Kia Sportage 2011 - battery dead - can't get into car
Results 1 to 17 of 17
    Jan 2018
    CPT
    Default Kia Sportage 2011 - battery dead - can't get into car
    Hi guys,
    My 2011 Kia Sportage .2.0 CRDI has a dead battery, and now I can't even open the car to pop the bonnet open. The car has keyless entry and keyless start so I have a smart key but the key that comes out to open the door manually isn't working either so I can't unlock the car at all.
    Any tips for how I can get the car to open? I thought about removing the splash cover underneath but not sure I'll be able to reach the latch of the bonnet...
    Thanks!
    Swakopmund
    Thanked: 197
    Default Re: Kia Sportage 2011 - battery dead - can't get into car
    Jumper cabels to the starter motor from the bottom to get power in the system?
    2014 Land Cruiser 76 V8 SW
    1994 Defender TDi 200
    Drive it like you stole it!!
    Thanked: 13577
    Yes.
    Quote Originally Posted by JJ-Namibia View Post
  4. The Following User Says Thank You to jelo For This Useful Post:
    Jun 2016
    Randfontein
    Thanked: 2064
    Q20 into the door lock and work it in and out a bit maybe the lock is just a bit sticky
    Willie
    2020 Nissan NP300 2.5TDi S/C
    Thanked: 13577
    Did you actually read the OP?
    Thanked: 431
    2004 Defender 110 Td5
    Dec 2018
    Calitzdorp
    Thanked: 99
    this is why I do not want to have anything to do with a car with all these stupid electronics. They market these cars as if keyless entry is such a wonderful thing. Why on earth is that and who do they fool.
    Imagine this happens to your 4x4 and you're up in the Richtersveld or Northern Mozambique.
  9. The Following 2 Users Say Thank You to AfriqueDS For This Useful Post:
    Bethlehem
    Thanked: 4355
    Quote Originally Posted by Sawdust View Post
    THATS the hassle for me.....your Plan B, your "manual key", doesnt work. Why not?? Is is even the correct Key??
    2008 Mercedes Benz CL 500........................"Bullet" (going....going...)
    2006 Mercedes Benz C 180K........................"Sussie"
    Jun 2016
    Randfontein
    Thanked: 2064
    I did indeed. Those smart keys has a actual key that you can take out and put in the door lock of the car to unlock it manually so if it doesnt unlock the door its probably just a bit rusty/sticky because of not having a key in it for a long time.
    Willie
    Bethlehem
    Thanked: 4355
    Quote Originally Posted by Naweed View Post
    Hi guys,
    Thanks!
    Naweed, I just chatted to a Pal of mine, also Kia Dealer.
    If the "hardware" on that emergency key doesnt fit, that means you got the wrong key from the Seller at the time.......I suspected that, hopefully I'm wrong but I do think that's the problem in all probability.
    Your "fob key" may work, that only means that it's CODED with your car - if the Hardware, the physical "manual" key doesnt fit, then thats the wrong one in the "fob".
    It can happen easily - the wrong fob gets sold with the "correct" (coded) fob, and you carry on like that for years, only to have a problem like you have now if the battery is flat.
    He advises you should call Kia Agent, you may have Roadside Assistance still??
    Good Luck, hope this helps.
  13. #11
    Thanked: 13577
    you'll probably find that there is no actual physical linkage, everything is electrical and all the physical key will do is close an electrical circuit to active the central locking system..........
  14. #12
    Sep 2010
    Brymore, Port Elizabeth
    Thanked: 31
    Toyota has a "double lock" feature. If you lock the car once (from the remote), you can open the door with the manual key. If you press lock twice, the manual key barrel is disabled/ disconnected and then you have a problem if the battery runs flat. Jumper cable on starter sounds like the only solution then.
    Pieter
    2018 Fortuner 2.8 4x4
  15. #13
    Friemersheim, Southern Cape
    Thanked: 3092
    Hi guys,
    Thanks!
    Any feedback?
  16. #14
    Cape Town, Plumstead/The Sea/Franskraal
    Thanked: 554
    Compare the price of a quartelight window glass versus all the other options.
    Have now covered 270 000Km on veg oil.
    Oh, and an Isuzu 280DT, 40 000Km on Bio Diesel
    Rand for Rand gets 33Km/L
  17. #15
    Thanked: 13577
    Quote Originally Posted by ZuluCowboy View Post
    yes, please do: my son did that on his car when he locked the keys inside and the price of the window was way more than a simple locksmith and he would have waited 6 weeks for the window..........
  18. The Following User Says Thank You to jelo For This Useful Post:
    FWM
  19. #16
    Thanked: 554
    It is an option. Check all options.
  20. #17
    Thanked: 219
    THose quaterlights are expensive. It is usually cheaper to break one of the big windows....
  21. The Following User Says Thank You to Wicd For This Useful Post:
