Fix Dewalt Radial arm saw Yolk - Powershot 7740
Results 1 to 4 of 4
    Mar 2020
    Thanked: 9
    Default Fix Dewalt Radial arm saw Yolk - Powershot 7740
    Hi
    Ive been having trouble setting my arm saw , and found that the yolk does not clamp firmly to roller head. i have played with the star shaped adjuster, but no joy.
    So i want to remove the yolk from the head and inspect the 2 mating surfaces.
    does anyone know how to disassemble the two parts ?
    2001 Defender 90 TD5
    Friemersheim, Southern Cape
    Thanked: 3253
    Default Re: Fix Dewalt Radial arm saw Yolk - Powershot 7740
    You have to remove the switches in front from the arm.
    Then the whole roller head and yoke comes out
    Remove motor and then it is easy to remove yoke from rollerhead
    Edit: then King Bolt can be removed
  3. The Following User Says Thank You to Prof For This Useful Post:
    Mar 2020
    Thanked: 9
    thanks for the reply
    my king bolt was welded in,
    after grinding it lose i was able to take things apart
    the adjusting star was broken wick enplane why it did not help
    think the easiest thing is to make a 6.5mm Allen key and adjust from the bottom every now and again when things get lose
    Thanked: 3253
    Quote Originally Posted by phhenning View Post
    My star adjuster is also damaged and locking mechanism works, but after while all is too loose to work properly.
    Then I use allen key to tighten up from bottom as you mention.
    Different model mine, but mechanism is the same
    Glad you got sorted
