Garmin trips, waypoints on Google Earth - Missing
Results 1 to 13 of 13
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 1225
    Default Garmin trips, waypoints on Google Earth - Missing
    I could view Mapsource/Basecamp trips and waypoints on Google Earth through the link "View/View in Google Earth."
    Now that facility is gone. I get sent to a dialogue box that tells me to instal Google Earth. I uninstalled G Earth and reinstalled.
    It seems the issue is at Garmin.
    Any assistance from someone perhaps? Please!!
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    BMW R1200GS & GSA
    Okahandja, Windhoek
    Thanked: 812
    Default Re: Garmin trips, waypoints on Google Earth - Missing
    Try having Google running while select viewing in Basecamp?
    Johan Kriel
    LCs, Hilux and Echo Chobe
    Swakopmund
    Thanked: 192
    It was taken out from Basecamp, check Google for the last vesion that supported it... I miss it as well!
    2014 Land Cruiser 76 V8 SW
    1994 Defender TDi 200
    Drive it like you stole it!!
    Jan 2009
    Thanked: 43
    Same problem since yesterday.
    No difference if it is open.
    The word Dzombo is derived from the Tsonga word Dzombolo meaning ‘to wait for something that is slow in coming.
    Named after one of the Magnificent Seven, sadly killed by a Poacher Oct 1995 @ 50 years old.
    Dzombo1 Ex Army LR TD upgraded to 200 Tdi
    Dzombo2 1997 Discovery 300Tdi man
    Dzombo3 2000 Jeep GC 3.0 Diesel a/t
    Dzombo4 2005 Hilux KZTE Legend 35
    Platkar 2017 Fortuner 2.8 4x4 Auto.
    Camping in a Bokwa.
    Okahandja, Windhoek
    Thanked: 812
    Quote Originally Posted by JJ-Namibia View Post
    Mapsource has it still
    Johan Kriel
    Jun 2008
    Thanked: 1225
    Nope
    Not mine. Just checked. The reply in the picture below.
    Isuzu 300 d-tec
    BMW R1200GS & GSA
  7. The Following User Says Thank You to JohanMaree For This Useful Post:
    Klerksdorp
    Thanked: 10
    Johan,
    Ek moet net eers se ek is nie baie kundig op die gebied nie en het maar die kenners se raad op die internet gevolg. Ek het vroeer vandag met n soort gelyke probleem gesit. Ek het basecamp se updates 4.7.1 installeer n geruimte tyd terug en het daarna nie die google earth funksie gebruik nie. Toe ek dit vandag benodig eers gesien dit is weg en is nie meer deel van basecamp 4.7.1 nie.
    Ek het toe basecamp 4.7.1 uninstall en basecamp 4.6.2 installeer wat wel die funksie terug gebring het maar toe ek dit probeer gebruik pop n error venster op wat se indien jy dit wil gebruik moet google earth oop wees. So gemaak, maar dit het geen verskil gemaak nie, die error venster spring nog steeds op. Na n geruime tyd op die internet le die probleem blykbaar by google earth pro. Die kenners se ek moet google earth pro uninstall en oor installeer maar die 32bit. So gemaak, en nou werk myne weer.
    Groete
    Jun 2008
    Thanked: 1225
    Dankie Roes.
    Sal hom more so probeer.
    Mooiaand
    Isuzu 300 d-tec
    BMW R1200GS & GSA
    Gaborone, Botswana
    Thanked: 1120
    When Google Earth Pro was released some years ago, I had the same problem. (For a change the problem was with GE and not Garmin). There was an easy solution, but I cannot remember how.
    Let me ask the interwebs.
    Kobus
    Swakopmund
    Thanked: 192
    Yes, I had to register Google pro earth with a cmd line command, was looking for the non pro vesion of Google earth
  12. The Following User Says Thank You to JJ-Namibia For This Useful Post:
  13. #11
    Gaborone, Botswana
    Thanked: 1120
    Here it is:
    http://www.laptopgpsworld.com/5594-v...-earth-problem
    https://forums.geocaching.com/GC/ind...gle-earth-pro/
    https://support.google.com/maps/foru...%2Fuok8DaHi4FU
    http://forums.gpsreview.net/discussi...ncompatibility
    The bottom line is you must find out where the 'googleearth.exe' file is in your version of Windows. Then do the /RegServer from the command line.
    Kobus
  14. #12
    Thanked: 518
    You can find a work around here (also remember that if you have a GDB/GPX file, you can directly import it into Google Earth): https://www.4x4community.co.za/forum....php?p=3822540
    Google Earth Viewing Problems (2):
    Today, 16 Feb 2018, I picked up the problem again where the "View in Google Earth" function did not work. It says that Google earth is not running or installed. I picked up a post in a Garmin Support forum where they state that this function is no longer working and that one has to export your BaseCamp data and then import it into Google Earth. This is not an ideal situation, but it is one of those thing that we cannot change.
    Your 1st step would be to select your BaseCamp data and then use the export function to export it. This is how it can be done:
    Exporting user data from BaseCampUser data such as routes, tracks, and waypoints can be exported from Garmin BaseCamp to be shared or used with other third-party software. The exported files can also be used as a backup for the user data or a way to transfer that information to a different computer.
    Multiple formats are available:
    * GPS eXchange Format (.gpx)
    * Garmin GPS Database Files (.gdb)
    * Comma-delimited text (.csv)
    * KML 2.2 Document, v2 (.kml) - USE THIS FORMAT FOR IMPORTING INTO GOOGLE EARTH
    * Garmin Training Center XML Document (.tcx)
    * Tab-delimited text (.txt)
    If the data is being exported as a backup or with the intention of reopening it with BaseCamp or another Garmin application, the .gpx or .gdb format would be recommended. The other formats are primarily used if the data is being transferred to a third-party software program such as Google Earth which uses the .kml file format.
    To export user data from BaseCamp:
    1. Open BaseCamp
    2. Select the information to be exported:
    1. My Collection can be selected to export all user data stored in BaseCamp
    2. A specific list or folder can be selected to export only its contents*
    3. Specific items can be highlighted in the lower left pane by clicking a single route/track/waypoint or using CTRL+Click or Shift+Click to highlight multiple items
    Click on the File drop down menuHighlight ExportChoose to export the desired folder/list or the current selectionChoose a name, format, and location to save the exported dataClick Save
    The file containing user data from BaseCamp has now bee exported and saved to your computer. Take note where you save it in order to find it easily for the next step to import it into Google Earth.
    The 2nd step would be to import your saved date into Google Earth. It can be done as follows:
    To import the user data into Google Earth:
    1. Open Google Earth or Google Earth Pro
    2. Click File
    3. Click Open...
    4. Browse to and select the file that was exported using BaseCamp
    5. Click Open
    The data will now appear in Google Earth or Google Earth Pro Places.
  15. #13
    Jun 2008
    Thanked: 1225
    Dankie Daniek
    Ek het hom nou so in G Earth. Net jammer die import/export sal nou elke keer gedoen word, en nie meer die outomatiese kliek heen en weer nie?
    Hoekom is hierdie klomp so blerrie jaloers op mekaar en nie wil saamwerk nie? Ons is mos almal grootmense!
    Isuzu 300 d-tec
    BMW R1200GS & GSA
  16. The Following User Says Thank You to JohanMaree For This Useful Post:
