Defender Using 2nd petrol tank for water tank -smell?
Results 1 to 9 of 9
    Aug 2011
    Napier
    Thanked: 37
    Default Using 2nd petrol tank for water tank -smell?
    Has anyone converted their reserve petrol tank for water storage and if so how do you get rid of the smell and taste of the petrol?
    Babushka - 3.5 V8 Defender Highline
    SWAMBO - 1.6 Nissan Livina X-Gear
    Gaborone, Botswana
    Thanked: 1166
    Default Re: Using 2nd petrol tank for water tank -smell?
    What is the tank made of?
    Kobus
    Mar 2017
    Okahandja
    Thanked: 722
    Get a new plastic tank from Pioneer plastics. Cheap and fast
  4. The Following User Says Thank You to Erwin Schimper For This Useful Post:
    Aug 2011
    Napier
    Thanked: 37
    It is a steel tank and already fitted but I don't use it so I thought it would be good to convert for eater.
    Thanked: 173
    You won't ever get rid of the petrol smell nor the taste from that tank. Safer to use a food grade plastic tank for water.
    Thys de Wet
    Jimny 2009
    Ek het nou klaar gewerk, maar ek weet nie of die bank daarvan gaan hou nie...
  7. The Following User Says Thank You to dewets For This Useful Post:
    Mar 2007
    Harties Boet
    Thanked: 824
    In the defender?
    will be a bit of a mission to modify the tank though. Those defender long range tanks gravity feed to the main tank, and the filling of the main tank goes through the long range.
    2004 Nissan Patrol 4.8
    1999 Nissan Patrol 4.2D
    Aug 2011
    Napier
    Thanked: 37
    My tank is seperate to the main tank - it has a pump and a switch which you switch on to feed the main tank.
    Langebaanweg
    Thanked: 1131
    Quote Originally Posted by dewets View Post
    Listen to this guy.
    It's very very difficult to completely clean a container that was used for fuel.
    '07 Land Rover Defender 110 TDI 300 Kalahari (Meisiekindē)
    King Williams Town
    Thanked: 1094
    Best is burn the tank in a furnace to get rid of contamination, then sand blast in and out of tank. Then get tank coated with some special lining to stop water rusting inside tank. Once you have added up all the costs and time, you could get a stainless steel tank made up for probably 1/4 of the cost.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
