Nissan NP 300 2.5 tdi EGR
Results 1 to 7 of 7
    Jun 2016
    Randfontein
    Thanked: 2116
    Default Nissan NP 300 2.5 tdi EGR
    Has anyone blanked the EGR on their 2.5tdi yet?
    Reenen I am sure you have...
    If so where did you put the blanking plate and did you have to do anything else?
    Willie
    2020 Nissan NP300 2.5TDi S/C
    Sep 2012
    johannersburg
    Thanked: 37
    Default Re: Nissan NP 300 2.5 tdi EGR
    Why not just do software and get it deleted their
    ISUZU KB300LX DMAX mine / 1.4tdci with software exhaust and intercooler and watermeth injection /dad-kb300 dteq kb5 4x4 /uncle kb300 4x2 dteq kb5 /step dad. Kb6 kb300 4x4 auto all double cabs
    Strand
    Thanked: 47
    On many you can just take out the arm that connects the solenoid to the actual valve.
    Jun 2019
    Thanked: 18
    I was considering this modification on my 2.5 NP300.
    What are the benefits and risks involved?
    If you decide to go ahead, please post a few photos - will be much appreciated.
    Ellisras
    Thanked: 560
    My EGR got stuck at some point (about 4 years ago)
    With lots of short slow trips the DPF/CAT thing clogged up badly
    Removed the EGR valve and cleaned out the muck causing it to stick, reinstalled
    Removed the manifold portion that contained the DPF and chiseled out the bloody thing inside, replaced without DPF
    No issues since....runs like a steam train
    Thanked: 133
    Don't know if your specific vehicle made excessive smoke. My experiance is that almost all of them do.
    But would you say it now smokes less?
    My NP 300 throw to much smoke for my liking and although NTT Nissan Bloemfontein says it is normal, I suspect the EGR to be the main culprit or otherwise a major contributing factor.
    The vehicle is still under warrantee so I unfortunately cannot touch the EGR.
    Just want to know if blocking the EGR made a difference smoking wise.
    Ellisras
    Thanked: 560
    Quote Originally Posted by Viertrek View Post
    When I had a problem with the EGR it did smoke more and when the DPF clogged it tend to have no turbo boost at all
    Note I only cleaned the EGR valve and replaced it.
    I removed the DPF - since then it does still smoke a little under hard acceleration from standstill (all YD25's do), but once up the revs it does not smoke at all
  8. The Following User Says Thank You to Dungbeetle For This Useful Post:
