RangeRover Exhaust smells of sulphur/rotten eggs
Results 1 to 20 of 31
    Feb 2016
    Thanked: 774
    Question Exhaust smells of sulphur/rotten eggs
    Hi gents,
    Ok, this is a weird one: I've noticed a smell of sulphur/rotten eggs when parking the Rangie - have any of you ever experienced this on a petrol car?
    I noticed it last week, but thought it was a drain/gutter as it had rained the night before. But yesterday when I parked the car, my wife was waiting in the garage to get stuff out of the car, and she also mentioned that something smells funny.
    Since the lockdown started, I only go out once a week for essential groceries, so the car is not being driven much. The shop is 2 km away, so I try to take the longest route possible to give everything a bit of a workout.
    Anything I should be concerned about?
    Thanked: 13623
    Default Re: Exhaust smells of sulphur/rotten eggs
    It's the catalytic converter doing its thing.
  3. The Following 3 Users Say Thank You to jelo For This Useful Post:
    Nov 2017
    Thanked: 210
    Also check your battery voltage, could be the alternator overcharging or fault with battery.
  5. The Following User Says Thank You to HobieDave For This Useful Post:
    Feb 2016
    Thanked: 774
    Thanks Jelo, other RRS owners say the same.
    Our Spar is 1km away, hard to get the car to operating temps, even if I take the 'long' way to go shopping.
    Thanked: 94
    Orxy.
    Do not be alarmed when you see excessive white smoke bellowing out at some stage. It happens when the cat gets partially blocked, which is not a good thing though. You might even get engine performance restriction. Cats do not like short distances. Best is to get a good burn on the highway.
    I am sure your Spar does not always have the goods you are looking for, which the Spar at Somerset West will have...
    Regards,
    Suid-Wes
    2006 Defender 110 Td5
  8. The Following User Says Thank You to Suid-Wes For This Useful Post:
  9. #6
    Jul 2010
    Modders
    Thanked: 251
    Often caused by dirty fuel also caused by stagnant fuel, something to do with algae
    Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
  10. #7
    Henties
    Thanked: 747
    Quote Originally Posted by Suid-Wes View Post
    Orxy.
    Regards,
    Suid-Wes
    Quote Originally Posted by Hamtheman View Post
    That RR is a petrol. Petrol cats don't get blocked, at least not within a few weeks.
    Algea form in diesel, petroleum and Kerosine type fuels, not in petrol.
    That smell is caused by some hydrogen sulfide, which the cat at proper operating temperature would usually convert into something without odor.
    Since the cat can't get to proper temps, the exhaust smells like rotten eggs. It probably is in solution in some condensation water inside the exhaust system, too. Hence the smell might linger around, even if the car has been switched off for a while.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
  11. The Following 6 Users Say Thank You to HugoNotte For This Useful Post:
  12. #8
    Thanked: 898
    My FJ also does it from time to time.
    FJC - Just Cruising
  13. #9
    Aug 2018
    Paarl
    Thanked: 66
    Years back had the same problem and turned out my battery was cooked
  14. The Following 2 Users Say Thank You to fatbike For This Useful Post:
  15. #10
    Apr 2018
    Fraserburg
    Thanked: 795
    Orxy.
    Regards,
    Suid-Wes
    That could cost him R5000 extra under Covid. Expensive grocery run.
  16. #11
    Witbank
    Thanked: 204
    Mine does it too, it's the Cat one up to temp or disappears. Takes quite a while to get a Cat to proper working temp. Nothing to worry about.
  17. The Following 2 Users Say Thank You to nedge For This Useful Post:
  18. #12
    Thanked: 439
    Sealed batteries give off a rotten egg smell when they pop (sulphuric acid)
  19. The Following User Says Thank You to GaryFrank For This Useful Post:
  20. #13
    Greyton westerncape
    Thanked: 40
    Exclamation Re: Exhaust smells of sulphur/rotten eggs
    Mine was an overcharging battery it nearly poped .
  21. The Following User Says Thank You to mike cullen For This Useful Post:
  22. #14
    Aug 2018
    Paarl
    Thanked: 66
    I will deffinately first check my battery
  23. #15
    May 2016
    Jozi
    Thanked: 24
    With spar only 1000m away, why not walk there and get the essentials you need in a backpack? Unless indeed the body isn't willing.
    It's an opportune time to walk the streets as I personally belive crime has dropped during this time. Still be cautious ie don't walk with phone in hand or on ear.
    2 more weeks and you can give the cat a proper burn!
  24. The Following User Says Thank You to Hloni For This Useful Post:
  25. #16
    Tzaneen
    Thanked: 281
    The RRS come with AGM battery.Don't think they smell.
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
  26. #17
    Thanked: 13623
    Or do donuts in the parking lot till the cats are hot
  27. #18
    Oct 2012
    Boland
    Thanked: 166
    Quick run up Helshoogte pass using 2nd & 3rd gear only.
  28. #19
    Wartburg
    Thanked: 1561
    Quote Originally Posted by fatbike View Post
    That was my first thought, but that smell would normally take longer to develop than a short 1km run. I won't hurt to check the battery and charge voltage though
  29. The Following User Says Thank You to mikeml For This Useful Post:
  30. #20
    Thanked: 1415
    Hi gents,
    Sounds like the Rangie did the egg challenge
    Sent from my iPhone
