Please pm me a contact number so that we can arrange for this to be fetched
