Defender 130 Overlander build - Page 9
Page 9 of 24 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... LastLast
Results 161 to 180 of 473
  1. #161
    Nov 2006
    Lonehill
    Thanked: 497
    Default Re: Defender 130 Overlander build
    Yes thank you. *taking a deep breath
    Patience is something Im not very good at.
    I measured everything up this morning and it can work pretty easily without too much work. Basically where it connects to the bin on the sides it needs to be raised 150mm (so the tent can clear the cab's roof), widened 100mm (50mm each side) and the rest will pretty much fit if I take the two boxes (one holds the gas cooker the other is empty) off of the rear.
    I will draw some "plans" up and show you guys what I am going to be doing.
    BruceT
    ZS6EBT
    Defender 130 Puma
  2. The Following User Says Thank You to BruceT For This Useful Post:
  3. #162
    May 2010
    Greenstone
    Thanked: 392
    That sounds easy enough. Keen to see it fitted.
    How would you have mounted it to the 2020 Defender?
    Discovery Sport 2.0i D
    Defender 90 LE Puma 2.2TDCI
    Defender 110 DC Td5 (life partners)
    Discovery 1 200 Tdi Auto
  4. #163
    Nov 2006
    Lonehill
    Thanked: 497
    Quote Originally Posted by Byron View Post
    I would have had to tow it
    BruceT
    ZS6EBT
    Defender 130 Puma
  5. #164
    Nov 2006
    Lonehill
    Thanked: 497
    Ok I think I have worked things out. Please excuse the crude drawings but here is the idea:
    - Canopy needs to be raised 150mm which will give similar clearance to the roof rack from the 130's roof
    - Door will have to be lengthened by around 150mm which is great.
    - the two small boxes at the rear of the canopy will be removed. Only one side is used for a small gas cooker
    - There will be an overhang of around 320mm at the rear, which means the tailgate can be left on and a step of around 150mm will be in front of the door
    - There is more than enough roof in front of the tent to fit a roof rack and carry a spare wheel
    Next thing I would like to do is make it removable, so the canopy will have to be a sealed unit with removable legs.
    Please let me know your thoughts.
    Everything in red is the Landy. Everything in black is the canopy.
ID:	577073   Click image for larger version.
    BruceT
    ZS6EBT
    Defender 130 Puma
  6. #165
    Nov 2011
    Langebaanweg
    Thanked: 1219
    If you space it on the sides, just re-enforce/support the floor to prevent sagging.
  7. The Following User Says Thank You to jfh For This Useful Post:
  8. #166
    I've had this slide on for quite a while. Works well for the wife & I. Went for the dual fold design as this gives you a hard "headboard" on your bed against which to prop your pillow when your reading and also it is a proper length bed (across). Had some dust proofing to do in the beginning but I believe they have changed their design in the spots where I had trouble - may not be a problem anymore.  Geyser, shower, battery, solar, 220 connectivity, etc. all in place. <br><br><br&amp ;gt;
ID:	577084   Click image for larger version.
ID:	577085   Click image for larger version.
ID:	577086   Click image for larger version.
  9. The Following 2 Users Say Thank You to Sam7 For This Useful Post:
  10. #167
    Nov 2006
    Lonehill
    Thanked: 497
    I will also adjust the floor to match so there is no space between the canopy floor and landy's floor.
    Thank you for your reply Sam7. Do you have jacks to lift it and slide it off?
    BruceT
    ZS6EBT
    Defender 130 Puma
  11. #168
    I will also adjust the floor to match so there is no space between the canopy floor and landy's floor.<br>
    <br>
    <br>
    <br>
    <br>
    <br>A frame on 4 height adjustable jockey wheels onto which I pull it with a hand winch and then push into the garage. Use the same hand winch with pulleys to pull back onto the vehicle - one man job.
  12. The Following User Says Thank You to Sam7 For This Useful Post:
  13. #169
    Thanked: 257
    make storage boxes for the sides, and a drawer system bellow the camper for extra space...Click image for larger version.
    D90
    D130
  14. The Following User Says Thank You to D-tox For This Useful Post:
  15. #170
    Nov 2006
    Lonehill
    Thanked: 497
    Nice idea D-tox. Perhaps I can use my Allu-cab drawers as a base, and not lower the door, as they seem very well built - only problem is they maybe too high so will probably have to get someone to custom make something. I need to work it out.
    Here is a very rough drawing of what I have in mind. between the wheel arches it measures 1090mm hence the shape of the base
    BruceT
    ZS6EBT
    Defender 130 Puma
  16. #171
    Nov 2006
    Lonehill
    Thanked: 497
    Did some more work today. Fitted the roof top tent and a snorkel. Do not buy the cheap Defender version itís ### compared to the OEM or mantec
    After lots of filing and making a seal itís on.
    I forgot how much work a RTT is! If I donít end up using the camper canopy I will definitely be buying a hard shell version.
    BruceT
    ZS6EBT
    Defender 130 Puma
  17. The Following User Says Thank You to BruceT For This Useful Post:
  18. #172
    Tzaneen
    Thanked: 315
    The OEM Mantac is much quieter than the other aftermarket one's(on induction noise).Welldone!!
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
  19. The Following User Says Thank You to DiscoFrans For This Useful Post:
  20. #173
    B-gowrie Randburg
    Thanked: 308
    Did some more work today. Fitted the roof top tent and a snorkel. Do not buy the cheap Defender version it’s ### compared to the OEM or mantec
    After lots of filing and making a seal it’s on.
    I forgot how much work a RTT is! If I don’t end up using the camper canopy I will definitely be buying a hard shell version.
    Bruce , I have a very similar though much older Eezi-Awn ... but mounted on my trailer, usually.
    I think next time I put it on my canopy , will buy a separate (additional) telescopic ladder to do the fly-cover and tidy up etc
    If you tie a cord-rope to the ‘axle-hinge’ of the existing ladder it helps as you can use the cord to counter pushing or pulling on the fixed ladder ... if you get my gist , 1 person each side .
    On a 130 canopy with roof-rack the tent floor is at about 2.5m !
    What is the size of your tent floor ... is it 2.2*(1.2*2) ?
    2002 Defender 130 DC HCPU. : Own the road...Any road
    Ď1981 R-Rvr Classic 2-Dr 3.5L V8... The Greatest Rover.
    Ď1975 Series3 88 PUP... Simply Classic...
    Ď2017 Metalian Mini ... A Home from Home
  21. The Following User Says Thank You to BushNomad For This Useful Post:
  22. #174
    Nov 2006
    Lonehill
    Thanked: 497
    Iím pretty tall so donít really battle too much. Only the rod for the window over the bonnet is a problem.
    I also would prefer the tent on the canopy but working alone it was a bit difficult to measure and drill holes.
    its a 1,4 x 2.2 I think. And yes about 2.5 meters off the ground.
    BruceT
    ZS6EBT
    Defender 130 Puma
  23. #175
    Nov 2006
    Lonehill
    Thanked: 497
    Now to vote:
    Front or back? (Back/boost in Black) Iíve tried to make it darker
ID:	577440   Click image for larger version.
    BruceT
    ZS6EBT
    Defender 130 Puma
  24. The Following User Says Thank You to BruceT For This Useful Post:
  25. #176
    Nov 2011
    Langebaanweg
    Thanked: 1219
    Now to vote:
    Wolf.
  26. The Following 3 Users Say Thank You to jfh For This Useful Post:
  27. #177
    May 2010
    Greenstone
    Thanked: 392
    Wolf. I wish my 285s would fit on a wolf rim.
  28. The Following 2 Users Say Thank You to Byron For This Useful Post:
  29. #178
    Mar 2013
    Thanked: 431
    White wolf.
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    LROC member:5881
    -Land Rover Defender 110 Td5
    -BMW F800GS
  30. The Following User Says Thank You to pjf110 For This Useful Post:
  31. #179
    Witbank
    Thanked: 208
    Black wolf
  32. #180
    Thanked: 257
    I have both sets, wolf and boost, boost is much lighter and fuel consumption is better, also, if you have to load the spare wheel on the roof rack (up or down), then boost every day
    D90
    D130
  33. The Following User Says Thank You to D-tox For This Useful Post:
