Rusty fuel tank
Results 1 to 10 of 10
Thread: Rusty fuel tank
    Jan 2018
    Default Rusty fuel tank
    Morning I have a older Pajero and the tank (diesel) has rust issues. Many years ago I had my LR petrol tank lined by a company in Jhb which was very successful. Sadly it was so long ago I cant remember who they were.
    Does anyone know if there is still someone doing this and can it be done with a diesel tank?
    Thanked: 13556
    Default Re: Rusty fuel tank
    Approach one of the local boat repair companies, I'm pretty sure they can either repair or build a replacement. Stainless steel would be best.
    Wilderness
    Thanked: 1170
    Silverton Radiators.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Thanked: 967
    Dec 2014
    Thanked: 1836
    There is a guy in Paarden Eiland that does tanks, I can't think of his company name right now, but I can find out if you want me to.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 114
    Pretty useless info if it is not available in SA.
    Kathu
    Thanked: 2837
    My experience with rust in tanks. Most fixes are temporary. Chuck it and get another one either new or good secondhand.
  8. The Following User Says Thank You to grips For This Useful Post:
    Bellville
    Thanked: 161
    Absolutely!
    Years ago had an older Alfa tank done here in CT. At first everything was OK, but a few months later I started to get a fuel starvation problem. Traveling between Stellenbosch and Bellville along the Bottelary road, the car would start spluttering almost at the same place, then die completely. You then had to wait for five minutes, start up again and drove the rest without any further incident. After having checked tank ventilation, disassembling and cleaning those twin Webers twice, I found an obstruction in the fuel line about halfway to the tank. The obstruction was a "sausage" comprised of compacted thin leafs of dislodged tank lining material which collected over time at a nick along the metal fuel line! It would let the fuel through for a while, but would then eventually become a solid plug preventing fuel flow. Switch the car off and test delivery at the engine, no problem, but drive it continuously for a while, and you have problems.
    So I tend to agree with Grips on this matter ...
    2011 Pajero 3.8 GLS LWB
    1996 Conquest 160i RS
    Nov 2011
    Langebaanweg
    Thanked: 1124
    An old toppie that worked with me did wonders when restoring vehicles.
    First he will fill the tank with phosphoric acid, this eats away the rust and leaves a protective layer.
    This is the part that takes time.
    After that the tank is flushed and dried.
    Then he threw, what we call syrup, in the tank and rolled it in all directions for hours.
    The syrup was a aviation fuel tank sealant. Expired stock.
    Always had success with this technique.
    Thanked: 439
    Mike at EC Radiators
  12. The Following User Says Thank You to GaryFrank For This Useful Post:
