Freelander II 2007 Freelander 2 td4 HSE not starting
Results 1 to 20 of 27
    Goodwood
    Default 2007 Freelander 2 td4 HSE not starting
    Hi there - I am in need of some advice please.
    My car has over a period, from time to time, struggled to start. It seems that when I did not use the car for a few days, 3 or more - I would get the clicking sound trying to start, and I needed to jump start. It was bad a few months ago when I was at my cabin in Ceres - we were busy packing to leave after our weekend - I connected my cooler box and went on packing up - not more than 2 hours - tried starting - I got the clicking - had to get a jump.
    After lockdown began - I made sure I started the van every 2nd day. Then I had to run an errand - I decided to take my van for a run to boost the battery - everything seemed fine - the van parked for about 3 hours - and when I left it started fine - while driving I noticed a few lights on the dash - which reminded me of the 3 amigos I had on my Disco 2 - and a message on the display saying HDC not active - or something like that. Also my speedo was not working either. When I got home I switched off and unlocked the garage - when I wanted to pull in - I started, it died almost immediately - when I tried starting again - the error was on the screen and there wasnít even a click from the starter. I disconnected the battery for a few days - but still the same.
    Has anyone have any advice for me please.
    Thanx
    Quinton
    1995 Discovery I V8 (sold)
    1998 Discovery I Tdi (sold)
    2001 Discovery II Td5 "Helga"(sold )
    Discovery 3/4 Tdv6 HSE (wish list)
    Current - 2007 Freelander 2 Td4 HSE
    Jul 2016
    Thanked: 501
    Default Re: 2007 Freelander 2 td4 HSE not starting
    It sounds like your battery is needing replacement
    Thanked: 858
    Quote Originally Posted by MikeBob View Post
    This.
    2011 Freelander 2 SE
    Sep 2013
    Pietermaritzburg
    Hi Quinton, new battery probably needed. Had similar issue and found the TCM (transmission control module)plug slipped out. Cable tied and fine now. Mine is 2008 auto.
    Thanked: 295
    Quinton, before you buy a new battery, remove both battery clamps and clean the battery poles and the battery clamps from battery acid build up.
    2006 VW Touareg 4.2 V8 Auto
    2000 Disco 2 GS 4.6 V8 Auto
    2013 Wildebeest Kalfie Boswa
    2002 Audi S6 4.2 V8 quattro
    2013 Freelander SD4 (SWAMBO)
    ORRA Z07
    Melkbosstrand Cape Town
    Thanked: 75
    I would charge the battery with a charger first and see how long it lasts , if all ok I would check alternator output . I don`t know why people with a flat battery jump start the car and then drive it for 10 min and think all is well. Surely if you say have a 40Amp alternator and 40Amp battery it would take about an hour or more driving to charge the battery and even then it won`t be fully charged ,or am I wrong ?
    Thanked: 295
    Edit..When there is acid buildup between poles and clamps, even a battery charger wont be effective when clamped onto the battery clamps.
    ORRA Z07
    Goodwood
    Thanx all for the responses - I have the van for more than 3 years now, and still have the same battery that I bought the car with - my initial thought was the battery going, cos it started a bit heavier on cold mornings lately. My other concern is that I donít hear the click when I try to start, like in the past - there is just the sound of the relays when trying to start. I have tried a charger - granted that it was while the battery was still connected to the car. When checking the battery with a voltmeter gauge, it shows just a bit below 12 volts - but it still doesnít want to budge and start.
    QT
    Thanked: 13630
    Quote Originally Posted by quingt View Post
    QT
    under 12v means it is toast
    12.6v minimum
    Definitely check the battery... Had the ticking noise and "Christmas tree" dash lights, on our former 08 Freelander 2 i6 HSE... Battery was tested and found to be a dead cell... It got worse as the weather got colder and eventually got to the point you are at where is died in hours not days.
    Have it checked sooner than later as prolonged "ticking" can damage the starter
    Warning... New battery was not friendly on the pocket 3 years ago, I can only imagine what it is now
    Retired: 07 Mitsubishi Outlander
    Retired: 07 Jeep TJ Wrangler Sahara (one of the last)
    Retired: 08 Land Rover Freelander 2 i6 HSE
    Current: 14 Range Rover Evoque Si4 Dynamic
    Goodwood
    Thanx all - feedback much appreciated.
    Will let u know once resolved.
    QT
    Jan 2019
    White River
    Thanked: 16
    Quote Originally Posted by Andrew Rodrigues View Post
    Batterys charge rates are not linear and to fully charge could take more than 5 hours.
    Goodwood
    Quote Originally Posted by desdrake View Post
    I had it on charge overnight, disconnected from the van - but same result. I donít doubt that the battery is vrot - my concern is, is that the only issue I have
    Jul 2016
    Thanked: 501
    The early FL2s often need a second earth cable running from battery to engine somewhere. But you need to have the battery tested first.
    Thanked: 858
    I had it on charge overnight, disconnected from the van - but same result. I don’t doubt that the battery is vrot - my concern is, is that the only issue I have
    Charging a vrot battery does not fix a vrot battery.
    It's quite simple to be honest, you are chasing ghosts. Have your battery tested properly, with the proper equipment, and if it is vrot, have it changed. It'll cost about 2-3k, depening on which brand and where you buy.
    If still issues afterwards, well then you are in for fault finding.
    Thanked: 189
    When the first battery on our FL died, I discovered that it was too small in the first place.
    I now run a Varta 80ah(me thinks?).
    I always go for the biggest battery that will fit.
    Si vis pacem, para bellum
    Goodwood
    Hi there all, the feedback was greatly appreciated - I got a brand new battery fitted, a Willard 668. Sadly, it didn't solve my problem. I then attempted a ECU reset, but alas, the problem still prevails HDC fault, and no start unfortunately.
    Are there any further fault finding I can try?
    Much appreciated.
    Quinton
    Goodwood
    Hi there all, the feedback was greatly appreciated - I got a brand new battery fitted, a Willard 668. Sadly, it didn't solve my problem. I then attempted a ECU reset, but alas, the problem still prevails HDC fault, and no start unfortunately.<br>
    Are there any further fault finding I can try?<br>
    <br>
    Much appreciated.<br>
    <br>
    Quinton
    Thanked: 858
    Look at what Mikebob said. He is very knowledgeable on Land Rovers
    Thanked: 858
    I also read on another thread that it might be your throttle body that is kaput, but for that you would need to have a reputable place look at it. I would suggest you get a reading from the computer to check what fault codes your car has.
