Discovery 1 HELP WHAT ARE THESE! Complete rebuild of Disco 1.
Results 1 to 14 of 14
    Jun 2016
    JHB
    Default HELP WHAT ARE THESE! Complete rebuild of Disco 1.
    Hi all,
    Would really appreciate help. Ive just started a rebuild of a 1996 Discovery 1 V8. I do not have a clue what these two objects are for. Please help?
ID:	571624Click image for larger version.
    The picture on the left is on the firewall, passanger side of the vehicle. Does not look like orriginal land rover wiring. Looks like its been butchered.
    Thanks for the help!
    Ps... I'm building the worlds nicest most capable disco 1. I'm not going to spare on quality and cost. Will post regular pics. But need advice as to how to do this? do i start a thread similar to this?
    Thanked: 13556
    Default Re: HELP WHAT ARE THESE! Complete rebuild of Disco 1.
    First one, no idea. Second one looks like a crankcase vapour catch can.
    Thanked: 517
    Quote Originally Posted by Andreamasselli View Post
    Hi all,
    Left is a resistor which could be for LED headlights. Refer to the topic "LED Headlights" in the 4x4 Pub section.
    Thanked: 87
    In My D1 300 tdi I have the same unit as in pic 1 - same place as well
    Also not connected to anything
    So not V8 specific
    If that helps
    Aug 2015
    Thanked: 295
    I think that canister has something to do with fuel venting/purging for the carb (or maybe fuel tank?)
    2007 Disco 3 TDV6 SE
    2007 Fortuner 3.0 D4D
    Cape Town - RSA
    Thanked: 350
    Is the first one not something to do with the radio antennae? Looks a bit like a radio ground.
    Ex - 2005 Cherokee CRD
    Oct 2017
    Kriel
    Thanked: 23
    Hi all,
    Picture 2 is a feul tank ventilation purge canister that connects back the the feul injection system to use the vented gas from the tank...
    Zululand
    Thanked: 79
    Iíve seen power resistors used like that to trick ECU that an electronic shock absorber has been replaced with a manual one. Otherwise the ECU will display a fault. Possible that if itís not for LED light, it could be doing that?
    Magalieskruin Pretoria
    Thanked: 265
    So what have you got planned?
    Stretching the wheelbase?
    Disco 2 differentials?
    Body lift?
    Suspension?
    LS 3 engine conversion?
    In the world of D1 mods you'll have to fork out a very, VERY large sum of money to build the nicest most capable one. I don't want to discourage you, hope you have fun with it.
    Henk
    So understand
    Don't waste your time always searching for those wasted years
    Face up, make your stand
    And realize you're living in the golden years
    Jun 2016
    JHB
    Hi All,
    Thanks for the help. The fuel purge canister is def stock, looks perfect.
    She was a one owner landy, my cousin. He never fitted LED's or anything. Bog Standard. Lots of tampering with over the years though with different mechanics over the country having a go.
    Anyway. I have removed for re-fitment later.
    Thanks all.
    Modjadjiskloof
    Thanked: 145
    Hi all,
    I have a 1996 Tdi and it also has that resistor in the first picture! Also not connected to anything.
    Jan 2019
    Otjiwarongo
    Thanked: 118
    That first picture is definitely a Land Rover Part , But all I can find out that it is part of the (GLOW PLUG TIMER,CATALYST OVERHEAT,DIM DIP SYSTEM & AMP OVERHEAT WARNING ). My Russian stinks so I am not 100% sure.
    1995 Discovery V8 ( Thor intake system , controlled by Spitronics Mercury 2)
    Land Rover 3.9 V8 " Defender 90 " Under Construction
    Hilux 2017 D/Cab 2.8 GD6 ( Company Vehicle)
    Modjadjiskloof
    Thanked: 145
    Quote Originally Posted by JWR View Post
    Interesting! I looked at mine again today after removing my engine. My first assumption that it was not connected to anything, was not correct. It has a proper plug and goes into the wiring harness.
    Ironically my previous Disco didn't have it.
    Jan 2019
    Otjiwarongo
    Thanked: 118
    I have posted the picture on a land rover group I belong to and this is the response I got from a guy in the UK
    "Dim dip for the head lights .....
    When you turn the side lights on it puts a little voltage to the headlights"
    Mine also does not have this !
