Defender 130 Overlander build - Page 18
Page 18 of 24 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LastLast
Results 341 to 360 of 474
  1. #341
    Thanked: 15068
    Default Re: Defender 130 Overlander build
    yes thank you. I did try this type of cable on my TD5 many years ago, but it started discolouring/turning brown and looked terrible after a while. I could have bought a cheap steel cable instead of stainless, though....... no sure, got it from Builders at the time.
    no, the plastic gets dirty inside and outside and it does look crap eventually, so why not a coloured sleeve and not clear?
    The cable tie idea is cool, although I'm not sure a cable tie will survive in a UV position, my experience is that sunlight kills them pretty darn quick.
    Jakes Louw
  2. The Following User Says Thank You to jelo For This Useful Post:
  3. #342
    Nov 2006
    Lonehill
    Thanked: 498
    Thank you. yes thats true but very little of the cable tie sticks out and if it needs replacing once a year its not a big deal.
    BruceT
    ZS6EBT
    Defender 130 Puma
  4. #343
    Nov 2006
    Lonehill
    Thanked: 498
    Some feedback after fitting only the panhard rod:
    She drives just as well as my 110 did when she was brand new. I’ve always had a very slight shake at between 80 and 100kmh but now nothing. very happy with the result and can only imagine it getting better with the other new rods fitted
    BruceT
    ZS6EBT
    Defender 130 Puma
  5. The Following 2 Users Say Thank You to BruceT For This Useful Post:
  6. #344
    Fourways Gardens
    Thanked: 700
    Thank you. Its a Terrafirma.
    Bruce whats the difference between the standard and Terrafirma? The bushes?
    Series III 88"
    Scout Nomad
  7. #345
    Nov 2006
    Lonehill
    Thanked: 498
    The bushes look like poly bush type bushes and the entire rod is heavier and much stronger. I would say itís probably 3 times the weight of the OEM rod. The OEM rod feels very weak in comparison
    BruceT
    ZS6EBT
    Defender 130 Puma
  8. The Following User Says Thank You to BruceT For This Useful Post:
  9. #346
    Nov 2006
    Lonehill
    Thanked: 498
    First weekend away in Mashozi. We did some bush camping with no facilities at a place in the Magalisburg. Main reason was to try things out.
    i have a list of things I will be changing but overall very happy so far.
    Toilet pic for proof of facilities 😂😂
    here is a short video I tried to make. Didnít take many pictures of videos but itís a start:
    Escape the City
    https://youtu.be/TdsSqWCnZRs
ID:	583773   Click image for larger version.
ID:	583775   Click image for larger version.
ID:	583776   Click image for larger version.
    BruceT
    ZS6EBT
    Defender 130 Puma
  10. The Following 6 Users Say Thank You to BruceT For This Useful Post:
  11. #347
    Nov 2006
    Lonehill
    Thanked: 498
    I forgot to mention. After a long drive I noticed a very slight squeaking noise when driving. It seems to be related to revs. I suspect one of the pulleys maybe tensioner pulley.
    any ideas?
    Here is a video of the setup time. This is at double speed so I would say less than 2 mins to set up
    https://www.instagram.com/p/CDuIig9H...=161flylew6p4v
    BruceT
    ZS6EBT
    Defender 130 Puma
  12. The Following 2 Users Say Thank You to BruceT For This Useful Post:
  13. #348
    Nov 2006
    Lonehill
    Thanked: 498
    Ordered a new belt tensioner, some silicon turbo hoses, new belt as a spare and some wheels. Will share a picture once I have fitted them. Hope the forum approves of the choice
    Next up I need to sort out the kitchen and clothing cupboard. Does anyone know anyone that can assist me with making the clothing cupboard. I have an idea that i need made in metal/aluminium.
    Thank you.
    Last edited by BruceT; 2020/08/12 at 06:50 PM. Reason: Realized I seem to be moaning a bit
    BruceT
    ZS6EBT
    Defender 130 Puma
  14. The Following User Says Thank You to BruceT For This Useful Post:
  15. #349
    Fourways Gardens
    Thanked: 700
    Which wheels!?
    Series III 88"
    Scout Nomad
  16. #350
    Nov 2006
    Lonehill
    Thanked: 498
    All will be revealed once fitted.
    BruceT
    ZS6EBT
    Defender 130 Puma
  17. #351
    Pta
    Thanked: 49
    Where did you get that sparewheel cover?
  18. #352
    Nov 2006
    Lonehill
    Thanked: 498
    Quote Originally Posted by renier_c View Post
    Hi Renier. I got it from Frontrunner
    BruceT
    ZS6EBT
    Defender 130 Puma
  19. The Following User Says Thank You to BruceT For This Useful Post:
  20. #353
    Thanked: 257
    Thank you.
    do you have a rough drawing with dimensions and material thickness?
    D90
    D130
  21. #354
    Nov 2006
    Lonehill
    Thanked: 498
    Quote Originally Posted by D-tox View Post
    I have this picture of what I am wanting to do but need to work out the measurements. I can put a drawing together this weekend. I would like it in metal.
    BruceT
    ZS6EBT
    Defender 130 Puma
  22. #355
    Jan 2016
    Golf Park
    Thanked: 218
    Escape the City
    Hi Bruce,
    Can you share details as to where in Magalies this camp is?
  23. #356
    Nov 2006
    Lonehill
    Thanked: 498
    Quote Originally Posted by Jay_B View Post
    Hi Bruce,
    Hi Jay_B. Its a place called B'sorah. Not much in the way of wildlife but you do hear lots of jackal at night and is a really nice bush setting and easy to get to from JHB or PTA..
    BruceT
    ZS6EBT
    Defender 130 Puma
  24. #357
    Nov 2006
    Lonehill
    Thanked: 498
    This weekend I fitted a spade bracket to the inside of the canopy, sorted out some more leaks in the canopy (will it ever seal?) and started planning where i would fit the drinks fridge. I may not use the drop down option as planned mainly because of the extra weight of building a frame to hold it as well as the fridge, as well as the drop down slide which all seem to be pretty heavy. So I may just fit it to the inside of the front door on the canopy.
    Oh and some packages arrived at the office today - still havent got pricing from the local guy. This is the wheels, silicon boost pipes and new belt tensioner and pully. Will share pictures once fitted. I cant wait for the wheels to be fitted but am not looking forward to the boost pipes.
    BruceT
    ZS6EBT
    Defender 130 Puma
  25. The Following User Says Thank You to BruceT For This Useful Post:
  26. #358
    Nov 2006
    Lonehill
    Thanked: 498
    Fitted the new wheels today. Iím a little undecided. Let me know what you think.
ID:	584798   Click image for larger version.
    BruceT
    ZS6EBT
    Defender 130 Puma
  27. The Following 5 Users Say Thank You to BruceT For This Useful Post:
  28. #359
    Thanked: 418
    Bruce, the rear end looks under strain, A bit weighty. Have you got the correct rear suspension. Nothing worst than bottoming out. Tyres and wheels look great. Maybe the picture is giving the wrong impression. You have really put a lot into this vehicle. Well done.
    [SIGPIC]MikevR Be determined to live the unlived life within you.
  29. The Following User Says Thank You to MikevR For This Useful Post:
  30. #360
    Aug 2017
    Thanked: 307
    Bruce, the wheels look great. Well done going the extra mile to get them!
  31. The Following User Says Thank You to Jakkals. For This Useful Post:
