LC 80... How about a Cummins 2.8 TB4
Results 1 to 20 of 28
    Jun 2019
    Horsholm
    Default LC 80... How about a Cummins 2.8 TB4
    I have seen quite a few clips on YouTube.
    There Cummins has developed a new engine kit.
    You get the whole shabang in a cradle and shove it into your cruiser.
    Anyone have a Cummins in there cruiser?
    If not what diesel conversion do you do?Click image for larger version.
    Thanked: 1184
    Default Re: LC 80... How about a Cummins 2.8 TB4
    1HDFTE with a 1 HDT diesel pump..... Henri will be here soon.
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
  3. The Following User Says Thank You to Uys For This Useful Post:
    Jun 2019
    Horsholm
    I dont know all the codes...
    That is?
    Mar 2015
    Thanked: 285
    I saw a US price for a complete conversion of $40,000. Not worth it for that price, then again there might be cheaper options for the same conversion Click image for larger version.
    Jun 2019
    Horsholm
    Definitely on the heavy side
    Quote Originally Posted by Tom13 View Post
    Robertson/ Larissa, Greece
    Thanked: 3289
    Quote Originally Posted by RichisAfrika View Post
    That is?
    1HDT is a 12 Valve turbo engine with mechanical pump. 1HD-FT is the same engine with 24 v. 1 HDFTe is the 24 Valve with electronic injector pump. The best range of engines for the Cruiser Toyota has built in my humble opinion. All diesel straight sixes
  8. The Following 5 Users Say Thank You to Francois Theron For This Useful Post:
    Swakop
    Thanked: 738
    Agree, and the 1hd-fte with a intercooler does some decent power, they used them in the 100 series cruisers. In australia the guys like putting that motor in 79's, 80's, 105's etc. If well looked after those engines are very reliable.
    Obviously I have to add that the 1fz-fe needs to be added to your list of best cruiser engines.
  10. The Following User Says Thank You to AboutAfrica For This Useful Post:
  11. #8
    Kathu
    Thanked: 2837
    The Cummins 2.8 looks great on paper. One of my biggest disappointments when I first had a drive in a vehicle fitted with one. You read about them in builds on forums, everyone rave about them but really it failed to impress me.
    Spending a R100k plus on a conversion in which you compromise reliability is not worth it.
    What is wrong with the engine of your Cruiser ?
    If fuel consumption is your headache get something like a D4D Hilux.
  12. The Following User Says Thank You to grips For This Useful Post:
  13. #9
    Nigel
    Thanked: 2284
    No contest.
    If I might add. I have done 370,000km with mine. Same injectors. Same turbo. Not using a drop of oil.
    I will take it to Cairo, NOW...
    Uniglide
    +27 zero eight 2 four 95 9252
  14. The Following 2 Users Say Thank You to Henris For This Useful Post:
  15. #10
    Bethlehem
    Thanked: 296
    The problem with the 12 and 24 Valve engines are to get Toyota spare parts and the price if you can get . Engines are discontinued except for the 1HZ 4.2
    OK it is a donkey , but a very reliable donkey and engine & parts will be available for a very long time .
    Cruiser 76 EFI 4.5 FullTime 4x4
    Cruiser 78 4.2 Diesel
    Cruiser 79 4.2 Diesel Full Time 4x4
  16. #11
    Thanked: 3289
    Quote Originally Posted by Swart Jan View Post
    Agreed. I still do not understand Toyota's approach with these engines. Here, in Australia and even in the USA these engines are recognised to be some of the best engines to fit to a big 4x4. Yet Toyota was seemingly very reluctant to fit them to too wide a range of engines and finally did away with them. I am sure if they take the 1 HDFTe, make it common rail and apply some modern engine management it will run with the best available today.
    Incidentally, the 1 HDFT is also available as a marine application under the Yanmar brand
  17. The Following 2 Users Say Thank You to Francois Theron For This Useful Post:
  18. #12
    Postmasburg
    Thanked: 253
    So Yanmar still make the 1HDFT?
  19. #13
    Thanked: 3289
    Quote Originally Posted by Mapog View Post
    Not sure. It was also sold as a Yamaha marine engine.
    https://www.yanmarmarine.com/Product...6LPA-STP2-342/
  20. #14
    Postmasburg
    Thanked: 253
    Die Yanmar maak aansienlik meer krag uit die enjin as Toyota?
  21. #15
    durban
    Thanked: 1056
    Why is it that I think the 2,8 cummins is chinese made and had piston issues. ?Am I spreading fake news.
  22. #16
    Thanked: 3289
    Tipies Toyota is hulle baie down rated in die Cruisers. Daai enjin het bitter baie potensiaal
    Cummins has huge manufacturing facilities in China. Many of their engines are built there but to their spec and quality obviously.
  23. #17
    Postmasburg
    Thanked: 253
    If I were to go Cummins, there are way better options than that 2.8.
    If a 6bt would fit, that would be number 1, if not 4 bt turbo.
  24. The Following User Says Thank You to Mapog For This Useful Post:
  25. #18
    durban
    Thanked: 1056
    Ah ,it wasnt the pistons it was the cylinder walls.It looks like a nice engine to me.
    I think they are good but depends in which factory it was built.
    https://www.google.com/search?q=2.8+...hrome&ie=UTF-8
    HaHa here is a post i did in 2013 asking how one would be for my jeep.The internet is an amazing thing.
  26. #19
    Kathu
    Thanked: 2837
    Thanks Francois never too old to learn. When I researched engines for the F250 I saw many references to the Yanmar/ Yamaha Marine diesel engines but never know they were copies of the 1 HDFT. Seems that the Marine version made around 200kw. You will need to spend big money on a Cummins 6BT to get it into that league.
    Off topic.
    Interesting as I were looking at a Ford 2704E Marine engine turbo diesel 5.9l 186kw and 726nm for the F250 build. Impossible to find in SA. Could only get a non turbo version from a Fishing Trawler. The turbo version were also used in some Ford Cargo trucks.
  27. #20
    Okahandja, Windhoek
    Thanked: 850
    You use to get those Toy engines in the bigger forklifts also .
    Johan Kriel
  28. The Following User Says Thank You to JLK For This Useful Post:
