Any tricks to lube the clutch plate splines without taking out the gearbox? - Page 2
Results 21 to 40 of 46
    Cape Town Southern Suburbs
    Thanked: 1123
    Default Re: Any tricks to lube the clutch plate splines without taking out the gearbox?
    Question, if a clutch plate spring breaks, what are the symptoms
    If I remember correctly judder, the clutch takes sharply, vibration, noise.
  2. The Following User Says Thank You to Skylark For This Useful Post:
  3. #22
    Robertson/ Larissa, Greece
    Thanked: 3289
    I cannot see any way that the splines can be lubricated where the clutch plate moves on the splines.
    And even if you do by some miracle manage to do it, I very much doubt it will make any difference. I suspect you have a faulty clutch.
    Please, whatever you do, please report back. I'd be keen to know the outcome.
    Good luck!
  4. #23
    Thanked: 2837
    Like 3bar said there is not much movement of the clutch plate on the splines. The release bearing slides on the sleeve that is where you have movement.
    Oil grade like Wiel said can have the same symptoms
    I will go with a sticky slave or master cylinder like others said in the thread.
  5. The Following User Says Thank You to grips For This Useful Post:
  6. #24
    Thanked: 1123
    You guys are steering me in this direction, how do I identify/troubleshoot a sticky slave or master cylinder?
  7. #25
    May 2016
    Thanked: 3036
    It is easy enough to recondition both.
    Even if it turns out not to be the main problem, it will be money well spent.
    I personally think you have a failing pressure plate.
    2006 VW Touareg V10 TDi
  8. #26
    Dec 2011
    Thanked: 2438
    Start by flushing the clutch fluid
    Then change the master and slave
  9. #27
    Thanked: 1123
    I'll start by flushing the fluid, easy and cheap, it was last done about 2yrs ago.
    I'd still like to hear what symptoms I can look for to diagnose a failing master or slave cylinder?
  10. #28
    Dec 2011
    Thanked: 2438
    If a problem can not be absolutely diagnosed I like to start with the cheap and simple.
  11. The Following 2 Users Say Thank You to MariusFourie For This Useful Post:
  12. #29
    May 2016
    Thanked: 3036
    Most failures would result in a 'soft' pedal, or the pedal needing to be 'pumped up'.
    If the pedal is firm and holds its firmness, the hydraulic servos are most probably ok.
    I cannot think of a mode of failure that would cause 'dragging' of the clutch.
  13. The Following User Says Thank You to 4eTouareg For This Useful Post:
  14. #30
    Thanked: 2837
    Quote Originally Posted by 4eTouareg View Post
    I have experience of two such cases. One were someone put contaminated brake fluid in the system causing the clutch master and slave cylinder rubber seals to swell. Other one were rust deposits in master cylinder.
  15. #31
    Thanked: 1123
    By dragging I mean the clutch plate does not fully release when the pedal is pressed to the floor, it very slightly drags on the clutch plates and causes the gearbox input shaft to turn and hence make gears very difficult to shift.
    My pedal is firm and always holds it's firmness, which is why it's hard to fault the hydraulic system.
    Were your 2 cases also temperature dependent?
    I would have thought a sticky cylinder would cause clutch slippage even when the pedal is fully released because the cylinder would not return fully. And also some fluid loss would be apparent which I have not had.
  16. #32
    Thanked: 13556
    It isn't the splines.
  17. The Following 3 Users Say Thank You to jelo For This Useful Post:
  18. #33
    King Williams Town
    Thanked: 1087
    Maybe adjust your clutch peddle to push further in ie more travel
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  19. #34
    cape town
    Thanked: 161
    confirm slave cylinder travel is within spec and that travel is not sluggish.
    check peddle free-play; its a long-shot but a quick and easy check.
    The clutch drags when pushed in for the first few km and then it's fine, it makes changing gears very difficult if not impossible, it also randomly happens at any time when trying to change gears when the vehicle is at a standstill.
    when this happens with the vehicle in gear, at standstill and clutch disengaged does the vehicle tend to want to move forward ?
    jack a rear wheel off the ground, chock front wheels and repeat the test. in gear and with clutch disengaged you should be able to stop the rear wheel with your foot on the side of the tyre.
    perhaps its not the clutch but an intermittently hard shifting gearbox.
    hope this helps, good luck
  20. #35
    Thanked: 2837
    Sorry misunderstood they way your clutch drag. I am with Wiel oil weight that is not to spec have the effect of dragging and heavy shifting when cold.
    Also with RussellF on paddle and slave travel distance specs. I would check and adjust first.
  21. #36
    Gaborone, Botswana
    Thanked: 1161
    I had something similar with my D21 Nissan. The seals on the piston in the master cylinder was on its way out. When you press the pedal, some of the fluid will bypass the seals and you do not get the full movement you need to disengage. In the beginning it was random but later on it happened all the time. New kit (piston, seals, little spring and dust cover ) for both the master and slave, new fluid and problem solved.
    Kobus
  22. The Following User Says Thank You to KobusDJ For This Useful Post:
  23. #37
    cape town
    Thanked: 161
    even with the clutch fully engaged its possible to change gears.
    plenty years ago and more than 10km from home I had an issue with a suddenly leaking master cylinder or collapsing firewall, I don't remember which exactly.
    was able to drive home thru all the gears without any clutch by slacking off on the accelerator slightly before gear changes, gearbox synchromesh did the rest.
    am relating the story to show that difficult gear changes may not be clutch related.
    I'm sure many others have similar anecdotes ...
  24. #38
    Nigel
    Thanked: 2284
    I didn't read all, but let me just drop my opinion.
    The splines are used for maybe 1mm. When the pressure plate is released, the clutch might move 1 or 2mm.
    Where there is travel is on the release bearing, on the collar around the main shaft.
    But all this being said, I have found that when the clutch starts acting up. Going stiff, not releasing, there is a failure. Be it hydraulic or mechanical.
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
  25. #39
    Thanked: 1023
    As many said its definitely not lubrication on the splines.
    I only 2 see possible root causes for a dragging clutch
    1. Clutch/pressure plate on the way out and thus not releasing properly
    2. spigot bearing dragging causing the input shaft to turn despite clutch releasing
    Either way its a gearbox out job to fix
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
  26. The Following 2 Users Say Thank You to mullerza For This Useful Post:
  27. #40
    Wartburg.
    Thanked: 606
    Like the rest of the guys said, your clutch is on it's way out I recon.
    Just drop the box and do it properly.
    You will most probably find that when you do take it out you will be surprised to see how little clutch is left!
    When last was that clutch done, and what sort of work has the vehicle done with the current clutch in it?
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
