CJ2A build with a difference
Results 1 to 6 of 6
    Nigel
    Thanked: 2282
    Default CJ2A build with a difference
    I am busy with a CJ2A, that is to be a nice driver/toy. Not a authentic vehicle.
    So I have a pretty butchered chassis, but totally usable.
    New re-manufactured body panels.
    So now the piece I presume you guys will frown at
    Land Cruiser 4spd H50 gearbox and transfer.
    D4BB H100 Hyundai engine.
    Original diffs, but with LR discs in the front.
    It must look nearly authentic, but be a friendly driver.
    My question.
    I am collecting spares. Looking at using a Toyota Hilux pedalbox and booster.
    Looking for a 6 unit gauge set.
    Speedo
    Rev counter
    Fuel
    Temp
    Oil
    Probably volts
    Where do I start?
ID:	568853   Click image for larger version.
ID:	568854   Click image for larger version.
ID:	568855   Click image for larger version.
ID:	568856   Click image for larger version.
ID:	568857   Click image for larger version.
    Uniglide
    +27 zero eight 2 four 95 9252
    Thanked: 965
    Default Re: CJ2A build with a difference
    Nice fun project.
    I would have thought loose gauges would be the way to go?
    Nigel
    Thanked: 2282
    Nice fun project.
    Yes, I do want loose gauges. But I want electric/electronic gauges. Something that I can calibrate.
    But they must look Old School. Something like this even, but in km/h
    Uniglide
    Thanked: 965
    Hmmm.
    http://www.autometer.co.za/
    But you've probably done that already too hey?
  5. The Following User Says Thank You to Peter Connan For This Useful Post:
    Nigel
    Thanked: 2282
    Hmmm.
    $500 and up. And I don't know how they will handle rain.
    Will probably make some kind of little drop down shield, but it will be at Hillcrest, in Kzn. Humidity and salt.
    Uniglide
    Thanked: 965
    They say beggars can't be choosrrs. Even basic Instruments are flippin expensive. I paid nearly R2k for a VDO boost gauge last year.
    I'm not sure how much room you have behind the dash, but I have in the past bought an air filter housing for a longish flat filter at a scrapyard, cut the lid open and fibre-glassed that to the back of an instrument panel, th3n fibreglassed the air outlet tube closed and mounted a few glands in it and used that to protect instruments. It worked very well.
