Results 1 to 20 of 21
Thread: Voltage drain
    Jul 2013
    Thanked: 547
    Default Voltage drain
    For the past while, my battery will go flat at the drop of a hat, sometimes it will be fine after a week, and sometimes it doesn't last two days.
    Besides my thermo fan, which only works when the car is running, I've disconnected everything that I had fitted aftermarket, and wired to the battery, so eliminating them as a power drain.
    Still the same problem, so I disconnected the negative lead and put a test light inline and it is lit up. (See pics.) I've systematically removed EVERY fuse one by one to check where the fault lies, and the only one that makes any difference is when I pull the 30amp fuse? (see pic) that according to the fuse box label is for the cabin fuse box, but this does not entirely remove the drain, it just brings the test light down to a glimmer??
    I have been told by two mechanics that the symptoms are the dreaded TRACKING unit, now as far as I am aware, my car doesn't have one, that I know of, but it did use to belong to Imperial Car rental, so this is a distinct possibility.
    My next question is: How the hell do I find it,if indeed there is one? I am not to keen to take all the panels out to look for something that I don't even know what it looks like!
Name:	test light2.jpg
ID:	572155   Click image for larger version.
Name:	test light1.jpg
ID:	572156   Click image for larger version.
ID:	572157   Click image for larger version.
    Mark Backler
    09 Kyron, the Korean Snail.
    NO Meeow!
    Blanked EGR.
    Thermo Electric Cooling fan.
    Rangeview Krugersdorp
    Thanked: 1597
    Default Re: Voltage drain
    Ask them which brand was fitted and have them remove it.
    Ford Figo 2016
    Thanked: 17104
    Post a pic of your positive terminal and all the wires connected to it.
    Jakes Louw
    Oppierotse
    Thanked: 293
    Before doing a battery drain test, you should wait at least 10 minutes for the PCM to go to sleep mode. If the bonnet have a switch, you must bridge it as well.
    Remove the alternator fuse(150A) and see if there is a change. If so, then there is a blown diode in the alternator.
    It is also better to use a multimeter or clamp meter to give more accurate readings.
    98 Hilux 2.8D D/C 4x4
  5. The Following User Says Thank You to wiel For This Useful Post:
    Melkbosstrand Cape Town
    Thanked: 116
    I had the same problem , here are my results
    https://www.4x4community.co.za/forum...y-battery-flat
    Jul 2013
    Thanked: 547
    Thumbs up Re: Voltage drain
    Quote Originally Posted by wiel View Post
    Dumb question/s: a) the car had stood since yesterday, so theoretically the PCM should have been asleep. How do I Bridge the bonnet switch? can I just unplug the wire from it? and if i remove the alternator fuse and diode is kaput, should the light then go out?
    Mark Backler
    NO Meeow!
    Blanked EGR.
    Jul 2013
    Thanked: 547
    I've owned the car for 7 years now! I doubt they will know?
    Mark Backler
    NO Meeow!
    Blanked EGR.
    Jul 2013
    Thanked: 547
    Smile Re: Voltage drain
    As requested, positive terminal. ignore the thin red wire, that runs to the thermo switch.
    Have tried with all doors shut, bonnet switch in the off position, and with the alternator fuse removed, the test light is still on.
    I do not have a multimeter, and to be quite honest, the last time I worked on a car, it was straight 12 volts! None of this fancy stuff about which I know zip!
ID:	572171   Click image for larger version.
Name:	Pos terminal.jpg
ID:	572172   Click image for larger version.
ID:	572173   Click image for larger version.
    Mark Backler
    NO Meeow!
    Blanked EGR.
    Thanked: 958
    A friend recently had a tracking company look for over 5 hours for his tracker. They phoned all over to find the person who installed it and no luck. The tracking company wanted to upgrade it.
    What I would do is to disconnect the earth on the battery and wire 2 leads to a multimeter o amp scale. Use a needle meter that will not go to sleep after some time. Route the wires to the outside of the car. Close the bonnet and lock the car as ussual. Then get a spare cell phone with camera with a APP that takes picture like every 3 seconds. This way one is bound to see if there is a above normal current as some stage even if it is only intermittend.
    Thanked: 17104
    I'm starting to get the same feeling.
    Jakes Louw
    Oppierotse
    Thanked: 293
    Quote Originally Posted by Markb View Post
    If ign was off the whole time yes, but there is also a BCM (body control unit) that is activated the moment a door open. Both of them stay activated for a few minutes when the ign is switched off.
    If you unplug the bonnet switch, the circuit stays open, which is the same as a open bonnet. You must bridge the two wires in the switch to simulate a closed bonnet. Otherwise take a screwdriver and push the bonnet lock close.
    If the light goes dim with the alternator disconnected , then the alternator is faulty.
    You really need to get hold of a multimeter. A test light cant tell you how many amps/ milliamps are drawn, and that is what you want to know.
    Jul 2013
    Thanked: 547
    Exclamation Re: Voltage drain
    After much head scratching, and searching, fuse and relay pulling, I "Think" I may have got to the bottom of the problem
    The other night at about 8ish, I went out to take the battery off charge, and reconnect the negative terminal.
    Now as I did this, I heard a faint but very distinct click.
    So this morning I decided to hunt down the sound, and after much prodding an poking, and by using a long piece of brake pipe, I found the thingie that clicks and then hums when I connect the battery! PROBLEM!!! I have absolutely NO idea of what it is, or how to even get at it!
    There are two connections on the rear of the fuel pump, which is of course hidden under the intake manifold, EGR, and some other bits and bobs.
    By dint of putting my listening tube on one or other connector, the click and then constant humming is very distinct! There is a green and a black connector, and the noise is most audible on the black one.
    Now just to find out what the hell they are, and how to fix it! Because I'm not sure if it is something else switching these things on, or what??
    Mark Backler
    NO Meeow!
    Blanked EGR.
    Jul 2013
    Thanked: 547
    Thumbs down Re: Voltage drain
    Adding to my previous post!
    Took the Snail to my diesel tech/auto electrician, and he put an ammeter on between the negative post and the earth strap.
    Started off with a 2.75amp reading, then quickly settled down to .5 amp draw?? We checked everything we could find, short of removing panels, and nothing!
    This really has me by the balls now!
    Oh and the click and hum, is the fuel pressure sensor, behaving perfectly normally!
    Mark Backler
    NO Meeow!
    Blanked EGR.
  15. #14
    Jul 2016
    Thanked: 614
    Mark the fuel pressure sensor shouldnt be drawing any current if the ignition is off
  16. #15
    Jul 2013
    Thanked: 547
    Quote Originally Posted by MikeBob View Post
    That's what I thought, and apparently it is only drawing when I reconnect, then it stops, and I'm left with the .5 amp draw
    Mark Backler
    NO Meeow!
    Blanked EGR.
  17. #16
    Jul 2016
    Thanked: 614
    have you tried unplugging it to see what draw you then get?
  18. #17
    Thanked: 1597
    I have mentioned before one of my cars had a faulty radio that needed current to store preset stations.
    Ford Figo 2016
  19. #18
    Kuilsrivier
    Thanked: 175
    So far all sounds normal.
    Fuel pump will try to maintain pressure in the system even if the ignition is off, same like an electric fan.
    To be honest, 0.5Amp at 12V is really nothing! That is only 6W.
    This is about what is needed to keep all the computers and systems active.
    For a 65AH battery, you would need around 5 days to drain your battery at 0.5A.
    Battery. Looks like 2019?
    When last did you have it tested?
    As mentioned, get a decent volt meter to check battery voltage and to see if the alternator is really charging?
    Also have a look at aftermarket radios.
  20. #19
    Jul 2013
    Thanked: 547
    [QUOTE=Wetkit;4403682]So far all sounds normal.
    Battery. Looks like 2019? Yup JUne 2019, Solite, so it's a good battery
    When last did you have it tested? January, by the agents, said it was fine
    As mentioned, get a decent volt meter to check battery voltage and to see if the alternator is really charging? Now disconnected, but have a permanent volt meter in the car, and it shows 14.7 while driving, and down to 12.7 standing.
    Also have a look at aftermarket radios. Car is completely original.
    Mark Backler
    NO Meeow!
    Blanked EGR.
  21. #20
    Kuilsrivier
    Thanked: 175
    Eish, I am out of ideas....
