Replacement seats
Results 1 to 20 of 25
    Jun 2019
    Horsholm
    Default Replacement seats
    I'm finally getting myself a defend again.
    One of the things I think about replacing is the front seats.
    I think I have heard that BMW 6 series is a good bet.
    What have you guys used how did it pan out and at what cost?
    Mar 2013
    Thanked: 401
    Default Re: Replacement seats
    I havenít done the mod yet but im fairly sure most guys use e46 bmw seats.
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    LROC member:5881
    -Land Rover Defender 110 Td5
    -BMW F800GS
    Thanked: 13556
    I've also heard that the Discovery 1 seats will work.
    I would say that anything with a distinct seat rail system could be used.
    Jun 2019
    Horsholm
    How you mean distinct seat rail system?
    Jun 2019
    Horsholm
    And....I haven't tried discovery seats...any good?
    Plettenberg
    Thanked: 107
    2010 Honda Civic 5 door. Land Rover Seat belts compatible with the Civic.
ID:	572388   Click image for larger version.
ID:	572389   Click image for larger version.
ID:	572390   Click image for larger version.
ID:	572391   Click image for larger version.
ID:	572392   Click image for larger version.
ID:	572393   Click image for larger version.
ID:	572394   Click image for larger version.
  7. The Following 6 Users Say Thank You to Wilk For This Useful Post:
    Thanked: 13556
    Quote Originally Posted by RichisAfrika View Post
    something with two proper parallel rails
    bear in mind that you need to get underneath the passenger seat at least, so they must be able to lift or pivot
  9. The Following User Says Thank You to jelo For This Useful Post:
    Witbank
    Thanked: 204
    Quote Originally Posted by Wilk View Post
    Sorry for the side track, but could you please send me a bit of detail on the sitcom system I seen in the back of your defender?
    Thanked: 13556
    That is impressive, is there a build thread for that Defender?
  12. The Following User Says Thank You to jelo For This Useful Post:
  13. #10
    Nov 2019
    Currently in Secunda for work
    I was about to mention 2006-2011 Civic hatch seats because the civic fuel tank is placed under the front seats which means they are fairly low and thought they'd be perfect for a Defender
  14. #11
    Plettenberg
    Thanked: 107
    Jelo, I will one day as I noticed that there are guys like you that will appreciate it. There is not much that I haven't changed. Sometimes twice, you can see that I installed a overhead Aircon, as the original just just take up legroom space. Now rebuilding that again completely, will be a dual system with an air recycle function in the front. Also busy with a different Instrument cluster that is more like a Defender's.
    I am working overseas so plan, buy, make most things while away and use my 40kg luggage to the full when I go on my annual holiday (working)
    Sorry OT
Name:	20191123_205348 - Copy.jpg
ID:	572464   Click image for larger version.
Name:	20191118_173110 - Copy.jpg
  15. The Following User Says Thank You to Wilk For This Useful Post:
  16. #12
    Plettenberg
    Thanked: 107
    Quote Originally Posted by nedge View Post
    If you asked about the rear seats, they are from 2010 Honda Civic 5 dr that folds up, or down. Just made brackets not to complicated. If you want details can send you, but think might be not Many Honda's on the road so to find the seats might be the biggest problem. I paid R4500 for the Complete set.
  17. The Following User Says Thank You to Wilk For This Useful Post:
  18. #13
    Witbank
    Thanked: 204
    Hi sorry for that, damn auto correct. I meant the aircon unit. Have been toying with the idea to put into mine.
  19. #14
    Thanked: 13556
    It looks suspiciously like an old VW Caravelle microbus unit.
  20. #15
    Plettenberg
    Thanked: 107
    No, no but the air vents is from Audi A6. The rest I made from fiberglass. Evaporator is at the back, Generic truck type, but will change that with Toyota Hiace Evaporator.
  21. #16
    Plettenberg
    Thanked: 107
    OK, then mostly answered already.
  22. #17
    Apr 2011
    Sandton
    Thanked: 209
    Nice build, seats and other mods look great.
    '06 TJ Wranger | 4.0L Auto| 4.5" Lift | 35" Copper STT | 15" MT Classic II Black | 4.88 Gears
  23. #18
    Nov 2011
    Langebaanweg
    Thanked: 1124
  24. #19
    Thanked: 518
    If you are tall. Be careful.
    A lot of the seats, no matter how much you trim off the bottom end up too high.
    Defender Kalahari
    Series 3 SWB
    Series 2 SWB (Near Future)
    Series 1 Station Wagon 88''
  25. #20
    Thanked: 304
    This looks like an awesome build, please share more info, particularly that Auto setup Whats under the bonnet??
    Cruiser 76 V8
    Disco 4 XS
