CnC Build
Results 1 to 20 of 22
Thread: CnC Build
    [REMOVED]
    Thanked: 262
    Default CnC Build
    For a long time now I wanted to build a CNC. A while back I started building a CNC but failed and ended up building a 3D printer instead. So now I'm back at it.
    Some goals.
    1. Use components that are very easy to come by.
    2. It has to be scalable.
    3. Must be as cost effective as possible but accuracy and reliability must be acceptable.
    4. Must be low profile.
    5. Must be able to mill wood or Alumenium. (Thought still in progress).
    In the end if it turned out successful I promise to make all of the designs/drawings or what ever else was generated in order to build this available for free. I hope someone is willing to contribute with ideas.
    If you are are familiar machines in the world of open source CNC then the above will scream Shapeoko and XCarve to you.
    Shapeoko
    Xcarve
Name:	xcarve_45angle-5ae5e290cfce25d7bf5c67d846e8540b2d927a23afa0489447521aa816480af6.jpg
    Besides the cost, The problem with these are the components are hard to come by. I.E the Makerslide extrusion which started off as kick starter project is damn near impossible to get locally. And when you do find a supplier there's almost never stock. And you never know if they are legitimate.
    I'm very sure many other people tried what I'm trying to accomplish here but I'm willing to give it a go.
    Maker slide example.
ID:	570485Click image for larger version.
    Note the triangular lips on the top and bottom, You are supposed to run a derlin wheel on as shown in the second photo. There is another option that allows you to bolt a strip that has the lip onto the extrusion. So possibly you can take 3mm alu flat bar (Available from builders chamberlain) and rip it on a table saw at a 45 degree angle. I unfortunatly do not have the equipment for that,.
    Other option is to make use of v-slot profiles.
    The V-slot appeals more to me and is easier to find but most of the time the places where I buy from don't have stock. Sometimes months go by then only do they get stock (Not referring to the current virus situation) They also need Derlin wheels which cost R50 a pop. R1000 easily for the bearings only if you can find them off coarse.
    So before going the Vslot route I would like to explore other avenues. And your input here is very welcome.
    I made the below but I'm not happy with it. It needs both sides to be on a rail otherwise it will derail. I also don't know how well the alumenium angle iron will hold up if you run a bearing directly on it , I think most bearings are made from Chrome Steel. If you ever tried to cut a linear rod made from chrome coated steel with a hack saw you will know what i mean. I'm still willing to try run a bearing on it though.
ID:	570490Click image for larger version.
  2. The Following User Says Thank You to SBSP For This Useful Post:
    durban
    Thanked: 1119
    Default Re: CnC Build
    Would using linear bearings not be cheaper and easier to get.
    [REMOVED]
    Thanked: 262
    Do you mean the below that run on a round bar ?
    The below is an example of an 8UU which runs on a 8MM round chrome rod. Problem with them is they cannot run on very long rail without causing droop in the rail.
    Vertically they are fine but horizontally they also tend to fail easily. You do get half bearings which will run on a rod which you can mount on a flat surface.
    That may also be a good idea.
    I should have mentioned that the one I want to build must be 500mmx500mm. But would like it designed in such a way that you can just exchange it for say 1000mm x 500mm
    Oct 2007
    Thanked: 15
    I am also building a CNC router. I want to do it as cheap as possible by using as much of my scrap material that I have collected over some time. I have converted a milling machine to cnc before and now are using the x and y lead-screws that I have replaced on the machine with ball-screws. For the router's x-axis I need to buy a new lead-screw and I am going to use two 1 m heavy duty slides that I bought some time ago to make a drawer system for my vehicle. They are very heavy and I hope they will work. The z-axis also make use of slides. I made the contraption some time ago to make a drill press for my Dremel tool. See pictures.
    I plan to use three NEMA 23 motors to drive the machine with Mach 3. I would appreciate it if you have suggestions were to buy these plus the rest of the required electronics for a decent price.
ID:	570560   Click image for larger version.
ID:	570561   Click image for larger version.
ID:	570562   Click image for larger version.
ID:	570563   Click image for larger version.
ID:	570564   Click image for larger version.
  6. The Following User Says Thank You to ockert For This Useful Post:
    Dec 2014
    Thanked: 1918
    Look at Rexroth extrusions for your build, they are pretty strong.
    https://www.boschrexroth.com/en/us/p...-framing/index
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 522
    Enjoy, I designed and built a 3000 x 2000 x 300 router.
    Its a very rewarding project.
ID:	570570   Click image for larger version.
  9. The Following User Says Thank You to faniedup For This Useful Post:
  10. #7
    Oct 2007
    Thanked: 15
    That's a monster. Very nice!
  11. #8
    [REMOVED]
    Thanked: 262
    Very Nice!
    Where did you get those thick alu plates ?
  12. #9
    Thanked: 522
    Quote Originally Posted by SBSP View Post
    Very Nice!
    You mean the uprights for the Y-axis? That is moulded carbon fibre parts.
  13. #10
    durban
    Thanked: 1119
    I guess all these cnc builds are really light duty for wood and may struggle with alu. As with any machine rigidity is key and theres no easy way around rigidity but to have lots of metal. And lots of metal is expensive. I wonder if its not better to use an existing machine.
    I am thinking mill so my comment is out of context.As the OP mentions he wants something with a low profile.
    I wouldnt mind building a cnc router if it could help me dip my toes into cnc.
    That big homebuilt router,what is used for the spindle.?
  14. #11
    Thanked: 522
    Its a 1.5kW watercooled motor, vfd and 20000rpm.
    I cut 95% wood/mdf/plastic and the odd profile cuts out of 3mm aluminium sheet.
  15. #12
    durban
    Thanked: 1119
    What kind of chuck system does it use. Is it ER 16 or something like that?Is it three phase. ? What kind of quality does the spindle have on its bearings.?Is that one of the chinese spindles that people have been raving about. The spindle is pretty vital in terms of quality of cut from what Ive read.
    Can it cut alu composite like ibond etc.
  16. #13
    Thanked: 522
    Yes it's Chinese with collets up to 10mm, look at Hobbytronics online website, I bought it from them, works well for my application. Yes it's 3 phase.
    It will cut Ibond no problem.
  17. #14
    [REMOVED]
    Thanked: 262
    I gave up on the idea of using an alternative method for the rails.
    I purchased some 20x20 T-Slots , 20x40 V-Slots extrusions with some delrin wheels. For starters I will 3d print the side plates. Will most probably not provide rigidity. But once I have it right
    I will cut the shapes using 3d printed templates out of 3mm mild steel.
  18. #15
    durban
    Thanked: 1119
    How true are those alu extrusions.In terms of flatness and rigidity
  19. #16
    [REMOVED]
    Thanked: 262
    I believe they are pretty accurate. By design they are very rigid Its all in the shape.
  20. #17
    durban
    Thanked: 1119
    [QUOTE=SBSP;4386875]I believe they are pretty accurate. By design they are very rigid Its all in the shape.[/QUOTE
    Where and how much is it
  21. #18
    [REMOVED]
    Thanked: 262
    [QUOTE=plunger;4386877]
    I usually by from the 3d printing store. Close to work
    20x20 T-Slot R237.00 for 3 metre
    http://www.3dprintingstore.co.za/alu...-slot-profile/
    R477.00 for the 20x40 V-Slot
    If you want to try someone in your valey
    https://www.diyelectronics.co.za/sto...inium-profiles
    I have bought stuff from them in the past
  22. #19
    durban
    Thanked: 1119
    I soppose flat is relative.If you take a lathe and over a meter if it was out by 0,4mm over one meter it would be horribly unacceptable.If it was 0,04mm it would still be bad but usable. I cant see an extrusion being accurate over a meter and being better than cast iron.But if its in wood it may have no bearing on the end product if it has a 0,1mm variation in it.
  23. #20
    Thanked: 522
    It all depends on what you want to do with it. A lot of routers only do profile cutting, for which the flatness is not the end of the world.
    I do a lot of 3d wood machining, for which 0,4mm is also not the end of the world given that you still need to sand the toolpaths out of your product anyway.
    What I have done is to stick a fly cutter into the spindle and face the spoil board after the build to compensate in part.
