Trickle charge via cigarette lighter plug?
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 54
    May 2016
    Thanked: 3006
    Default Trickle charge via cigarette lighter plug?
    Simple question.
    Can I attach a (smart) trickle charger to a cigarette lighter socket?
    The socket is "always on".
    2006 VW Touareg V10 TDi
    Aug 2017
    Springs
    Thanked: 35
    Default Re: Trickle charge via cigarette lighter plug?
    On a modern car? With ecu’s in the mix? Personally I wouldn’t
    Driving
    2010 Land Rover Discovery 4 3.0 TD/SD V6 SE
    Klerksdorp
    Thanked: 428
    No, connect the charger directly on to the battery terminals.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
    Nigel
    Thanked: 2255
    If that charger is not going to draw more than 15A, why not.
    If it is an intelligent charger, just make sure it cut out before your crank battery is to low. Else add some kind of protection device.
    Uniglide
    +27 zero eight 2 four 95 9252
    King Williams Town
    Thanked: 1031
    Simple question.
    It will work but take into consideration volt drop in wires ie resistance if the battery is very discharged. Secondly, if you going to leave your car door open to charge via ciggy lighter due to wires, then you might as well pop the bonnet and charge direct onto battery.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  6. The Following User Says Thank You to hunter26 For This Useful Post:
    Thanked: 863
    Are you trying to charge the car battery through the lighter, or charging a second battery from the lighter?
    May 2016
    Thanked: 3006
    The first.
    Thanked: 15
    Check out the latest Harry's Garage on YouTube, he deals with this.
    Short answer is, he does.
    Centurion, Pretoria, SA
    Thanked: 351
    If in doubt leave it out!
    I have a B/H plug that chargers my caravan battery while driving. Simply plug the charger in there with a B/H plug - Wife brags that we now have a hybrid!
    SOMETIMES I WAKE UP GRUMPY,
  11. The Following User Says Thank You to Sneaky Pete For This Useful Post:
    Thanked: 172
    Simple question.
    I'd connect it to the battery, using an inline-fuse perhaps (always safer).
    A trickle charger may still follow the 8-step process and current may spike, blowing your cigarette lighter fuse. Most cigarette fuses are 10A if I recall.
    2018 Ranger DC 2.2 XLS Auto 4x4
    Canon 5DMkIV with L-goodies.
  13. #11
    Thanked: 25
    If the battery was charged prior to the application of the trickle charger then the thin wires should not be a problem.
    Trickle charging has very low currents so there should not be significant voltage drops. There should not be current spikes, especially not north of 2 Amps if the trickle charger is just floating the battery and there are no significant loads connected to the battery.
    Just do not start the engine with the charger connected as the charger would like to "contribute" to the dropping battery voltage due to the high current draws. This is probably the only high current scenario I can think off from personal experience.....Midas battery chargers eats fuses when you attempt to force it to "contribute" amps or jump start a flat bat Hilux !
    In general most trickle chargers, designed for "trickling" and not full blown charging normally also have a fairly low amp rating in any case ( Ja, ja I have seen those fancy high amp C-Teks ! )
    If the system is fused at the charger supply side I don't see the problem.
    With the charger connected measure the voltage on the battery. I would expect it to float in the 13.8 V range on a lead acid battery
    Maybe not an issue, but the 220V power supply will have to get into the car somehow. Just check for pinching at the door seal
    Old:1998 Hilux SC 3000D
    Old: 2001 Hilux DC KZTE
    Old: 2007 Fortuner 3.0D4D
    Current: VW T5.1 BiTdi Transporter
  14. #12
    Thanked: 863
    My concern is that for the lighter socket to be connected to the battery, the ignition has to be partially on.
    I wouldn't.
  15. #13
    Aug 2017
    Durban or Centurion
    Thanked: 1229
    I wouldn't.
    Some vehicles, as with the OP, has an ‘always on’ socket. It is powered even of the ignition is turned off.
  16. The Following User Says Thank You to SAND For This Useful Post:
  17. #14
    Thanked: 863
    Ah, missed that. Thanks.
  18. #15
    Jun 2012
    Thanked: 339
    Even outside of lockdown, the Fortuner does about 6k clicks a year. It's our holiday/long weekend vehicle. It seems to have an inactive tracking unit somewhere, draining the battery over time. So far we've not been able to find it.
    I asked an auto-electrician to modify the one ciggie port for this type of charging, including proper wire and fuse and always-on. So the Ctek is plugged in permanently.
    Much less hassle than fiddling with the bonnet as the car stands nose to the garage wall.
    Make it happen!
    2018 Mobi Lodge
  19. The Following 2 Users Say Thank You to Toccata (Roelof) For This Useful Post:
  20. #16
    Sep 2018
    Thanked: 100
    The first.
    Am I reading this right?
    You want to charge the car battery from the cigarette lighter socket which is powered from the car battery??
  21. #17
    May 2016
    Thanked: 3006
    Quote Originally Posted by Lxv View Post
    Perpetual motion is possible, so why not closec loop charging?
    No, the charger is 220V smart charger.
  22. The Following User Says Thank You to 4eTouareg For This Useful Post:
  23. #18
    Hillcrest, Malaysia
    Thanked: 6455
    Somebody stole 4e's identity.
    Either that or the old man has gone mad.
    Maybe it's lock down sickness.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  24. #19
    Thanked: 601
    Self edit.
    I understand now. You want to 'reverse' the power into the system like plugging a genny into a wall socket.
    Pieter
  25. #20
    Sep 2018
    Thanked: 100
    Sorry, but this is very confusing - this is your original post:
    Simple question.
    Are you asking if you can plug a 220v smart charger into a 12v cigarette lighter socket?
    Or is there maybe an inverter in this perpetual motion loop charging machine?
