Mampoer ketel - Page 18
Page 18 of 19 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 341 to 360 of 378
Thread: Mampoer ketel
  1. #341
    Oct 2006
    Melkbosstrand
    Thanked: 894
    Default Re: Mampoer ketel
    Are you going reflux on your first run?
    No.
    Really just built the reflux extension with leftover tubing and fittings I had already to keep myself busy and to see if I can.
    Will most likely build a 28mm or 35mm column similar to this one at some point.
  2. #342
    durban
    Thanked: 1178
    What are you using to drill. A holesaw?
  3. #343
    Oct 2006
    Melkbosstrand
    Thanked: 894
    For those a hand drill and step drill bit.
  4. #344
    Richardsbay, KZN
    Thanked: 15529
    Quote Originally Posted by ColeGP View Post
    There is a possibility that the reflux pipes may cause a restriction on your main column as its a pretty small pipe you used, only way to know for sure is to test it.
    A test for the column to judge obstruction ( if one wants to see if you inserted too many scrubbers) is to try breathe through it, if that can be done it should be ok.
    But as you say Cole, Kola must test it as each setup has it's own idiosyncrasies.
    Walker Evans, Photographer
  5. #345
    Oct 2006
    Melkbosstrand
    Thanked: 894
    So curiosity took over yesterday and I put about 6 litres of a sugar/potato wash through the still.
    It fermented from last Wednesday to Monday, SG was .990 with an OG of 1.070.
    Still ran well, with a few things I learnt on the first run.
    - My gas cooker is a bit hot, will do the next run with a gas simmer plate to give me a bit more control.
    - My condensor pump needs a control valve, water flow with the pump at its lowest setting is still to high for most of the run (expected this, valve will be added before next run).
    - No cuts, just a fast stripping run with an overall content of 30%
    I will run another batch some time this week, then combine the stripped runs and do a spirit run to se how that works out.
  6. The Following User Says Thank You to Kola For This Useful Post:
  7. #346
    Richardsbay, KZN
    Thanked: 15529
    A 15mm ball valve works well, the male thread also matches hose tap fittings. Have one on the Liebig and another on the reflux flow.
  8. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  9. #347
    Thanked: 15171
    Yes, I have an assortment of ball valves with hose tap quick disconnects on either end, quick and easy if you need flow regulation and I use them for brewing as well.
  10. #348
    Oct 2006
    Melkbosstrand
    Thanked: 894
    Thanks, have ball valves but it makes sense to set up with quick connects.
  11. #349
    Thanked: 1071
    A gate valve is better and has more control, got this advice on this forum and bought a gate valve.
    On the outlet from my kettle I will fit a ball valve as that is open and closed at any point.
  12. #350
    Thanked: 15171
    indeed, gate valves are more accurate, but at the price of them, I can buy quite a few ball valves
    I also find the gate valves tend to cause issues when dirty.
  13. #351
    Thanked: 1071
    We need to do a group buy on red and blue hose pipe. Can't afford R 500 X 2 for 40m of hose just to use 2m.
    Anyone got sources for 13mm hose in varying colour sold by the m?
  14. #352
    Thanked: 15171
    Go and ask the local co-op or irrigation store for dragline.
  15. #353
    Thanked: 1071
    Looks like dragline is 20mm, I need 13mm. Do you know if they go this small?
  16. #354
    Gaborone, Botswana
    Thanked: 1253
    Look at the Marley website. https://marleypipesystems.co.za/mega...igation-hoses/
    There is a 12mm available.
    Kobus
  17. #355
    Thanked: 1071
    I need a reseller that sell by the m.
  18. #356
    Gaborone, Botswana
    Thanked: 1253
    I assume the red and blue hose (for in and out) is for cosmetic reasons.
    What about black hose with the ends covered with blue and red shrink sleeving ? Black hose may be more readily available in "per meter" length than colored hose.
    Kobus
  19. #357
    Thanked: 981
    I see you are in Alberton so Hose Centre in Edenvale isn't too far from you. They should be able to supply you with the correct hose you want. http://www.hosecentre.co.za/
    https://www.google.co.za/maps/place/....1612051?hl=en
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  20. The Following User Says Thank You to Paul#25 For This Useful Post:
  21. #358
    Thanked: 1071
    Indeed, I have come so far now that to fall at the final hurdle will be criminal .
  22. #359
    Thanked: 193
    I would suggest a lever ball valve for the reflux, by having a longer handle its a whole lot easier to adjust (and to see what angle you are at) plus the plastic coating helps not burn yourself
    when you have to touch it in the middle of a run.
    2009 Suzuki GV 3.2
    ex : 2010 Suzuki GV 2.4 M/T
  23. The Following 3 Users Say Thank You to ColeGP For This Useful Post:
  24. #360
    Thanked: 889
    So I bought some of that "syrup" that you flavour your neutral spirit with last week. I got some Irish Whisky flavouring and also some Pirate Dark Rum flavouring. Both aren't anywhere NEAR the real stuff, but it's amazing with Coke. So if that's what you're looking for, I can REALLY recommend it. The rum one tastes exactly like Spiced Gold and the Irish one very close to Jameson when mixed with Coke.
    On a related note, I started a high-gravity all-grain wash today to make a pure all-grain whisky. Got my French Oak toasted and everything ready for it!
