1998 Land Cruiser Prado 3.0 KZTE
Results 1 to 19 of 19
    Default 1998 Land Cruiser Prado 3.0 KZTE
    Hi guys
    My mate has a 1998 Land Cruiser Prado 3.0 KZTE auto.
    He is looking for replacement suspension, ball joints etc.
    Which company would you guys recommend to buy or replace these items? OME is to expensive so anything in between worth installing onto a R100K vehicle.
    Then the power. I know there is not much that can be done but, what is a safe modication to try and get some more horses from the engine?
    2016 VW Amarok 2.0 bitdi Ultimate 4motion D/C
    Thanked: 183
    Default Re: 1998 Land Cruiser Prado 3.0 KZTE
    If the car does not have an intercooler, get one from Cirrus Coolers and then take it to Dastek for a Unichip and dyno tune.
    Si vis pacem, para bellum
  3. The Following User Says Thank You to thabogrobler For This Useful Post:
    Apr 2014
    Thanked: 118
    The best money you will ever spend. My KZ-TE runs with a Cirrus and a Dastek chip.
    Robertson/ Larissa, Greece
    Thanked: 3288
    Suspension agents only. No use even looking elsewhere but very expensive. After market parts not worth it.
  6. The Following User Says Thank You to Francois Theron For This Useful Post:
    May 2020
    Craigavon
    Suspension agents only. No use even looking elsehwere but very expensive. After market parts not worth it.
    Hi All,
    Does anyone have experience with Terrain Tamer parts?
    Thanked: 183
    Quote Originally Posted by Jeandup View Post
    Hi All,
    Not personally but they have a VERY good reputation!
  9. The Following User Says Thank You to thabogrobler For This Useful Post:
  10. #7
    Kathu
    Thanked: 2837
    Bearingman also stock ball joints for most vehicles.
  11. #8
    Sep 2017
    Tzaneen
    Thanked: 50
    Balljoints only from toyota for prado 90, i did try pirates and allmost roll the prado because off failure from balljoint.
  12. #9
    Malawi
    Thanked: 1184
    Quote Originally Posted by Vogue View Post
    Hi guys
    Definitely Toyota ball joints, but tie rod ends, steering rack ends etc you can buy quality non OME parts.
    Also shocks. Gabriel safari are cheap and longlasting for that model.
    One of the best mods you can do on the KZ TE is fitting a really wide freeflow exhaust, it might even give you a bit more oooomph.
    Also the Viscous fan will need refilling/replacing by now.
  13. The Following User Says Thank You to tashtego9 For This Useful Post:
  14. #10
    Thank you for the prompt response from everyone.
    Where will the best place be to get a quote for the Gabriel shocks?
    Does anyone perhaps have a workshop manual for these vehicles on PDF, can't seem to find one on the internet.
    From a level from 1 to 10 how much of a hassle is it to rebuild the power steering rack, do I need any special tools?
  15. #11
    Malawi
    Thanked: 1184
    Anywhere, any spares place will be able to get them. Stick with the white Safari ones, don't go for the green ones, forgot what they call them, mine leaked.
    The steering rack, what is wrong with it? If it;s just the play, you can get replacement bushes kits like this one:
    https://www.milneroffroad.com/toyota...02960k/002960K
    If it is leaking from the portion just above where the pinion meets the rack, there is replacement seal kit you can order from Toyota.
  16. #12
    Thanked: 13547
    Quote Originally Posted by tashtego9 View Post
    Here is a ball joint
    here is a tie rod end
    Explain TECHNICALLY what the difference is please?
  17. #13
    Thanked: 3288
    Same design principle in terms of movement. Ball joints connect control arm to wheel hub. Tie rod connects steering rack to wheel hub.
  18. #14
    Thanked: 13547
    yes, well exactly
    How does a aftermarket tie rod end differ from an aftermarket ball joint? Same design principle, therefore the quality cannot be different just because of where it is used? I can't quite understand Tashtego's claim that one is better than the other. And to my mind, a TRE and a ball joint should both be OEM quality or better.
  19. #15
    Apr 2018
    king williams town
    Hi there my name is Brad I would like to give you some advice on suspension parts for your Prado. There is place called Intter Spares. If you Google Intter Spares click on Intter spares online shopping then you will see a catalog you can select and see what all they have for your vehicle.
  20. #16
    Thanked: 3288
    yes, well exactly
    Ball joints on the Prado 90 is known to be a rather weak point, even in OE form. And expensive. So his argument is probably that OE is vital for the ball joints since it is a hight wearing item. TRE's perhaps not to the same degree.
  21. #17
    joburg
    Thanked: 444
    Perfect time to test, replace left ball joint with genuine and right with "quality" replacement part. Drive for 300 0000 and see which lasts better?
  22. #18
    Malawi
    Thanked: 1184
    yes, well exactly
    I know of a couple of cases of people who used NON OME ball joints and they broke again, Catastrophic failure, luckily at low speed. One guy pulling out of a garage. Bent wheel, car cannot be moved. It is a common failure on these.
    The NON OME rack ends and tie rod ends I have used lasted a long time, and, more importantly, their failure is gradual and not potentially catastrophic , like the ball joint one.
    So I would recommend OME ball joints, while I would't be so fussed about the other suspension parts, if he/she wants to save some money.
  23. #19
    Malawi
    Thanked: 1184
    In other words...
