Land Cruiser 80 or 105
Results 1 to 20 of 28
    Jul 2018
    Default Land Cruiser 80 or 105
    Hello
    Been lurking on the forum for quite some time and generally reading.
    I am looking for a either an 80 series diesel to work on as a project vehicle and start doing overland trips but man, they are super difficult to find.
    So i am wondering, should i consider a 105 series?.
    When looking at the two, is the big difference between the 2?
    I ideally want this to be a family vehicle when the time comes for kids so space is a necessity.
    I have joined various facebook groups and check gumtree etc, where else should i be looking for an 80 (or 105)?
    Ciao
    Rapa
    Apr 2018
    Rustenburg
    Thanked: 18
    Default Re: Land Cruiser 80 or 105
    Quote Originally Posted by RapaNui View Post
    Hello
    Ciao
    Rapa
    I am the owner of a diesel 105 and I must say these vehicles are like hens teeth. The 105 is obviously a much newer design and more comfortable vehicle but there are pretty much on the same chassis.
    The benefit of getting the 80 is that it came in a turbo diesel where the 105 only had a naturally aspirated diesel.
    I how ever love my 1hz 105 and would not trade it.
    Apr 2018
    Rustenburg
    Thanked: 18
    Here is mine, before I got Oupa, he had one owner and was completely standard.
    Swakop
    Thanked: 738
    a 105 will probably be even more difficult to find than a 80, and will cost quite a bit more if you do find one.
    Maybe contact Petri Oosthuizen on the forum, he might know of something, easiest to find him n the commercial member section. Also have a scroll through the classified section and have a look if you see a cruiser there.
    Robertson/ Larissa, Greece
    Thanked: 3288
    Quote Originally Posted by Michael11 View Post
    Michael, which suspension do you have fitted? And tyre size?
    Love the UN rims, look good!
    Bethlehem
    Thanked: 131
    The 80 you had various diesel versions, if you can get an 80 1HD-T or 1HH-FT that would be first prise
    105 Diesel was only the 1HZ, and I believe the gearbox is different to the ones in the 80, the 80 would be the stronger gearbox on the diesel's specifically
    If you are looking at a Petrol, the 4500EFI 80 or 105 would both be very similar
    Only advantage of the 105 above the 80 is the newer model, and on the 105 the Diff parts are inter-changeable with the current 79 series, so spares for those a lot more freely available
    Christo Davids
    Land Cruiser 105 4500 EFI
    Hilux 2.8GD6 Extracab 4x4
    Thanked: 13547
    Get an 80, really iconic shape.
    And the square headlight units are still available from Hella.
    I'd love a TDi LC80. Only a TD42Ti Patrol can beat it. Oh, and maybe a MB GW.
    Malawi
    Thanked: 1184
    The sticker on the damper is a Tough Dog one if I am not mistaken...
    Lovely, unmolested vehicle, well done!
    Thanked: 3288
    You'll have to qualify that statement!
    Thanked: 13547
    in my heart and in my opinion
    Thanked: 3288
    Thought so
    But seriously, in this instance the turbo LC 1HDT/FT engines are in a different league.
  12. The Following User Says Thank You to Francois Theron For This Useful Post:
    Thanked: 13547
    Thought so
    Granted, but also really scarce as far as I know.
    Kathu
    Thanked: 2837
    Ja that is a pity that it were only available in SA in the 80 Series. The 1HDT should have been an option in the 70 Series.
  15. #14
    Thanked: 3288
    Not that Td42's are lying around either!
    But yeah the LC turbo diesels are scarce and expensive, even in Oz.
  16. #15
    Thanked: 13547
    TD42s are available from the importers. But yes, getting friggin expensive.
    Sad, really.
  17. #16
    Kathu
    Thanked: 2837
    My against the TD42T is that with the slightest modification you need to drive with your one eye glued to an EGT gauge. I know the guys mod them to serious hp. Thing is you only use max power for as long as EGT stays in check. Being an indirect pre-chamber diesel engine it is understandable. I have a pet hate in regulating engine temp and EGT with the throttle.
  18. #17
    Thanked: 13547
    I'd fit an EGT to any modified turbo diesel, regardless of mechanical or electronic injection.
  19. #18
    Kathu
    Thanked: 2837
    We are going OT. You only have an EGT problem if your AFR is running out of spec.
  20. The Following User Says Thank You to grips For This Useful Post:
  21. #19
    Jul 2018
    Thanks for the advice.
    Going to keep looking!
  22. #20
    Jul 2018
    That's a beaut!
