LC Catch Can
Results 1 to 15 of 15
Thread: LC Catch Can
    Jan 2015
    Thanked: 219
    Default LC Catch Can
    Easter weekend for my wife and I is usually spend somewhere remote, either on the Wild Coast or up in the mountains somewhere. This year however, as for many, was a little different. So I spent the weekend making a catch can for my Land Cruiser.
    In my scrap pile I came across this old fire extinguisher. It was roughly the right size and, as a bonus, it has an aluminium canister.
    First the top came off
    The guts extracted
    And the powder emptied
    This is where I began.
    I must admit that there was very little planning and design involved and I was basically just making it up as I went along. The idea was to have the can in two halves, so that it can be opened and cleaned out periodically. It would have some filter media inside, most likely Goldilocks or something similar. I have come across one brand that is actually a complete spiral without little bits floating around.
    The canister will be inverted, with the screw cap at the bottom. Since it already has a hole in it, that will, with a bit of modification, be utilized for the drain pipe.
    This is the top cap, with the existing hole.
    The extra wings were removed, so that it looks like this.
    In my scrap drawer, I found this little fitting
    Which turns out to be a perfect fit.
    The inside was doctored with a little Wonder Fix Auto to form a nice funnel to the fitting.
    So now on to the canister. The plan is to cut the canister on the solid line and use the piece of scrap aluminium from my scrap pile to make a collar that will again join the two halves together. The small circle will most likely be where the inlet will be, with a baffle holding the Filter in place roughly where the dotted line is.
    Ready to cut. I parted it in the lathe to get a nice straight cut.
    What will eventually be the upper cap was threaded on the inside
    The chunk of aluminium was then turned down to size
    And the one end threaded to accommodate the top cap.
    The other side was turned down to fit snugly inside what would be the lower half. This will eventually be welded in place.
    I had to trim off this piece in order to maintain the overall length of the canister, as I still have the original mounting bracket and would like to use that as the final mount.
    Here is the complete canister with the mounting bracket.
    The collar welded in place
    And the can re-assembled.
    So today I will start on the pipes. The lower pipe will basically just have a 90° bend facing downward and not really an issue.
    The upper fitting though is a bit of an issue, as I need to pipe facing in the correct direction in relation to the lower pipe once the can is assembled and fitted.
    I will most likely make a swivel fitting protruding straight out the top with a 90°outlet. This will be able to swivel in any direction and will not be fixed. Will post some more when it it done.
    Guy B. Vergoes Houwens
    2014 LC76 4.5 V8
  2. The Following User Says Thank You to ghouwens For This Useful Post:
    durban
    Thanked: 1178
    Default Re: LC Catch Can
    I have no idea what a catch can is. Nice weld . What welder have you got.?
  4. The Following User Says Thank You to plunger For This Useful Post:
  5. #3
    Mar 2013
    Thanked: 432
    Very neat build, my only concern would be that the mounting bracket may not be up to the task on severe corrugations.
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    LROC member:5881
    -Land Rover Defender 110 Td5
    -BMW F800GS
  6. The Following User Says Thank You to pjf110 For This Useful Post:
  7. #4
    Jan 2015
    Thanked: 219
    Panweld 200A AC/DC. That, however, is a crappy weld. I have only done aluminium welding for the sum total of about an hour, so really new to it.
    2014 LC76 4.5 V8
  8. #5
    Jan 2015
    Thanked: 219
    Quote Originally Posted by pjf110 View Post
    I did have a similar concern as the original bracket is basically just a spring clip. However, the open end of the clip can accommodate a cable tie, and once it is cable tied there is no way of removing it without cutting the tie.
    2014 LC76 4.5 V8
  9. #6
    King Williams Town
    Thanked: 1182
    What is a catch can and it's purpose, or is it a turbo protector to keep oil at turbo bearings during shut down of motor Thanks
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  10. #7
    Gaborone, Botswana
    Thanked: 1252
    What is a catch can? : Ask google about PCV (Positive Crankcase Ventilation), blow by, oil mist, oil trap.
    Kobus
  11. #8
    Jan 2015
    Thanked: 219
    A catch can is to collect the oil from the crankcase vapour that would otherwise collect in the intercooler or foul up the turbo and intake manifold.
    2014 LC76 4.5 V8
  12. The Following User Says Thank You to ghouwens For This Useful Post:
  13. #9
    Mar 2013
    Thanked: 432
    Ghouwens has built a very nice system that I can only assume will reroute back to original intake position. I went the supposedly environmentally unfriendly route with letting the catch can vent to atmosphere. After seeing the amount of oil vapour that still pours out of the filter I will be reluctant to run a diesel again without a catch can.
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    LROC member:5881
    -BMW F800GS
  14. #10
    Jul 2015
    Garsfontein
    Thanked: 162
    Nice job. It helps if you have the right tools and know how to use them.
    Flip le Roux
    2012 Fortuner D4D 4x4 Auto
    2016 Jurgens Exclusive
    2014 BMW R1200RT
    2016 BMW F800GS ADV
    2016 Kia Picanto - Swambo
    2019 2.2 Ranger D/C XLS 4x4 Auto - Work
    GP0015
  15. The Following User Says Thank You to Riekielouw For This Useful Post:
  16. #11
    Jan 2015
    Thanked: 219
    Thanks PJF110. Yes, the system will feed back into the intake, hopefully a little cleaner than before.
    I have located what appears to be the perfect mounting spot on the side of the radiator fan cowl, next to the battery. Looks almost purpose made for the job.
    2014 LC76 4.5 V8
  17. #12
    Thanked: 1115
    Probably telling you stuff you already know, but from reading up a little on the topic, the most important part of the whole setup is how it connects to the engine. If this is not done correctly, the oil is not extracted.
  18. #13
    Jan 2015
    Thanked: 219
    Correct Peter. The idea is to get the vapour to cool as much as possible to allow it to condense. I have increased the size of the inlet and outlet to 22mm from the current 18mm. This will allow me to extend the piping without affecting the pressure. The further the air can travel before entering the catch can the cooler it will be.
    2014 LC76 4.5 V8
  19. The Following User Says Thank You to ghouwens For This Useful Post:
  20. #14
    Jan 2015
    Thanked: 219
    I had a chance to get this project to the 99% mark. I now just need to wait for lockdown to be a thing of the past, and then I can get some piping and a circlip to complete.
    I turned the plumbing fittings from some scrap aluminium heavy wall pipe.
    Then sectioned it and welded back up again to form the 90° bend I needed. I also welded in 3 small pins which would hold the "support baffle" in place.
    The top half (the cap) also got 3 pins and the hole bored for the outlet swivel fitting.
    This is the swivel fitting for the outlet. It has a groove cut in it to accommodate an o-ring.
    Here the o-ring is fitted. I also cut the groove for the circlip which will hold it in place.
    The outlet pipe was welded on. Test fit. Perfect.
    I got some cheap spoons from the Chinese shop ...
    and hacked them up to fit like this and form the baffles. One in the bottom ...
    and one in the top.
    3M pot scourers fit perfectly ...
    and 3 of them together nicely fill the space provided.
    And after a quick coat of my favourite Hammerite Satin Black, here is the completed can. Just need the circlip to hold the outlet in place and some rubber tubing to hook it all up.
    2014 LC76 4.5 V8
  21. The Following 8 Users Say Thank You to ghouwens For This Useful Post:
  22. #15
    Thanked: 51
    That is a work of art. What a pleasure to see craftsmanship like this in this day and age.
    Phil
    '10 Hilux D-4D AT - Land Cruiser Lite
    '14 Amarok 2.0 BiTdi 4M AT
    Summit Everest
    Wise men speak because they have something to say; fools because they have to say something - Plato
  23. The Following User Says Thank You to philth For This Useful Post:
