Chemicals for reverse electrolysis?
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 51
    Thanked: 175
    Default Chemicals for reverse electrolysis?
    Hi, it was discussed but i cant find the post
    I want to de-chrome some old taps, to have the brass show.
    Leaving them in hydrochloric acid is not working.
    which chemicals should i use?
    Hilux 2700i s/c 4X4 with a few extras ...............
    Jul 2017
    Louis Trichardt
    Thanked: 203
    Default Re: Chemicals for reverse electrolysis?
    My Life Loving It
    durban
    Thanked: 1061
    Ismail ,interesting question. Ive tried this and couldnt get an absolute answer. If you find out I would love to know. The electroplaters told me they do a reverse process. I dont know if you need big amperage but what i tried is simply bicarbe of soda and some steel as an electrode. Itwas connected to a 4 amp battery charger.
    It cooks like crazy creating a blueish foam . When you take it out the next day it looks like the chrome is still there but its lost its shine. I tried a bit of sand paper on it and it came off fairly easy.I tried this as an experiment and my conclusion is that there will still be alot of elbow grease involved .
    I may be wrong but I dont think its a case of you wake up the next morning and you have a beautiful shiny piece of brass.Once the top chromium layer is gone the nickel coat seems fairly easy to knock off.
    I dont know if you could up the amps if it would speed the process up because I had it in for an entire day.
    Take a look at Kroger Weekly Ad, Builders Warehouse Specials, Boots Offers,Avon Brochure and Avon Catalog!
    Thanked: 175
    I know the guys did tell me that the older the taps are the more difficult the chrome come off. But I had an old shower rose and taps in hcl for 3 days nothing. Hence why I'm gonna try reverse electrolysis. There's a company BRM in edgemead that do stunning work for me but due to the lockdown they closed at the moment. But I will keep you posted.
    Thanked: 13623
    A bucket, a battery charger and some bicarb solution. It's worth a try.
  6. The Following User Says Thank You to jelo For This Useful Post:
    durban
    Thanked: 1061
    Are these taps for yourself or for a client.?If for yourself you have nothing to lose.
    Thanked: 175
    Its just for me, I got into a new hobby restoring old taps especially victorian style exposed stuff.
    durban
    Thanked: 1061
    Quote Originally Posted by ismail View Post
    I would try what I suggest with the bicarb.
    May 2016
    Thanked: 3042
    I used washing soda.
    The terminal polarity is very important.
    2006 VW Touareg V10 TDi
  11. The Following User Says Thank You to 4eTouareg For This Useful Post:
    Thanked: 175
    thanks will give the bicarb a go this afternoon, will let you guys know how it comes out.
  13. #11
    Jul 2010
    Modders
    Thanked: 251
    Use an old phone charger, you need low current, negative to a piece of steel, positive to your tap. Use a mix of water and soda ash.
    Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
  14. The Following User Says Thank You to Hamtheman For This Useful Post:
  15. #12
    durban
    Thanked: 1061
    Quote Originally Posted by Hamtheman View Post
    I dont think a charger will do it.
  16. #13
    Thanked: 13623
    I dont think a cell phone charger will do it.
    agreed
    a 4A battery charger will do the job, and if you want to regulate that a little, then put a small gate battery in the circuit
  17. #14
    Thanked: 175
    oh well it is lockdown.
    1. try phone charger (5V 1A) in bicarb (negative to tap)
    2. try PSU module 12V 1A (what i have)
    3. confirm or rethink stratergy if not succesfull
    4. wait for lockdown to stop
  18. #15
    May 2016
    Thanked: 3042
    Positive to tap (or whatever needs to be de-chromed).
    The process is reasonably fast so you could connect it to the car battery with engine running.
  19. The Following User Says Thank You to 4eTouareg For This Useful Post:
  20. #16
    Thanked: 175
    Didn't do it today didn't have bicarb will get some.
    Noted - on positive to tap
  21. #17
    Robertson/ Larissa, Greece
    Thanked: 3318
    Nahh. I think you should connect it straight to mains, 220V. Should be done in no time!
  22. #18
    Thanked: 175
    i would like to make it through the lockdown ; )
  23. #19
    Jul 2010
    Modders
    Thanked: 251
    I have done it with a phone charger .....
    agreed
ID:	567697Click image for larger version.
  24. #20
    Thanked: 505
    I have done it with a phone charger .....Click image for larger version.
    But you did not remove chrome plating as per the Op?
