Discovery 1 The resurrection and further adventures of Fugard
Page 1 of 9 1 2 3 4 5 6 7 8 9 LastLast
Results 1 to 20 of 169
    Modjadjiskloof
    Thanked: 174
    Default The resurrection and further adventures of Fugard
    With the final demise of La(n)dy, I realised that I've been posting rebuild info for her replacement using the same old thread. To make things easier and more understandable for those following, I decided to start a new thread for a "new" Land Rover.
    Meet Fugard. Another 300 Tdi Disco 1.
    I flew down to St Lucia in August 2019 to fetch him from a loving previous owner who was not at all glad to see him go! Driving up, he looked like this:
ID:	568082   Click image for larger version.
ID:	568083   Click image for larger version.
ID:	568084   Click image for larger version.
  2. The Following User Says Thank You to antvz For This Useful Post:
    Modjadjiskloof
    Thanked: 174
    Default Re: The resurrection and further adventures of Fugard
    Despite running very well and being in generally good condition, Fugard soon revealed that he had an untreated drinking problem. About 1 litre per 400 km of the best 15W40 you can give him. He was going to go to Mozambique like that, but I didn't want to risk it. So I decided to open up and have a bit of a measure around...
    The verdict was that the bores were showing enough wear to warrant a proper rebuild.
    This time, the engineering will be contracted out, then measurements checked, and the actual rebuild will happen in my lounge! It will be a good learning experience and hopefully have good results...
    Watch this space for details and pics as I progress...
  4. The Following 4 Users Say Thank You to antvz For This Useful Post:
  5. #3
    Thanked: 16423
    subscribed, I have an ache for a 300tdi D1
    Jakes Louw
  6. The Following User Says Thank You to jelo For This Useful Post:
  7. #4
    Modjadjiskloof
    Thanked: 174
    Only one way to fix that :-)
  8. #5
    Thanked: 16423
    Ja I know, get the behind me Satan
    Jakes Louw
  9. #6
    Oct 2015
    glen innes
    G'day Antvz.
    Will be following this thread with much interest......hope not too long before Fugard is back on the road.
    mike
    Disco 1 300tdi 1997
    Land Cruiser hzj75 1997
    Landy trayback s111 1976
  10. #7
    Modjadjiskloof
    Thanked: 174
    Quote Originally Posted by boobook View Post
    G'day Antvz.
    mike
    Thanks boobook. This is going to be an interesting journey and a good learning experience.
    In general, it's not too difficult to rebuild an engine like this one, but tolerances are very important and so is neatness, cleanliness and meticulous attention to detail. Also good quality parts.
    Knowing what to replace, what to check, and what to re-use is also important if you don't have an absolutely unlimited budget.
    Anyway, it will all be documented here and open to criticism and discussion...
  11. #8
    May 2010
    Kraaifontein
    Thanked: 9
    Looking forward to the rebuild antvz! #subscribed
    'For I know the plans I have for you," declares the LORD, "plans to prosper you and not to harm you, plans to give you hope and a future.' Jeremiah 29:11 NIV
  12. The Following User Says Thank You to NinoZA For This Useful Post:
  13. #9
    Apr 2011
    Thanked: 19
    Good luck with the rebuild!
    Guillaume
    Fortuner Epic 4.0 V6 AT
  14. The Following User Says Thank You to Guillaume For This Useful Post:
  15. #10
    Modjadjiskloof
    Thanked: 174
    Finally some space is cleared after stripping the other one. Yesterday I removed all the peripheral stuff around the engine. Unfortunately, due to the routing of the wiring harness, I have to remove the injector pump first, so that slowed me down. Hopefully by the end of today, the engine will be out.
  16. The Following User Says Thank You to antvz For This Useful Post:
  17. #11
    Modjadjiskloof
    Thanked: 174
    Well, it happened. Engine out. Those three fiddly bolts on the top of the bell housing were a pain, as usual. One was half way out already, so someone in the past gave up or forgot about it.
    The torque converter came out with the engine this time, to my annoyance. I hope the extra manhandling didn't do any damage to the gearbox pump.
  18. The Following 2 Users Say Thank You to antvz For This Useful Post:
  19. #12
    Oct 2015
    glen innes
    Geez... you were very trusting using those two long bolts through a chain link to lift the block out.
    The leverage generated would have been close to ripping a piece of the block out....I bet the bolts have a bend in them now!
    But maybe that engine is scrap anyway.
    Good to see things happening anyway, Landy's are meant to be used, not stored away in a corner!
    Disco 1 300tdi 1997
  20. #13
    Modjadjiskloof
    Thanked: 174
    Actually I thought it was a pretty good idea, although I did have some concerns at first but used the shortest head bolts I could. However, I actually see your point, and what I should do is fashion a thick plate with anchor points to bolt down to the block properly in a few places.
    I particularly don't want to encourage bad practice on an open forum.
    Also, I suppose I'd better have that block checked. Thanks for the headsup.
  21. #14
    Modjadjiskloof
    Thanked: 174
    Ok, so today was the day to strip the engine block. As far as I can see, all the parts on there are the originals. In general, bores are still in good condition, but there is a bit of a wear ridge so it's time for a rebore.
    One of the reasons I decided to go the "whole hog" and not put the engine back together again, was a score mark in bore no.4. We suspected a broken ring. In fact, the piston itself had lost a piece (cracked) which was nowhere to be seen. That's where all my oil was going!
    The above explains why the previous owner had high but acceptable oil usage. He had been driving around just fine, and I think topping up once between services. I could hardly get it to joburg and back without stopping every now and then to fill the oil and check the diesel!
    The straw that broke the camel's back was an indy service just before I took ownership. This guy couldn't or didn't loosen the IP sprocket bolts when doing the cam belt. It was way too advanced and the car ran hot at the slightest provocation. I think the constant extra heat and knocking finally caused that piston to fail and lose a piece.
    Bearings are worn (through to the copper in most cases) but very little scoring. Just an honest to goodness high mileage engine, nice and clean inside. I feel it's done it's worth and the rebuild should be straightforward.
    The quality of the bearings is particularly noticeable compared to what was in the engine of my white Landy.
  22. #15
    May 2020
    Lone Hill, Johannesburg
    Hi Antvz, I'm doing a similar build and have a similar vehicle. Could you suggest a method to loosen thr top bolts of the belhousing without the torque converterbeing on the wrong side.
  23. #16
    Modjadjiskloof
    Thanked: 174
    Quote Originally Posted by Mike dP View Post
    Hi MikeDP,
    I've only ever taken out 2 of these engines before, so I'm no fundi. For those top three bolts, here are my strategies:
    - After removing the engine mounts, etc. and while the engine is supported by the crane, I lower it slightly to get access to those top three bolts. Otherwise they are right up against the firewall. I do those three bolts first before loosening the others on the bell housing.
    - On this green Landy (Fugard), I had the head off first. This gives you space to get in there with a good, flat number 13 spanner. Must be a good one or those bolts can get rounded. Even better, is a no.13 ratchet spanner - again, the flattest you can get. If it's "bent" at an angle you can't get access.
    - Without taking the head off first, it's more difficult. In that case, I used a hint I saw in Hayne's, I think. A good 13 socket on a long extension with a universal joint so it can flex - lie under the car with that contraption and get an assistant to guide the socket onto the bolt. This works a treat.
    Regarding the torque converter being on the "wrong side", I'm not sure exactly what you mean. Do you mean, to avoid the torque converter coming off with the engine instead of staying on the gearbox? I'm not sure how you can prevent that. In one case, it stayed on perfectly. In the next, it came off with the engine. I'm sure others will be able to shed some light.
    (obviously, remember to unbolt the torque converter from the flywheel before you start, otherwise it's 100% certain where it will come off!).
  24. #17
    Dec 2014
    Thanked: 2174
    Once you have unbolted the torque converter from the drive plate, you can push it back slightly and there is a special tool to hold it in place, but a piece of flat bar will suffice. That will keep it on the transmission side of affairs for removal.
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  25. #18
    Modjadjiskloof
    Thanked: 174
    With all the Covid restrictions in place, Fugard has been sitting there without his engine for some time. Meanwhile, I've been shopping around for a place to do the engineering.
    There's a little shop here in Tzaneen that I use sometimes. The owner has his thumb on everything and takes good care. Unfortunately their setup is too basic to fit the cam bearings properly, and they also don't have a big chemical cleaning outfit.
    I had pretty much decided on a certain shop in Joburg, after using them once for my Tata cylinder head. They showed me around the shop afterwards, and they seem to tick all the boxes. However, when I handed in the head originally, they also had no time to listen to what I wanted. So I decided to look around a bit more.
    Eventually I came across Norman Hall Engineering in Joburg. I emailed them already during the lockdown and got a very favourable response with answers to all my questions. Today I phoned them and got a cost estimate. Again the representative answered all my questions and did not fob anything off. Based on what I have read, and their response, as well as the fact that it seems to be a very good outfit...I think this is the shop to use.
    Unfortunately I can't travel to Joburg yet, but hopefully all this will get done at the end of September if I get a few days to go through. So now I'm just preparing everything and getting a parts list ready.
  26. #19
    Cape Town Southern Suburbs
    Thanked: 1265
    If you want to speed things up Xoc.co.za can courier huge weights/volumes for not much money, you can get a quote and pay for the couriering online. Just pack the stuff well, probably best crated.
  27. The Following User Says Thank You to Skylark For This Useful Post:
  28. #20
    Modjadjiskloof
    Thanked: 174
    Thank you, will get a quote. Postnet will charge about R1400, which is too much.
