Painting of corrugated metal roof
Results 1 to 20 of 26
    15°57'44.5"S 5°38'53.2"W
    Thanked: 506
    Default Painting of corrugated metal roof
    Hi Guys,
    My workshop has a corrugated metal roof (sink dak). Flat, 5x5m. It's showing it's age these days. With heavy rain, it sometimes leaks a bit at some of the overlaps of the panels. I want to sort it out, seal the overlaps, and paint the thing.
    I've never painted "sink" before. If there anything specific I should be looking at? What precautions should I take? What preparations should I do for this?
    Any pointers?
    Chris
    Don't blow it, this is the only planet with beer!
    HYADES
  2. The Following User Says Thank You to Hyades For This Useful Post:
    Greyton westerncape
    Thanked: 47
    Thumbs up Re: Painting of corrugated metal roof
    Perhaps it is a Zinc roof. Easy job DIY talk to your local paint supplier.
  4. The Following 2 Users Say Thank You to mike cullen For This Useful Post:
  5. #3
    Thanked: 15601
    Default Re: Painting of corrugated metal roof
    Raw galvanised metal needs an etch primer. There are plenty of sealing options, from sealant gum to impregnated overlay fabric. In my opinion, talk to a Duram agent, they'll have a decent product for you. A metal roof with a proper pitch and overlap shouldn't leak though.
    Jakes Louw
  6. The Following 2 Users Say Thank You to jelo For This Useful Post:
  7. #4
    Thanked: 305
    Thumbs down Re: Painting of corrugated metal roof
    Quote Originally Posted by mike cullen View Post
    Roberto Forbes
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
  8. #5
    Thanked: 506
    Yes, a Zinc roof, is a "sink dak" in Afrikaans.
    Chris
    HYADES
  9. #6
    Thanked: 492
    Are your overlaps proper? If not, it might leak a bit there.
    I have an old (circa 1972/73) corregated roof on my house. I sprayed it with ordinary red oxide about 7/8 years ago and it seemed to work. Although the Plascon Roofpaint I put over it, powdered up and disappeared over the years.
    Paint shop suggested that the water base paint was attacked by the solvent based red oxide. I will repaint at some point with bitumen aluminium solvent based paint.
  10. The Following 2 Users Say Thank You to Spiceman For This Useful Post:
  11. #7
    Thanked: 460
    I once painted a new corrugated roof. It was a 12x3m area.
    I used Galv-etch to etch and clean it and painted with Megabond Thermshield without a primer.
    We sold the house 12 years later. No peeling at all.
    I have seen a few roofs with peeling paint due to improper under coats.
    https://www.galv-etch.co.za/
    2004 Defender 110 Td5
  12. The Following 2 Users Say Thank You to Sawdust For This Useful Post:
  13. #8
    Thanked: 270
    Have a look at the new paint on rubber solutions. I used it on a problematic ,nearly flat, section that even docters could not sort. And one rainy season down the line it is so far so good. Did not even need primer.
  14. The Following 2 Users Say Thank You to Wicd For This Useful Post:
  15. #9
    Thanked: 83
    Do not use acrylic pain sealer (pap en lap) it will corrode the zink/galv. I use Sikalastic, a rubber sealant that can be painted on with the membrane. Also a good idea to seal/ prime metal sheets with bitumen product from ABE before you put any pain/ sealant on
  16. The Following 2 Users Say Thank You to emileheyns For This Useful Post:
  17. #10
    Jan 2014
    Heliport
    Thanked: 308
    First of all , good hose down with a pressure cleaner , edge primer and plascon roof coating , should last for years . As far as the leaking , roof anchors mostly the problem , the rubber washer fails due to the elements over the years , replace . You might find that the wood under the nails can be rotten in which case you should replace with oversize anchors Also look for movement on the roof ( inadequate roof trusses ) it will loosen up the roof anchors and no matter how you seal this it will leak
    Using Tapatalk
  18. The Following User Says Thank You to cor For This Useful Post:
  19. #11
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 1511
    Sorry to say. You will NEVER stop leaks on your flat corrugated roof.
    Corrugated sheets should not be used on slopes lower than 15 degrees.
    If it was my roof I will replace the sheets with Kliplok type and never have concerns again. A bit more expensive than painting etc, but (even financial) worthwhile.
    Johan Maree
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    Conqueror UEV-25
  20. The Following User Says Thank You to JohanMaree For This Useful Post:
  21. #12
    Nigel
    Thanked: 2362
    Use poprivits and snap them together. But on the ridges.
    Plenty poprivits.
    Uniglide
    +27 zero eight 2 four 95 9252
  22. The Following User Says Thank You to Henris For This Useful Post:
  23. #13
    Robertson/ Larissa, Greece
    Thanked: 3641
    My experience with Corrugated sheets on flattish roofs is that in hevay rain, the ridges fill up with water and then spill over causing a leaking. No matter the overlap. In other words the slope is not enough for water to flow down fast enough. What Johan is saying here. Or also when raining with heavy winds, the wind will drive the water under the sheets. A bigger ridge like IBR does not cause that
  24. The Following 2 Users Say Thank You to Francois Theron For This Useful Post:
  25. #14
    Jan 2014
    Heliport
    Thanked: 308
    Nothing wrong with corrugated , done a lot of garages , houses etc . No pop rivets please , problem with small slopes is the wind driving the water up the slope and then it leaks against the flashing if there’s a wall . I had my corrugated bend ( no joints or overlapping on the lengths ) Clip-lock is a good idea but not good in storms , most of the roofs that was lost in the “hurricane “ that hit Krugersdorp a couple of years back was clip-lock
    Using Tapatalk
  26. #15
    Apr 2018
    Umhlanga
    Thanked: 689
    Quote Originally Posted by Hyades View Post
    Hi Guys,
    Any pointers?
    1st rule. Clean off all the rust. Loose, flaking. surface
    2nd rule after cleaning the rust. Paint anti rust/ etch primer/ P4 zinc primer over where the rust used to be.
    Pre drill a pilot hole before nailing down/ fastening any loose sheeting.
    Unless you can place a torch on membrane such as Derbigum over the overlaps and joints, do not waste your money buying the 5 litre tins of waterproofing liquid that come with a "free" membrane.
    Rather buy a roll of "Flashband". ABE is one of the maunfacturers, but the prices vary between the brands. All do an excellent job, and are exactly the same.
    Use a 75mm wide flashband. Don't use smaller, as movement will cause the edges to peel.
    Do not use enamel paint on an iron/ tin roof.
    Do not use roof paint, unless it is designed for iron/ tin/ zinc.
    Etch primers such as NS4, Hammerite, come in a huge variety of colours.
    And remember that your "flat" roof has served it's purpose for many years.
    Don't replace it. Fix it.
    I met some crazy people.... They made me their leader.
    2014 Mazda BT-50 - Recently bought. March 2018
    2013 Nissan NP300 - Daily workhorse
    1993 Ford Courier 2.2... Odometer stopped working just over 530'000 km's. Sold 2013
    69' Series 2 Landi - Old, slow, thirsty. Go anywhere. Stolen in 2010
  27. The Following User Says Thank You to AlexP For This Useful Post:
  28. #16
    Thanked: 492
    Something that wasn't discussed in detail is the galvanizing part. I was lead to believe that if a corrugated roof is old and rusty its not necessary to use galvanising primer. Only on newish/shiny zink. Any remarks or facts about that please.
  29. #17
    Jun 2008
    Thanked: 1511
    Thanks for your support Francois. Exactly as you explain. Although, even IBR is dicey as its lowest designed slope should not be less than 7.5degrees.
    Where Kliplok was blown off in storms they were not installed correctly. Never blame the product if the artisan is suspect too.I have a roof that has a 100mm drop over 6m under Kliplok and it has never showed any leak, even with 50mm hail spread over it (at one time).
    The guys who install corrugated on flatter roofs are doing it as a cost saving only. There can be NO other sensible reasoning. And it is ugly to say the least.
    Johan Maree
    Isuzu 300 d-tec
    Conqueror UEV-25
  30. #18
    Apr 2018
    Umhlanga
    Thanked: 689
    Carports usually use IBR sheeting, and there is minimum fall if not any.
    Clay roof tiles recommend a minimum fall of not less than 17 degrees.
    If galvanized sheeting has weathered. (6 months exposed to sun & rain) You do not need to wash the sheeting with a galvanized cleaner before painting.
    The use of galvanized primer - which is always yellow, for some unknown reason, acts as a bond between the metal and the final coat of paint.
    Personally I have painted galvanized barriers with galv primer and then enamel paint, and the paint has peeled within a year.
    And I have painted corrugated roof sheeting on a trio of gemini huts, with only etch primer and green roof paint, and 3 years down the line they are looking good. With no leaks where I have patched using Flashband.
  31. #19
    Thanked: 1117
    Quote Originally Posted by emileheyns View Post
    Reviving here ...
    I'm considering using Sikalastic, i've watched some videos on the product and it seems very sufficient. Has anyone else used it? See photo below, I used a contractor from Pretoria, which was my first mistake in this process to build a new roof and braai.
    He sealed it with some sort of fiberglass and rubber application around the chimney. (because "he doesnt use pap & lap yadda yadda)
    We had 3 drops of rain, literally 5min ± 3 weeks ago, it leaked. He came back to re-seal it, only to see that he used pap & lap upon my return. Now last night we had 6 drops, leaked again. Safe to say he's not coming back, I just don't have the energy. Will Sika do the job? Should i try and rip off his pap & lap application first?
ID:	589458   Click image for larger version.
  32. #20
    Thanked: 757
    I see Hyades / Chris gives his location as the airport on St. Helena Island. Will be interesting which of the suggested options are actually available at his presumed location.
    Mike Nieuwoudt
    '89 LR 110 V8
