Daily runner is FUBAR, Help?
Results 1 to 20 of 22
    Thanked: 880
    Default Daily runner is FUBAR, Help?
    Hundai i10 daily runner, sitting in the garage since lockdown.
    Thought it be a good idea just to run the engine for a few minutes to get lube spread again.
    Got this.
    Any ideas?
    What do I do?
    Have a look at this vid:
    Lonehill
    Thanked: 25
    Default Re: Daily runner is FUBAR, Help?
    Charge the battery
    D
    2014 Jeep Grand Cherokee Limited 3.6 Pentastar
    1967 MGB GT
  3. The Following 5 Users Say Thank You to hercules_za For This Useful Post:
    Thanked: 880
    Is that how it sounds if the battery is discharged?
    Had no idea.
    Lonehill
    Thanked: 25
    Yip, not enough power to spin the starter.
    D
    1967 MGB GT
  6. The Following 2 Users Say Thank You to hercules_za For This Useful Post:
    Thanked: 880
    Thank you!
    Bethlehem
    Thanked: 4353
    Nie dalk die sleutel nie?? Het jy die duplicate probeer??
    Hoe lyk die fuses??
    2008 Mercedes Benz CL 500........................"Bullet" (going....going...)
    2006 Mercedes Benz C 180K........................"Sussie"
    Lonehill
    Thanked: 25
    D
    1967 MGB GT
    Dec 2018
    Thanked: 20
    Yup
    Agree with the other guys, recharge battery and all should be well again.
    Jun 2016
    Randfontein
    Thanked: 2054
    +1 Just the battery
    Willie
    2020 Nissan NP300 2.5TDi S/C
    May 2013
    Thanked: 25
    I had the same problem with my IX 35, a quick charge for a hour or so got it running again
    2007 Discovery 3 V8 SE
    2015 Hyundai IX 35 Limited Edition
  13. #11
    Thanked: 880
    Hoe lyk die fuses??
    dun ys meneer :-P
  14. #12
    Napier
    Thanked: 8
    Starter solenoid chattering due to flat battery?
  15. #13
    Dec 2014
    Thanked: 1839
    Meh, bat flattery, not a biggie.
    Problem arises depending how old it is, how flat it is and whether it recovers it's capacity. Run it for a good 30 minutes to charge it up properly, and leave a few days before starting it again to see if the battery holds charge.
    You may be in for a new battery sometime.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  16. #14
    Jul 2010
    Modders
    Thanked: 251
    Battery
    Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
  17. #15
    Thanked: 413
    OP, update please.....
  18. #16
    Plett/Paulshof
    Thanked: 990
    So many people don't realize that older cars need battery charged whilst care not being driven for long periods and with colder weather. Even newer ones after a while will need charging.
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa ?, Fusion 17 boat-Yamaha FT100hp 4st.
  19. #17
    somerset west
    Thanked: 417
    plenty of pensioners who drive 2 to 3 km several times per day and then wonder why the cars battery packs up prematurely.
    Not enough distance traveled to recharge the battery
    Add a week or 5 of standing with tracker using electricity and bingo battery dead
  20. #18
    Thanked: 880
    Simple jumper cable job.
    Thanks all.
    First time ever I hear that machine gun effect.
  21. #19
    Jan 2014
    Ezulwini Eswatini
    Thanked: 1988
    smart charger or trickle charger is a must have over long periods of car standing still, now that winter is going to hit even more so.
    2011 VW Touareg V.8 TDI
    2006 VW Touareg 3.0 TDi air suspension aka Pumba ( sold)
    2003 Pajero IO 2.0 aka Bosvark
  22. #20
    Thanked: 30
    Charge battery.
    Sound is the starter gear/rotor solenoid becoming a "klokkie".
    Due to very low battery, there is barely enough current to move the solenoid, but when it makes contact the starter coils draws all the current available to the point that there is no more current left for the solenoid to resist the return spring....it then moves back and then current becomes available again because the starter coils has been disconnected.... and then the cycle repeats.....tiki, tiki, tok
    Old:1998 Hilux SC 3000D
    Old: 2001 Hilux DC KZTE
    Old: 2007 Fortuner 3.0D4D
    Current: VW T5.1 BiTdi Transporter
