300tdi ticking noise
Results 1 to 8 of 8
    Jul 2015
    Default 300tdi ticking noise
    Hi guys,
    I can hear a ticking noise coming from the engine when going downhill, in gear and foot off accelerator.
    The ticking is not noticeable when stationary and idling (even when revving).
    Any ideas?
    Thanked: 13664
    Default Re: 300tdi ticking noise
    Could be one of the following:
    Exhaust manifold gasket.
    Loose valve rocker.
    Thanked: 88
    Quote Originally Posted by Ro55 View Post
    Hi guys,
    Any ideas?
    When going downhill - no accelerator - no fuel is being injected
    So motor is quieter - so maybe then noise becomes more apparent
    The other option is that your front prop uj is just starting to go - seems unrelated I know but that has happened to me recently
  5. The Following User Says Thank You to RossJ For This Useful Post:
    Nov 2011
    Langebaanweg
    Thanked: 1146
    Could also be the vacuum pump.
  7. The Following User Says Thank You to jfh For This Useful Post:
  8. #5
    Jul 2015
    Thanks for the advice. I'll do a process of elimination starting with the cheapest
  9. #6
    Thanked: 13664
    The cheapest is ignore it.
  10. #7
    Thanked: 17
    Broken valve cap possibly.
  11. The Following User Says Thank You to Ivoryhunter For This Useful Post:
  12. #8
    Jul 2015
    Replaced the exhaust manifold gasket, and lift pump... still ticking.
    Checked for head gasket blowing at the back, and had a look and feel under the valve cover. All seems good.
    I'm going to replace all the u-joints over the weekend.
    Next culprit, vacuum pump? Seems to be leaking a bit.
