KZTE Gearmax rear diff no drain hole
Results 1 to 11 of 11
    Harrismith
    Thanked: 492
    Default KZTE Gearmax rear diff no drain hole
    A friend of mine is servicing his 2003 KZTE 2x4 with the rear Gearmax locking diff. He can't find the drain hole. There is a boss, where presumably the drain is supposed to be, but there is no plug.
    Any ideas on how to drain the oil?
    Where it (presumably) should be
    Thanked: 187
    Default Re: KZTE Gearmax rear diff no drain hole
    My Isuzu (rear diff), which I believe is also a gearmax diff, also has no drain holes. I got 2 handpumps. One for sucking the diff dry and one another (clean oil) pump for filling the diff again. Also works great for filling the gearbox.
    It is a bit temperamental with thick oils, but works well with some patience.
    PS - It does not break, but the pipes do not like hot liquids. I have used it to pump radiators empty before.
    https://www.adendorff.co.za/product/...r-siphon-pump/
    Isuzu Frontier 280LX 4x4 2001
    Oct 2017
    Vereeniging
    Thanked: 84
    It is easy enough to take off the whole cover. Gives me a chance to care for it with a bit of Autosol. (Aluminium cover on Isuzu rear diff)
  4. The Following User Says Thank You to EtienneB For This Useful Post:
    Harrismith
    Thanked: 492
    Pump or siphon it is then.
    Thanked: 187
    Quote Originally Posted by niclemaitre View Post
    Siphon 100 weight oil? - may the force be with you...
    The oil is like molasses.
    Any type of pump will be much less painful.
    Thanked: 13618
    Take off the cover, much easier. Replacing the gasket might be the issue.
    While it is open, drill and tap a drain hole?
  8. The Following User Says Thank You to jelo For This Useful Post:
    Sep 2015
    port elizabeth
    Thanked: 72
    Quote Originally Posted by EtienneB View Post
    HOW do you keep your van so clean? Looks like its still on the showroom floor
    Wartburg.
    Thanked: 611
    Quote Originally Posted by aidan zimmerman View Post
    I was wondering the same thing.
    To the OP, just take the cover off, you can get the gasket from Gearmax for a few rands.
    If you are able to drill, tap and put a plug in then do so.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  11. The Following User Says Thank You to Chris8d For This Useful Post:
  12. #9
    Postmasburg
    Thanked: 255
    Ek amper seker dat Adendorf elektriese pompies ook het.
    Maak werk baie makliker.
  13. #10
    Oct 2017
    Vereeniging
    Thanked: 84
    Quote Originally Posted by Chris8d View Post
    I was wondering the same thing.To the OP, just take the cover off, you can get the gasket from Gearmax for a few rands.If you are able to drill, tap and put a plug in then do so.
    Small little cleaning routines, very often. Have to because I drive it daily. I saw 385,000 km on the odo this morning on the way to the mine. Yes, the gasket is not expensive, and if you install carefully, you can re-use. Clean contact surfaces, thin film of all-purpose grease on both sides, and bob's your uncle.
  14. The Following User Says Thank You to EtienneB For This Useful Post:
  15. #11
    Bellville
    Thanked: 161
    Agree, rather take cover off and clean properly inside, you can then check the diff-lock mechanism as well. And EtienneB, must be one of the cleanest daily driver bakkies in SA - great!
    2011 Pajero 3.8 GLS LWB
    1996 Conquest 160i RS
