Defender 130 Overlander build - Page 13
Page 13 of 18 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 241 to 260 of 356
  1. #241
    Nov 2006
    Lonehill
    Thanked: 418
    Default Re: Defender 130 Overlander build
    Quote Originally Posted by nedge View Post
    Bruce, if you are talking about the aluminium cover for the box under the rear bench, I have one sitting around doing nothing, which you are welcome to have.
    Drop me a pm if you interested.
    thank you very much Nedge. I donít mean the aluminum cover I mean the actual rubber or carpet that covers the box.
    BruceT
    ZS6EBT
    Defender 130 Puma
  2. #242
    Nov 2006
    Lonehill
    Thanked: 418
    Decided to try out the tent this weekend at a friends property on the Vaal. It was f#%_€* cold. Went down to -4C and with the wind it was not pleasant.
    Roof top tent works well though and was really comfortable. Very easy to set up and pack up.
    Next up is a spare wheel carrier, remap and I need to figure out what is whistling when the motor is hot and after a highway run. It’s related to engine revs as it goes away when the clutch is pushed in. Probably a pulley or something and only does it after driving at highway speeds- heard it loudest at the toll gate. Any ideas?
ID:	579414   Click image for larger version.
ID:	579415   Click image for larger version.
ID:	579416   Click image for larger version.
    BruceT
    ZS6EBT
    Defender 130 Puma
  3. The Following 3 Users Say Thank You to BruceT For This Useful Post:
  4. #243
    Thanked: 408
    Hi Bruce, Your vehicle is really coming along nicely. Can you give us a bit more detail on the inside of the bakkie area please. I wonder what length the Grenadier Bakkie will be. If it came to SA it would be a worthy contender to the 130 you are building up?Thanks for sharing your developments. They are getting filed away for future reference. My son and I are looking for a future project. He has sold the Land Rover 90 that we rebuilt.
    [SIGPIC]MikevR Be determined to live the unlived life within you.
  5. The Following User Says Thank You to MikevR For This Useful Post:
  6. #244
    Mar 2009
    Swakop
    Thanked: 797
    Quote Originally Posted by BruceT View Post
    Itís related to engine revs as it goes away when the clutch is pushed in. Probably a pulley or something and only does it after driving at highway speeds- heard it loudest at the toll gate. Any ideas?
    release bearing?
    "Meerkat"
    slightly modded 02' 105 series 1FZ-FE
    https://www.facebook.com/kepanamibia/
    My heart will always beat to an African drum...
  7. The Following User Says Thank You to AboutAfrica For This Useful Post:
  8. #245
    Nov 2006
    Lonehill
    Thanked: 418
    Don’t think it’s that as when in neutral and rev’ing the motor the sound comes and goes but only when hot. It seems to be rev related and doesn’t change if the clutch is depressed or not.
    There is no noise when normal driving to work or in and around JHB. And when off the highway and driving slowly when all has cooled down it goes away.
    thank you MikevR. What detail would you like? Should I wait until it’s finished or as I progress?
    BruceT
    ZS6EBT
    Defender 130 Puma
  9. #246
    Apr 2009
    Thanked: 244
    @Bruce, I actually had the same thing om my 90, drove me nuts.. turned out to be a small hole in the boost pipe, sounded like a winding/spinning sound, especially louder wen driving past high walls and toll gates with the sound bouncing off it..
    no impact on performance as it was still small.
    D90
    D130
  10. The Following User Says Thank You to D-tox For This Useful Post:
  11. #247
    Thanked: 408
    thank you MikevR. What detail would you like? Should I wait until itís finished or as I progress?[/QUOTE] -----------------------------------I will follow this thread Bruce and let you know - I think wait until project completion then maybe a catalogue by section. By the way on checking the Grenadier Bakkie will have an extended chassis compared to the Station Wagon possibly like your 130.
  12. #248
    Nov 2006
    Lonehill
    Thanked: 418
    thank you. That would make sense. Time for some silicon hoses I think
    BruceT
    ZS6EBT
    Defender 130 Puma
  13. The Following User Says Thank You to BruceT For This Useful Post:
  14. #249
    Nov 2006
    Lonehill
    Thanked: 418
    Fitted the spare wheel carrier today. Now I can take the spare wheel off of the roof
    BruceT
    ZS6EBT
    Defender 130 Puma
  15. The Following User Says Thank You to BruceT For This Useful Post:
  16. #250
    Thanked: 294
    If your solo purpose of this vehicle is overlanding, then a second spare on the roof might need to stay
  17. The Following User Says Thank You to Jakkals. For This Useful Post:
  18. #251
    Nov 2006
    Lonehill
    Thanked: 418
    ‚Äč
    Quote Originally Posted by Jakkals. View Post
    im not sure but will see. I may just carry a tyre
    BruceT
    ZS6EBT
    Defender 130 Puma
  19. #252
    Hermanus
    Thanked: 425
    Is the spare wheel carrier from front runner ? What do you think of quality and ease of opening closing when a spare wheel is on.
  20. #253
    Nov 2006
    Lonehill
    Thanked: 418
    Yes itís a Front Runner.
    Quality looks very good. I will be fitting the wheel to it tomorrow so will feed back then.
    BruceT
    ZS6EBT
    Defender 130 Puma
  21. The Following User Says Thank You to BruceT For This Useful Post:
  22. #254
    Thanked: 90
    this came up on my utube feed
    thought it might be of interest
    https://www.youtube.com/watch?v=jBDGqfsu1_4
  23. The Following 2 Users Say Thank You to RossJ For This Useful Post:
  24. #255
    Apr 2009
    Thanked: 244
    ‚Äč
    +1, also lighter and not too difficult to re-fit.. also, its part of the fun
    D90
    D130
  25. #256
    Nov 2006
    Lonehill
    Thanked: 418
    Haven’t got the spare wheel bolts yet so can’t report back but will ASAP.
    i fitted a Mud center console sub box and some Mud “flares” to the rear bottom of the front wheel arches to reduce spray up the front doors. I also fitted mud flaps to the front.
    mud sub box works out well as it makes the center console the perfect height for an arm rest now.
ID:	579904   Click image for larger version.
    BruceT
    ZS6EBT
    Defender 130 Puma
  26. The Following 2 Users Say Thank You to BruceT For This Useful Post:
  27. #257
    Nov 2006
    Lonehill
    Thanked: 418
    After this weekends short trip I found an oil leak on the turbo oil feed and while looking at that I found that I have a unichip fitted. I donít like the unichip and have had it removed. Canít believe how much better the Landy drives now.
ID:	580097   Click image for larger version.
ID:	580098   Click image for larger version.
    BruceT
    ZS6EBT
    Defender 130 Puma
  28. #258
    Apr 2009
    Thanked: 244
    interesting.... mine also had a uni-chip hidden away that I removed, mine flew like a jet though, was seriously fast probably due to the oversize turbine... it drives like a normal 2.4 now...
    if you suspect the oil feed pipe, then have it check ASAP, as oil starvation will kill the turbo, sometimes its just the copper washers that needs to be replaced (quick add easy fix)
    D90
    D130
  29. The Following User Says Thank You to D-tox For This Useful Post:
  30. #259
    Nov 2006
    Lonehill
    Thanked: 418
    Yes was just the copper washes that needed replacing. All sorted now.
    i actually can’t believe the difference in her now. Hills that I used to have to gear down to 5th on I can now maintain my speed in 6th. Perhaps because it came from Nelspruit it was tuned for the lower altitude?
    anyway, fitted the spare wheel. Only thing I don’t like is the wheel touches the body when fully opened. Will fit a stopper of some sort.
    also the mud flaps work well and reduce the spray onto the doors.
    to add, if anyone is looking at buying or selling a Landy I can not recommend Auto Excellence enough.
ID:	580143   Click image for larger version.
ID:	580144   Click image for larger version.
    BruceT
    ZS6EBT
    Defender 130 Puma
  31. The Following User Says Thank You to BruceT For This Useful Post:
  32. #260
    Nov 2006
    Lonehill
    Thanked: 418
    Anyone interested in my front Bull bar and bumper? Going to be putting it up for sale.
    Will be removing it tomorrow.
    BruceT
    ZS6EBT
    Defender 130 Puma
