Another pizza oven - Page 2
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
  1. #21
    Aug 2017
    Thanked: 668
    Default Re: Another pizza oven
    I got small and compact, OLD oil welder at home, but never learned how to weld. Need a helmet and rods and all that. Think that's my next thing to learn at home.
  2. #22
    Mar 2012
    Pierre van Ryneveld
    Thanked: 3916
    Quote Originally Posted by Toxxyc View Post
    A lot of us learned to weld on old oil welders. The helmet is really one thing I can emphasize. No need to struggle with old type, and flash your eyes unnecessary.
    I also put my rods in the sun for a few minutes before I weld. Not sure if it works or if it is just an old mane tale.
  3. #23
    Robertson/ Larissa, Greece
    Thanked: 3069
    Quote Originally Posted by Redman View Post
    I guess you got the suggestion from someone along the way in your life. It most probably stems from the fact that welding rods should be as dry as possible for obvious conductivity reasons. When I worked in the oil and gas industry where the welding had to be 100%, the welders had an oven on site to dry out the slightest bit of moisture from the rods. All welding rods spent time in the oven before use.
  4. The Following 6 Users Say Thank You to Francois Theron For This Useful Post:
  5. #24
    Thanked: 12783
    also learned on a 60kg oil bath welder
    auto helmet is MANDATORY
    and you can put the rods in the oven
  6. #25
    Ruimsig
    Thanked: 8592
    Awesome project
    Estee = S T = Sean Towlson
    2010 Hummer H3 5.3lt V8, 300 HP, FDL, RDL, CDL, TC and 4:1 Low Range Building for Touring, not Trails
    FJ: One day when I am big
    Land Rovers: Done unfortunately
  7. The Following 2 Users Say Thank You to Estee For This Useful Post:
  8. #26
    Jan 2020
    Kidd's Beach
    Thanked: 43
    Default Finally seems to have got it right
    Thanks for all the help everybody. My wife finally seems to have got the 100 percent rye right.
  9. The Following 2 Users Say Thank You to Khakibush For This Useful Post:
  10. #27
    Jul 2015
    Thanked: 37
    I have made pizza on the campfire as well as the Weber a couple of times, the results can be great but it is a struggle to get/maintain enough heat on the top without burning the base.
    I think you might have the same problem with your design. I would like to see how a pizza turns out, hopefully you will nail it
  11. The Following User Says Thank You to Hanny For This Useful Post:
  12. #28
    Thanked: 526
    Quote Originally Posted by Hanny View Post
    I blind bake the base a bit first. Doing one side to 80%, and the other to 40%. Then I take it off and put toppings on the 80% side, put it back on the fire with the 40% side down. Cover with weber lid over low heat by the time the 40% side is done, the top is also done and cheese melted.
    12 Conqueror courage
    17 Ranger Supercab Tdci (Sold)
    97 Defender 90 CSW 2.8i (Sold)
    04 Defender 110 d/c p/u Td5 (Sold)
    04 Discovery 2 Td5 GS auto (Sold)
    97 Defender HCPU Tdi (Sold)
    99 Discovery 2 TD5 GS (Sold)
  13. The Following 2 Users Say Thank You to LandyLove For This Useful Post:
  14. #29
    durban
    Thanked: 1005
    When I worked on the modular base and accomodation frame (moss gas rig) the welders ,all coloured welders had rod holders that were called hot boxes strapped to their bodies. They had Canadian engineers doing inspection and said they were probably the best welders they have ever seen.
    Makes you think what happened to these guys on the eskom projects. I heard alot of these welders went to Canada.
    I was in awe .Welding huge 40mm thick plates upside down.All seemed to just use stick welders,no mig.Everything was x rayed.
  15. The Following User Says Thank You to plunger For This Useful Post:
  16. #30
    Sep 2012
    North West
    Thanked: 14
    That pizza oven would be nice to be converted further to a gravity feed system for smoking and braaing and and and ...
    Regarding welding, when you can weld you CAN weld. I am however part of the BBB association (ie Bird Butt Brigade because I am a very competent and accomplished bird Shyte applicator).
    Bossies toe!!!
    Work : Toyota LC HZJ76
    Home : Trailblazer 2.8 4X4 LTZ
    SWAMBO: Toyota Avanza - Gone
    Conqueror Commander
    Google know too much.
  17. The Following User Says Thank You to Harry OpieTremspoor For This Useful Post:
  18. #31
    Dec 2015
    Thanked: 98
    The first batch of pizzas was made in a pan as we were ansure about the surface of the baking tray that I had used as it was standing in the elements for quite some time. The 5 pizzas that we made came out very well.
    The next moring I cleaned the tray properly and made some focaccia straight on the base and also didn't have any issuesClick image for larger version.
ID:	567047Click image for larger version.
    2009 Ford Ranger 3.0TDCI
    Raleigh RM9 (Tank)
    Raleigh Chopper MK2 (Restoration porject)
    Giant TCR2 Elite (Silver Train)
    Trek 810 Single speed (Frank)
