TD5 blowby? - Page 4
Page 4 of 4 FirstFirst 1 2 3 4
Results 61 to 63 of 63
Thread: TD5 blowby?
  1. #61
    Sep 2019
    Thanked: 15
    Default Re: TD5 blowby?
    So both engineering shops got back to me with parts, they both use KS pistons and bearings which from the sounds of it are the right ones to go for. The local store quote really wasn't competitive enough for me to consider it, even though I would like to be able to pop in and see the work so going to go with Remtec.
    Head has been surface grinded (0.05mm) just to clean it and they are resetting the valves so they sit true, which is great that is isn't warped should be receiving the head back shortly. They did say however that 2 of my injectors aren't firing properly and can't be fixed. Can anyone recommend a good place to get reconditioned injectors please?
    Land Rover
    Defender 110
    TD5
    @saffaoverland
  2. #62
    Oct 2007
    Uitenhage
    Thanked: 623
    Unfortunately injectors are either within spec second hand or new.
    Everybody that I have spoken to have said that Td5 injectors can't be rebuilt successfully.
    2004 Land Rover Discovery 2 VNTd5 ES
  3. The Following User Says Thank You to Fontuin For This Useful Post:
  4. #63
    Thanked: 1595
    Speak to Reef fuel injection services in germiston.
    They can apparently repair the injectors.
    Look on eBay.co.uk, there are places that guarantee refurbished injectors.
    I however don't know of anybody who has successfully had them refurbished.
  5. The Following User Says Thank You to NewLandy For This Useful Post:
