Things to do on an Amarok
Results 1 to 15 of 15
    Krugersdorp
    Thanked: 147
    Default Things to do on an Amarok
    We bought an Amarok BiTDi Auto with just over a 100,000km on the clock a month before the lockdown.
    To date I have done the following:
    - Service
    - Cambelt and waterpump
    - Front discs and pads
    Things I still want to do once the lockdown is over:
    - EGR
    - Catalytic converter
    - Shocks
    - Gearbox oil change
    Is there anything I missed that I should consider looking at at this stage?
    As an aside, as stated I have already planned to replace the shocks as I am not happy with them, but just out of interest, do these shocks look like they might still be the original shocks?
Name:	Amarok Shocks Front.jpg
Name:	Amarok Shocks Rear.jpg
    Mar 2017
    Okahandja
    Thanked: 722
    Default Re: Things to do on an Amarok
    That looks stock. I installed Bilstein B6 with a 30mm lift from Mikem.Click image for larger version.
    Dec 2018
    Thanked: 20
    Awesome maintenance you are doing and after all this work.
    It should drive like a new car.
    May 2016
    Mossel Bay
    Thanked: 23
    Hi,
    Did you do the gearbox oil change yourself?
    Oil you used?
    Mine is almost on 140k and I am looking after it wrt maintenance and preventative maintenance , next I want to do is the Gearbox Oil.
    VW says it has lifetime oil in it, what is your take on that?
    2014 AMAROK 4MOTION
    2014 BUSHLAPA 350 MISKRUIER
    Thanked: 2444
    Quote Originally Posted by Voetpomp View Post
    Hi,
    Oil you used?
    Warranty lifetime
    Tshwanetoria
    Thanked: 749
    Look out for the ZF specials on oil changes. I would rather them do it.
  7. The Following User Says Thank You to hatjohan For This Useful Post:
    Krugersdorp
    Thanked: 147
    Hi,
    Oil you used?
    That is on the to-do list. The lockdown go in the way.
    My plan is to take it to ZF and let them do the oil change.
    Look, I know what the manufacturers say, but as a mechanical engineer there is just no way that I would expect a piece of mechanical equipment to work for years and thousands of cycles without any maintenance. Why should I expect different from my vehicle's gearbox?
    Personal choice, but something that is non-negotiable for me personally.
  9. The Following User Says Thank You to JS-V8 For This Useful Post:
    Krugersdorp
    Thanked: 147
    Quote Originally Posted by Unobeat View Post
    Thanks. Must say, I am very surprised at the overall build quality of the vehicle, not a single rattle in the vehicle.
    Krugersdorp
    Thanked: 147
    Thumbs up Re: Things to do on an Amarok
    Jip, that is my plan.
  12. The Following User Says Thank You to JS-V8 For This Useful Post:
  13. #10
    May 2016
    Mossel Bay
    Thanked: 23
    Quote Originally Posted by JS-V8 View Post
    Thx for the reply,
    My sentiment is the same, cannot see how oil can last a "lifetime".
    Think of a Amarok with 250k on, can you imagine the amount of cycles that went through!!
    2014 AMAROK 4MOTION
  14. #11
    Mokopane
    Thanked: 230
    Check the EGR cooler and if fine, replace around 150 000kms.
    Die reŽn is 'n dag nader as gister.
  15. #12
    Jan 2007
    Thanked: 325
    I'm also planning on doing the gearbox oil soon (on 126K km now). I've already had to replace the EGR cooler (should have blanked it off...)
  16. #13
    Krugersdorp
    Thanked: 147
    Any thoughts on oil replacement on other items (other than gearbox) such as diffs etc?
    When should this be done?
  17. #14
    Krugersdorp
    Thanked: 147
    - Service
    - EGR
    - Shocks
    Just an update, the following has now been done:
    - Shocks replaced with Bilsteins
    - Gearbox and Diff oil changes done
    - EGR removed and blanked
    - Cat removed and replaced with downpipe
    - Powder coated intake pipe fitted
    The last three were all done by John from G-Fab. Very happy with the work and results!
Name:	Amarok 1_Copy.jpg
ID:	576152Click image for larger version.
Name:	Amarok 2_copy.jpg
ID:	576153Click image for larger version.
  18. #15
    Thanked: 936
    I have been using ravenol. I am trying to recall, but i think i do it every 80kish or so when I do the cam belt .
    I spoke to James and he hooked me up with everything.
    I do,
    RAdiator Fuild
    Brake Fluid.
    Front and Rear Diffs. (They use different oils)
    Transfer Box
    Gearbox.
    Ravenol can supply you with everything including the oil pump.
    Front diff is a pig. You may need to modify an allen key to get the fill cover off.
    On shocks I also did Bilstein from Mikkems. THAt was around 200k km back and still happy.
