Lo and behold.... another diy caravan.
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 48
    Jul 2010
    Thanked: 44
    Default Lo and behold.... another diy caravan.
    So the 15th of Dec I started this caravan... or should i say that is when I got it back from Getaway. You see,,,, I realised that to license and register a home built is a massive task. That is when I gave my plan to getaway to build the frame for me. Of course fully licensed and on the road. Below is what it looked like.
ID:	566006   Click image for larger version.
    2015 Mitsubishi triton 2.5 4x4
  2. The Following 4 Users Say Thank You to Joe triton For This Useful Post:
    Jul 2010
    Thanked: 44
    Default Re: Lo and behold.... another diy caravan.
    I have had time so the caravan is in a more advanced state now. The 1st thing I did was build a floor on the Caravan.
  4. The Following 3 Users Say Thank You to Joe triton For This Useful Post:
  5. #3
    Jul 2010
    Thanked: 44
    The next I built the front and back panels onto the caravan.
  6. The Following 2 Users Say Thank You to Joe triton For This Useful Post:
  7. #4
    Jul 2010
    Thanked: 44
    Now after the front and back panels were built it was the very difficult task of the side panels.
ID:	566011   Click image for larger version.
  8. The Following 2 Users Say Thank You to Joe triton For This Useful Post:
  9. #5
    Jul 2010
    Thanked: 44
    Just some info... The axel is a 1.6ton braked axel with a 1.3ton coupler. For the tail lights I used LED lights. The wood is 18mm plywood.
  10. #6
    Jul 2010
    Thanked: 44
    After the sides were built I proceeded to paint the caravan with velvaglo. I used a dark grey colour and used hammerite paint on the galvanizing. The reason why I painted the galvanizing is that the galvanizing is not that great.
ID:	566016   Click image for larger version.
  11. The Following 2 Users Say Thank You to Joe triton For This Useful Post:
  12. #7
    Ruimsig
    Thanked: 10425
    Awesome build.
    So the outer will be the ply and the paint only?
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
  13. #8
    Jul 2010
    Thanked: 44
    The number plate has a very significant meaning. I did not choose it , just so happened. My real name is Johannes Marthinus Nel and I tell everybody that for 29 years I have been battelling to get past the age of 30. So it is my name and age on the caravan.
  14. The Following 2 Users Say Thank You to Joe triton For This Useful Post:
  15. #9
    Jul 2010
    Thanked: 44
    Awesome build.
    I am considering putting 1mm alu sheeting over it, but for now is only paint.
  16. The Following User Says Thank You to Joe triton For This Useful Post:
  17. #10
    Aug 2017
    Thanked: 728
    Quote Originally Posted by Joe triton View Post
    Yeah you're going to have to do something about the plywood. It's not made to withstand the elements, even with a coat of paint. You could coat it with a layer of some sort of waterproofing paint, or perhaps a type of flexible epoxy like used on floors?
    EDIT: It looks brilliant though...
  18. #11
    Jul 2010
    Thanked: 44
    The next I proceeded to build the fridge slide. It is 180kg 1427mm sliders. I have a low profile snomaster 92l dual that will fit there. The slider has no base as alu places are closed. The base will be 4mm alu sheeting.
  19. The Following 2 Users Say Thank You to Joe triton For This Useful Post:
  20. #12
    Jul 2010
    Thanked: 44
    I know that plywood is not the ultmate but for info this piece of plywood is 6years old unpainted closing a bad gate. It has some power.
  21. The Following 2 Users Say Thank You to Joe triton For This Useful Post:
  22. #13
    Jul 2010
    Thanked: 44
    After this I proceeded to build the cupboards in the front. They will all get doors when lockdown is past. The 2 bigger cupboards will be hanging cupboards with hangers that I design. Little shelves always causes shirts and so on to crease.
  23. The Following 3 Users Say Thank You to Joe triton For This Useful Post:
  24. #14
    Jul 2010
    Thanked: 44
    This in turn finished I build the bed 1.9m by 1.4m
  25. The Following 2 Users Say Thank You to Joe triton For This Useful Post:
  26. #15
    Jul 2010
    Thanked: 44
    You will notice a split in the bed. This was done so that if there is an electrical problem I can get to the electrics. Also the space under the bed I did not want to waste so I build pull out sliders there for what have you. The bigger slider can take a 32l fridge. I have mounted a wrnd controller under the bed for the solar and battery.
ID:	566022   Click image for larger version.
ID:	566023   Click image for larger version.
ID:	566024   Click image for larger version.
  27. The Following 2 Users Say Thank You to Joe triton For This Useful Post:
  28. #16
    Mar 2012
    Pierre van Ryneveld
    Thanked: 3922
    No such thing as another DIY caravan thread. These are the best.
    Really cool to see how each one builds their own caravan, that will have a similar function, yet all the different approaches you guys take. These are great threads and thanks for sharing it.
    Hey, I even want to build one myself now. I don't need it just feel the urge to build one
  29. #17
    Jul 2010
    Thanked: 44
    The roof will be a popup alu roof double with foam in between. I will probably lift it about 500 to 600mm. That means any 6 foot guy will stand with ease. However this project must now rest for a little while as material is short and lockdown ensures that I cannot get.
  30. The Following 2 Users Say Thank You to Joe triton For This Useful Post:
  31. #18
    Jul 2010
    Thanked: 44
    The wood is sealed with sika seal onto the metal and then bolted with butthead stainless steel screws. I honestly believe that if this caravan is painted every 3 years it will last forever.
    I have contacted bundutech for there awning with squareback. However it is not cheap and also thinking of my own idee.
  32. The Following 2 Users Say Thank You to Joe triton For This Useful Post:
  33. #19
    Aug 2017
    Thanked: 728
    Quote Originally Posted by Redman View Post
    I fully agree. I don't have space for a caravan (not even if I try), but man these threads make me want to build my own!
    EDIT: What's the legalities on building your own caravan like? Hard to register, get on the road, get approved, etc. etc.?
  34. #20
    Ruimsig
    Thanked: 10425
    Indeed, I have sailed a number of tubs in excess of 10 years old, one or two older than 18 years and all plywood. (Marine Ply)
    Hummer H3 V8
    W.A.P Objectivist
