Re: TD5 blowby?
A pressure test on the cooling system will tell you if there are external leaks in the system normally. The correct test to check if you have a leaking head gasket is where a sample of the coolant is tested for traces of combustion gasses by adding a chemical that reacts with the contamination. This changes the colour of the sample for a visual indication. It's a quick and easy test that should be done at the same time as a pressure test.
2004 Disco 2 Td5
Suzuki SJ410 (being rebuild)
VW Touran 2.0Tdi
Lotus 7 (replica - not a kit)
