Freelander II Freelander 2 Turbo? - limp mode issue
Results 1 to 20 of 24
    Default Freelander 2 Turbo? - limp mode issue
    Fellow LR owners,I have a strange problem with my 2013 Freelander 2 SD4 and was hoping for some guidance. The vehicle will drive normally, and maybe after an hour or multiple stops the following happens:
    1. Limp mode...no power even when pressing foot down flat on accelerator. Vehicle will eventually accelerate but no turbo at all..
    2. Worse when there is slight incline or uphill. will eventually move but very slow.
    3. The next day vehicle drives normally with turbo kicking in until it happens again after 1 hour or multiple stops.
    4. No dash error. FL has enough fuel.
    5. Cannot see any issue with cracked or torn booster pipe as some members on FL Facebook group mentioned.
    6. Recently serviced at LR Extreme. IF i am unsuccessful, i will take it back to them.<br>Thanks again.
    Jul 2016
    Thanked: 499
    Default Re: Freelander 2 Turbo? - limp mode issue
    Did the problem start after the service? Most likely the bypass valve in the diesel filter is faulty
    Jul 2008
    Thanked: 18
    My money is in the fuel filter or fuel line connectors at the filter. Sounds like it might be sucking some air.
    _____________________
    Work is to pay for playing
    Quote Originally Posted by MikeBob View Post
    The issue started perhaps 3 months after service. Mostly commute by bike. Not mechanically inclined at all, do i need to take of engine cover to check for the diesel filter\connections? I will check on Youtube, see there are videos
    Thanks, i will check it out...and update post once resolved
    Thanked: 516
    I have been dealing with no turbo in limp mode for over 2 years. It comes and goes and then at times no problem for up to a year. This is on a Freel 1. I do however suspect that it might be the electric fuel pump in my case. Get some diagnostics done as it will give the pump pressure and see if it is within the about 3 bar spec.
    Jul 2016
    Thanked: 499
    There is no pump in the tank supplying the engine in FL2
    Jul 2016
    Thanked: 499
    Quote Originally Posted by Quicksilver View Post
    Yes you do.
    Yes you do.
    There seems to be 4 lines going into the diesel filter. Will check connectors.
    Jul 2016
    Thanked: 499
    Thatís correct. Itís unlikely a connnector. The valve is inside the filter. It regulates the fuel temp going to the HPFP.
    Need to check live values while driving
    Thanked: 516
    Is there no electric pump to supply the high pressure pump?
    Jul 2016
    Thanked: 499
    Nope. There is a pump but only to transfer fuel in the tank
    Kriel
    Thanked: 23
    Pull of the turbo intercooler pipe that goes fro turbo to intake manifold... If there's a lot of oil in the pipe renew the turbo...
    Thanked: 516
    Good.
    I actually did not refer to the tank pump but thought the FL 2 also uses a electric pump as per the FL 1 to supply pressure to the high pressure pump. This pump is in the engine bay next to the diesel filter on a FL 1.
    Feb 2020
    Check the fuel filter when the fuel gets warm it bypasses it back to the tank. They are a consumable. They not included in a normal service. You need a hand pump to bleed the system when you have changed it. If you had a split in the turbo hose you will have smoke.
    Thanked: 236
    On the Si6, there is definitely a high pressure fuel pump in the tank.
    During cranking the pressure is around 42MPa and then drops to 30MPa when the engine runs.
    Had to replace mine twice.
    Johnie
    Volvo XC60 T5
    180kW/350Nm (1500 - 4800 rpm)
    Quote Originally Posted by barryt View Post
    Hi Barry, i checked and the fuel filter was replaced with the 160k km service. I will go back to LRXtreme and have them check the fuel filter again.
    May 2013
    Thanked: 303
    My dad's 2007 TD4 sometimes went into limp mode, especially when you needed some power, i.e overtaking, accelerating hard, etc.
    We feared the worst. Turned out to be a clogged air filter.
    Long shot, but it was the cheapest fix ever.
    Current: 2013 Honda Insight Hybrid CVT
    Ex:
    2005 Volvo XC70 2.5T Geartronic
    SWAMBO: 2011 Volvo XC60 D5 AWD Geartronic
  19. #19
    Good Morning,
    The issue has been resolved. Faulty fuel filter. LRXtreme replaced filter and all is good!
    Thank you for all the inputs and suggestions, appreciated.
  20. The Following 2 Users Say Thank You to Quicksilver For This Useful Post:
  21. #20
    Jul 2008
    Thanked: 18
    Good Morning,
    That is the only thing going wrong on these SD4s. Brilliant little cars.
