Possible to charge main battery using solar and NL25 dc-dc?
Results 1 to 11 of 11
    Aug 2018
    Port Louis
    Thanked: 12
    Default Possible to charge main battery using solar and NL25 dc-dc?
    Wondering of its possible to use my NL25 dc-dc system (with solar) to charge the main battery once Aux is full? Is there a way to wire that up to automatically switch over? I dont think the NL25 system does this type of reverse charging automatically.
    thanks
    Mulva
    Apr 2016
    Thanked: 64
    Default Re: Possible to charge main battery using solar and NL25 dc-dc?
    What is the main battery used for? Is it to power the charger if there is no other supply?
    It looks like in a caravan/trailer mode with PV panels it doesn't need a main battery..
    Please confirm if this is the case..
    Aug 2018
    Port Louis
    Thanked: 12
    It's a simple dual battery system in my Defender. Main battery only used for starting and regular automotive features. Aux used for any overlanding accessories I have attached (led lighting, fridge, work lights). The NL25 is pretty straightforward - inputs from Main/alternator, Aux, ground and solar. The truck sits now and again with small battery drains from gps tracker and maybe other small parasitic drains. Main battery is also not in best shape anymore. It would be nice to be able to use the solar already topping up the Aux to keep Main charged
    Feb 2017
    Santa Cruz, CA
    Thanked: 224
    I have the NL25 DCDC too, and I also would LOVE this feature. Our vehicle is a dedicated overland vehicle, and goes long periods not being driven. Combined with the constant drain of the unavoidable CarTrack tracker, and it kills the start battery. Seem like it'd be great if the solar would switch over to the start battery if the aux battery was full.
    I'm going to install a manual switch, for when the vehicle in in storage, to accomplish this.
  5. The Following User Says Thank You to CalDriver For This Useful Post:
    Apr 2016
    Thanked: 64
    The charger isn't designed to charge the main battery but you might be able to make a plan..
    You could swap the batteries to charge both. They also could be switched electrically with a changeover switch..
  7. The Following User Says Thank You to Richard Mackay For This Useful Post:
    Feb 2017
    Santa Cruz, CA
    Thanked: 224
    I haven't drawn it out yet, but I am thinking of one of these switches: https://www.bluesea.com/products/600...y_Switch_-_Red
    Apr 2016
    Thanked: 64
    If it's not essential then an easy plan is possible..
    Thanked: 537
    Quote Originally Posted by CalDriver View Post
    Is the logic of the NL25DC-DC not in such a way that if you have solar it will not charge via the main battery.
    If it is then one can charge the main battery via the NL25DC-DC (2nd bat not connected to NL25DC-DCwith solar to keep it full and use a bypass switch to connect the main and 2nd battery together to be kept full when the vehicle is not used.
    Can this work?
    Apr 2019
    Thanked: 765
    I had a few technical questions on the similar 40A DC-DC and e-mailed Nat Luna support - got a very prompt and VERY thorough, and technical, response from them. You might try that route to get it straight from the "horse's mouth" so to speak - I was very very impressed with their support.
  12. The Following User Says Thank You to heyyahhey For This Useful Post:
  13. #10
    Feb 2017
    Santa Cruz, CA
    Thanked: 224
    Totally agree - NL support is excellent and knowledgable. Really impressed with them, and I've contacted them a few times.
  14. The Following User Says Thank You to CalDriver For This Useful Post:
  15. #11
    Jul 2019
    Houtbay
    Thanked: 28
    Been considering something similar for my NL 25A DC-DC setup.
    A marine change-over switch would work but is expensive.
    Could use a DB type change-over switch if inside the vehicle and not under the bonnet - a bit cheaper.
    A few Brad-Harris plugs would also work - cheap but fiddly.
    My preferred approach and what I'll probably do is buy a solar controller and wire it directly between the panel and the main battery. This is simple and gives you redundancy if your DC-DC charger fails.
