Baby Ranger
Results 1 to 4 of 4
Thread: Baby Ranger
    Thanked: 182
    Default Baby Ranger
    Hope SA will also get this.
    Ford's baby bakkie will have rugged look inspired by Ranger, Bronco
    By Motoring Staff 17h ago
    Earlier last year Fordís global markets President Jim Farley confirmed that the company was working on a new compact pick-up truck that would slot beneath the Ranger, and now some new details are starting to emerge.
    For starters, bakkie fans can look forward to a rugged design.
    MotorTrend says its sources have indicated that the newcomer will be ďanything but cuteĒ, with styling inspiration likely coming from both the Ranger and the upcoming Bronco Sport SUV.
    The latter is not to be confused with the actual Bronco, which will be a more rugged Wrangler-like SUV based on the Ford Ranger. The Bronco Sport will instead use Fordís compact front-wheel-drive architecture that underpins the new Focus and Kuga models that have not been launched in South Africa. This means it will also be fairly closely related to the upcoming compact pick-up and the two could even be built in the same Mexican factory, MT reports.
    Itís practically certain that the vehicle will be offered as a double cab, but itís not yet clear whether single and extended cab variants will form part of the mix.
    According to the aforementioned US publication, the baby bakkie will also likely share its two turbopetrol engines with the Bronco Sport, these being a 134kW 1.5-litre three-cylinder and 186kW 2-litre four-cylinder.
    Being a unibody bakkie, there wonít be a traditional 4x4 system with low-range, although range-toppers will almost certainly offer the option of permanent all-wheel-drive.
    Itís too early to say whether the newcomer will ever reach South Africa, but it would be a travesty if it didnít. The vehicle is likely to be primarily aimed at South American markets, where it will go up against the Fiat Toro and Volkswagenís upcoming Tarok.
    Oh, and Ford hasnít given it a name yet, but the Courier name (which SA got to know through a badge-engineered Mazda) has been bandied about by a number of publications. We sure hope that isnít the case as a rugged-looking bakkie thatís presumably aimed at the leisure market should not have a name like Courier.
    "The whole problem with the world is that fools and fanatics are always so certain of themselves, but wiser people so full of doubts" : Bertrand Russell
    2014 Nissan Navara 2.5 4x2
    1995 Nissan Sani 3.0 V6 4x4
    Jun 2016
    Randfontein
    Thanked: 2064
    Default Re: Baby Ranger
    Id like this
    Willie
    2020 Nissan NP300 2.5TDi S/C
    Oct 2019
    Birchleigh
    Thanked: 50
    Bantam, pleeeease!
    Skihili
    2019 Ford Ranger 2.2 DC 4x4 Auto
    Old school. QL is not an instructor.
    Thanked: 13577
    Will be a standard bakkie size, the Americans consider our bakkies small.
