Defender 130 Overlander build - Page 5
Page 5 of 24 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 81 to 100 of 473
  1. #81
    Mar 2013
    Jeffreys Bay
    Default Re: Defender 130 Overlander build
    Thanks Claude. Didnt know about the EGR cooler. Thank you
    Mine is a 2.4. Same exact model as my old 110. (2011)
    will obviously be doing the rest as was done on my 110. Already spoken to Uncle Peter. Just need to sort out a turbo seal which I can hear blowing slightly, one door is not locking with the central locking and passenger front window is not opening and closing smoothly. Dealership is going to sort all this out as well as fit tyres for me.
    Hi Bruce, I have an EGR blanking plate for you to blank off at the exhaust manifold side of the EGR cooler. Put one on my 2.4TDCI as well. No engine light problems....can't use them on the 2.2's though....they have a different design.
  2. #82
    Nov 2006
    Lonehill
    Thanked: 497
    Quote Originally Posted by VARKIE View Post
    Thank you. Was just going to do it with software, but will look at this. How much would you like for it?
    BruceT
    ZS6EBT
    Defender 130 Puma
  3. #83
    Jul 2010
    Swakopmund
    Thanked: 47
    Bruce on the door that is not locking, check the wires in the tube between the door and B pillar, almost guaranteed its broken.
    Had the same problem on Right rear door.
    DON'T BE AFRAID TO TRY NEW THINGS - AFTERALL THE TITANIC WAS BUILT BY PROFESSIONALS, THE ARK BY AMATEURS
  4. The Following 2 Users Say Thank You to obotha For This Useful Post:
  5. #84
    Thanked: 40
    Quote Originally Posted by MikevR View Post
    Hi Ross - Was this unit not advertised the other day in Autotrader or did you purchase it? I quite liked its layout at the back.
    Hi ... yes it was but I decided I love it too much :-)
  6. The Following User Says Thank You to Ross McLean Calder For This Useful Post:
  7. #85
    Thanked: 40
    That looks like an Oztent permanently fitted to the roof?
    It is an Oztent
    And permanent ... until I want it off :-)
    It sits on a removable foam composite board ... I use the Frontrunner quick release to fix and unfix
    R
  8. The Following User Says Thank You to Ross McLean Calder For This Useful Post:
  9. #86
    Jun 2007
    Gillitts Durban
    Thanked: 57
    I have completely removed the EGR actuator and cooler. Silver soldered a cap (SS welsh plug) onto the old EGR inlet pipe and fitted a blanking plate (Laser cut) on the exhaust manifold side.
ID:	572970   Click image for larger version.
ID:	572971   Click image for larger version.
    1997 Land Rover Defender 90 CSW TDI
    2010 Land Rover Defender 110 CSW Puma
    Echo 4 Off Road Trailer
  10. The Following User Says Thank You to Bernard Burger For This Useful Post:
  11. #87
    Jan 2016
    Golf Park
    Thanked: 218
    Started working on the kitchen. Cleaned and resprayed the inside and started cutting carpet to size. Need supplies so Iím stuck here.
    picture of before and after. (Work in progress)
    Some nice ideas and work going in so far, keep them coming.
    if i may ask, where did you get that foam in the left hand picture, have been looking for something like that in our drawers?
  12. The Following User Says Thank You to Jay_B For This Useful Post:
  13. #88
    Nov 2006
    Lonehill
    Thanked: 497
    Thank you Jay B. I had it cut by sondor a few years ago for my 110. Basically just took them a pattern I had made out of wood and they cut it for me. It needed some adjusting and cutting to fit into this box so I used a hacksaw
    BruceT
    ZS6EBT
    Defender 130 Puma
  14. #89
    Fourways Gardens
    Thanked: 700
    Quote Originally Posted by Bernard Burger View Post
    Very nicely done Bernard.
    Series III 88"
    Scout Nomad
  15. The Following User Says Thank You to ClaudeG For This Useful Post:
  16. #90
    Jul 2010
    Swakopmund
    Thanked: 47
    Quote Originally Posted by Jay_B View Post
    Try these guy. They made mine:
    www.hdfoamsolutions.co.za
  17. #91
    Nov 2006
    Lonehill
    Thanked: 497
    Did a bit more work today.
    - Fitted the FR roof rack water tank and tap
    - fitted spade brackets and spade
    - fitted branch deflectors
    - did some more work on the kitchen. Taking it slow as Iím undecided about the final setup
    - had new tyres fitted to the front
    - replaced the turbo gasket, fixed most of the rattles and squeaks in the cab
    - started collecting bits to redo the entire suspension. So far bought a steering damper, and the terrifirma steering arm kit. I will be upgrading the entire suspension but donít want to lift it.
ID:	573745   Click image for larger version.
ID:	573748   Click image for larger version.
ID:	573749   Click image for larger version.
ID:	573750   Click image for larger version.
    BruceT
    ZS6EBT
    Defender 130 Puma
  18. #92
    Feb 2016
    Thanked: 955
    Bruce, if you don't want to lift it, then get LR heavy-duty coils for the front and airbag helpers for the rear.
    I'd recommend Bilstein or Koni shocks over Terrafirma.
    Or go completely air? http://onairsuspension.uk/4X4-pickup...4x4_130/fa_130
  19. The Following User Says Thank You to Orxy For This Useful Post:
  20. #93
    Nov 2006
    Lonehill
    Thanked: 497
    Thanks Orxy. I already have heavy duty springs but the ride is very hard.
    the air setup looks interesting.
    BruceT
    ZS6EBT
    Defender 130 Puma
  21. #94
    Oct 2007
    Uitenhage
    Thanked: 588
    If you want air contact Gremeltech:
    http://www.airsuspension.co.za/
    They'll have a solution for you.
    2004 Land Rover Discovery 2 VNTd5 ES
  22. The Following User Says Thank You to Fontuin For This Useful Post:
  23. #95
    Nov 2006
    Lonehill
    Thanked: 497
    Mashozi is coming together.
    Fitted a new steering damper. It feels slightly stiffer than the original.
    now I need to make up my mind. Should I fit the boost wheels in black (swambo’s choice) with some decent tyres or keep these?
ID:	573834   Click image for larger version.
    BruceT
    ZS6EBT
    Defender 130 Puma
  24. #96
    Feb 2016
    Thanked: 955
    Why not go halvies and get the steel wheels powder-coated in black or gunmetal/dark grey? ?
    IMHO, it will make a the truck look great!
  25. #97
    Nov 2006
    Lonehill
    Thanked: 497
    Thank you. Thatís exactly what I was thinking of doing. As well as fitting slightly bigger tyres
    BruceT
    ZS6EBT
    Defender 130 Puma
  26. #98
    Feb 2016
    Thanked: 955
    Tyres look like new, rather use this set until they're worn down, then replace? Unless you can trade these in on a new set?
  27. #99
    Fourways Gardens
    Thanked: 700
    Id powder coat the wolf rims. Love that look.
    Series III 88"
    Scout Nomad
  28. The Following User Says Thank You to ClaudeG For This Useful Post:
  29. #100
    Thanked: 2343
    Don't want to be a party pooper, but are you going for looks or practicality? I'd keep the current wheels as is, especially since you've put on new tires up front. Similar for the rest, at first add stuff that enhances drive ability and makes camping trips easier.
