Results 1 to 20 of 21
    Sep 2014
    Default Discovery3 twin battery installation - second battery fault
    Hi there
    I have a professionally fitted dual battery system fitted to my Disco3. This was installed several years ago for an overland trip - it worked great for that purpose.
    I want to know whether I can simply disconnect the second battery from the system whilst in town. The problem that I find is that the second battery is failing since its not really being utilised in town conditions - nothing is attached.
    I've now had 2 batteries die on me completely. They will no longer hold a charge - and this causes the main battery to go flat because the system keeps trying to charge the second battery (which won't take a charge).
    During lockdown, I've disconnected both batteries to be charged.
    - The main cranking battery was a little low, but picks up its charge and keeps it fine from a normal mains charger (and maintenance charger). Testing the battery, its good for cranking, saving etc.
    - The second (deep cycle) battery is flat, and will not take a charge any more. Its voltage is below 7V, and is therefore useless to man or machine!
    1. Can I simply disconnect the second battery from the dual battery system?
    2. Can I simply connect the two terminals of the second battery together - probably not a good idea, as it would be a direct short!)
    3. How do I disconnect the dual battery system, in favour of just the cranking battery?
    Deep cycle batteries are expensive - the current one is over R5000! Ouch!
    Can I get away with a smaller Deep Cycle Battery in its spot (perhaps one that is only R1500 or R2000?)
    Your expert advice is very welcome!
    Thanked: 1380
    Default Re: Discovery3 twin battery installation - second battery fault
    I'm no expert like Eggie or Fluffy but would say you can disconnect in town. But with no load on the 2nd battery, won't cause it to die. Do NOT under no circumstances connect two battery cables together. R5000 for a derp cycle for your vehicle? I would say they saw you coming. I would easily use a 102Ah (1150K) Royal. It should be a lot cheaper. Something else caused your 2nd battery to die.
    Sep 2014
    The second battery is installed in the right hand side compartment where the hydraulic pipes etc go. This means a tight space for a small battery (55Ah). There is not much on the market in the dimensions needed - Optima Bluetop fits = R5500!
    I don't want to cause a fire or other problem by not having a battery connected!
    Thanks for the tips!
    Thanked: 1380
    You can tape the terminals with insulation tape.
    I get the issue wrt battery size. There my "expertise" fails me. Someone else with more knowledge should assist.
    Mar 2015
    Thanked: 102
    I am no expert but something doesn't sound very kosher about your system.
    if you use a solenoid then the second battery should be isolated from the main battery and should not drain it when parked. The same goes for using a dc/dc charger unit, these would also isolate the second unit from draining the main battery. Without further information about the design/components of your system it will be hard to troubleshoot accordingly.
    If you need to bypass the second batter then start at the main battery terminals and remove the positive and negative power take of wires. Also test at the rear after removing with a meter if there is any power coming through to ensure it is the correct wires that were removed.
    I would remove the failed second battery from the current space as trying to charge a failed battery can cause numerous problems, among them being the battery exploding or catching fire or spilling battery acid in its enclosure.
    As an alternative for your small enclosure size i would rather look at a lithium battery and proper battery management system (BMS) to manage your needs.
    Snap some pics for us till one of the forum sparkys come along and help further...
    Quote Originally Posted by Photorer View Post
    Hi there
    Curent: VW Touareg 3.0Tdi R-Line
    Current: VW G6 GTi DSG
    Ex:Ford Ranger 3.2 Auto 4x4 XLT (Stolen but not forgotten)
    Ex:Paj DiD SWB Auto (Sold but not forgotten)
    Ex:E92 335i 430kw at the wheels! (Sold but not forgotten)
  6. The Following User Says Thank You to Kish2604 For This Useful Post:
    Thanked: 1380
    Optima is a very good battery. How long have you been using that one?
    Sep 2014
    OK - here's my setup:
    1. Main Battery (currently on maintenance charge just for luck!)
    2. Second battery located in a tight bay on the right of the car:
    Not sure if you can see, but the top of the battery is bulging a little directly above the round parts of battery.
    3. This is the DC/DC charger unit that has been fitted:
    WRND Dual Battery Charger - Unit automatically charges from vehicle or solar as detected.
    Current Limited to 20A
    Aux Battery boosted to 14.4V
    Aux battery float at 13.7V
    Solar voltage range 12V to 40V max
    Car Battery discharge to 12.8V
    Extend discharge to 11.8V
    The Optima Battery has been in there for around 1 year.
    Thanked: 1380
    I year for a proper battery such as Optima is not normal. Something went wrong somewhere. You should get at least 5 years service.
    Sep 2014
    Hence my question.........
    Sep 2014
    Simply removing the second battery and insulating the terminals sounds like a very easy solution.
    I just want to know that I will not be damaging the DC-DC charger, or possibly causing another problem.
    If I do that, I will also quickly find out what is not working, as that would have been attached to the second battery - a way of finding the fault!
    Thanked: 958
    Something is seriously wrong.
    There had been discussions from members that had trouble with their WRND units, but generally it's accepted to be a robust no nonsense dc2dc charger which will isolate the two batteries when power is turned of.
    So, if this is not being done, then there is a problem with your WRND unit. If not, then you had been given a factory dud as far as the Optima battery is concerned.
    Seeing that the battery is stuffed now in any event, you can just disconnect the cabling coming from the unit and insulate them where they connect to the Optima while you have the charger removed and tested.
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
    Thanked: 958
    Here is two of those discussions.
    https://www.4x4community.co.za/forum/showthread.php/329854-WRND-Electronics
    https://www.4x4community.co.za/forum/showthread.php/329855-WRND-DC-to-DC-Charger?highlight=
    Nico Swart
    ZS6NJS
  14. The Following 2 Users Say Thank You to Die SwartKat For This Useful Post:
  15. #13
    Sep 2014
    Seeing that the battery is stuffed no in any event, you can just disconnect the cabling coming from the unit and insulate them where they connect to the Optima while you have the charger removed and tested.
    This is the second attempt...... I firstly had a HCDC (?) unit fitted, that fried my second battery (previous installation). The DC-DC charger was swopped out for this one, and a "new" Optima battery installed. Its not been very long before the same problem arose.
    My primary battery is dead if I leave the car standing for more than a day. I've taken the opportunity of lockdown to source a solution........ last weekend I got a maintenance charger and battery tester, and found that the secondary battery is toast!
    If I can simply disconnect the secondary battery whilst still driving around to get things tested, that would be great! can you confirm that if I insulate the terminals this won't cause a problem.
  16. #14
    Thanked: 958
    Yes confirmed.
    Nico Swart
    ZS6NJS
  17. The Following User Says Thank You to Die SwartKat For This Useful Post:
  18. #15
    Thanked: 954
    Based on your pictures you have already disconnected the positive on the 2nd battery. As is already indicated you just need to tape them closed to prevent a short. You can then drive like that. Always better to also disconnect the positive at source as indicated and tape up.
  19. The Following User Says Thank You to ekkekan For This Useful Post:
  20. #16
    Sep 2014
    Right - here's an update on the problem that I've had for so long now that I can't remember when it started!
    I have disconnected the second Optima battery altogether, and securely connected the cables that connected to it to their respective polarities. This means the system is simply not trying to charge a second battery. (All nicely insulated of course!)
    Battery draining is still the main problem.
    I have put in a brand new Bosch battery 2 weeks ago, since when testing it, it showed it was not fully charged.
    I now have a situation where I cannot leave the car standing for a day whilst at work, because the main battery is dead in the evening. On Thursday it was so flat, that the instrument panel did a really good impression of a Christmas tree, and I got every warning possible from the system! I managed to jump start using a Jumpstart pack on Friday afternoon to go home. On getting home, the car started perfectly, no issues - and everything appeared as normal.
    I tried starting the car on Saturday morning- battery so flat I couldn't even get it to Jump Start! I have disconnected the main battery and its been on charge for the past 24 hrs.
    Nothing turned on in the car.... radio off, auto headlights off, auto wipers off..............
    It seems like there is a dead short to earth somewhere Is this possible?
    Any suggestions?
    Thanks in advance!
  21. #17
    Thanked: 830
    Alternator not charging/draining battery due to failed diodes, or some trackers or other parasitic currents drain g you battery.
    Chack the latter with an amp meter when car is switched off, pull fuses till current drop to id
    guilty circuit.
  22. #18
    May 2010
    Paulshof
    Thanked: 374
    Not maybe another case of hidden unidentified Netstar or other tracking device draining your primary battery?
    Roy
    Beneath every ‘Majestic Oak’ lies a ‘Tuff Nut’ that refused to give up!!
    Daily Drive : 2010 Discovery 4 SE
    Weekends: 2003 BMW K1200GT
  23. #19
    Sep 2014
    guilty circuit.
    I've checked the charging with a tester- Alternator is doing perfectly. When the engine is running - the system is happy....
    I will need to do some looking to see where there is a current flowing when the vehicle is switched off. Please clarify where I should check the current - between which terminal and which part of the fuse connectors? Thanks!
  24. #20
    Sep 2014
    Quote Originally Posted by royjacobs View Post
    Roy
    I have had the Netstar using removed years ago. That made a dramatic improvement at the time. There is no other tracking unit installed in the car which draws off the battery system - it has its own independent supply (one of the reasons I went with Tracetec!)
    I just hope its not a wire that has worn through from rubbing somewhere.........
